LightBen 3 Posted August 22, 2021 Posted August 22, 2021 Bonjour J'utilise Emby depuis un certain temps et je suis un peu perdu car il y a beaucoup d'options. J'ai un compte Emby et je realise que je n'arrive pas a me connecter sur mon NAS depuis mon telephone. Puis j'ai vu qu'il y a l'app Emby QNAP. J'ai installe, et j'essaie de me connecter dessus mais je ne retrouve pas les bibliotheques que j'ai crees a la base, pourquoi ne retrouve-t-il pas tout ? Tout recreer prendrait trop de temps... Merci d'avance =)
Carlo 4561 Posted August 22, 2021 Posted August 22, 2021 Hi, do you have Emby Server setup on your NAS?
LightBen 3 Posted August 22, 2021 Author Posted August 22, 2021 6 minutes ago, cayars said: Hi, do you have Emby Server setup on your NAS? Hi, thanks for your answer, Yes I do. Like I said, first I was using Emby server on my PC, then I installed Emby server on my NAS but I can't connect this to the first and get back all the data I made for some time already (recognizing movies, lists, etc)
Solution Carlo 4561 Posted August 22, 2021 Solution Posted August 22, 2021 Each server is completely different from each other. So if you install a new server you have to setup Users and Libraries on that Server. If you want both server to be available remotely this too needs setting up using different ports. 1
