reiniertaller 0 Posted August 20, 2021 Posted August 20, 2021 compre lifetime y me sigue diciendo en tv en directo que tengo que comprar una suscribcion y en emby premier me dice que tengo lifetime
Mibok 158 Posted August 20, 2021 Posted August 20, 2021 Si eso es desde el navegador intenta borrar las cookies
vdatanet 1619 Posted August 20, 2021 Posted August 20, 2021 Esto sale siempre, simplemente es una advertencia, funciona correctamente. Al tener Premiere, esto debería ocultarse.
reiniertaller 0 Posted August 20, 2021 Author Posted August 20, 2021 No y mi lista de canales no me sale porque no tengo supuestamente Emby premiere
Carlo 4561 Posted August 20, 2021 Posted August 20, 2021 Hi, if you are talking about this just ignore it. That simply means this feature require Premiere but is not a check. Everyone sees this. That message does not go away when you have a Premiere license.
ebr 16334 Posted August 20, 2021 Posted August 20, 2021 Hi. I think you are misunderstanding what you are seeing as your Premiere validation appears to be working fine. If you could go over the specifics of the actual problem you are having, we could probably help. However, you have already filed a claim at PayPal so you would need to withdraw that. Thanks.
reiniertaller 0 Posted August 20, 2021 Author Posted August 20, 2021 119 dollars is paid for what? because my list of channels does not work because it says that I do not have paid prime, and right now it does not work for what I pay, to have my channel list working and my movies. I am sorry but the claim I am not going to withdraw because it does not work for me have a great day
ebr 16334 Posted August 20, 2021 Posted August 20, 2021 10 minutes ago, reiniertaller said: because it says that I do not have paid prime, Exactly where does it say that? Can you show us a screen shot?
reiniertaller 0 Posted August 20, 2021 Author Posted August 20, 2021 My friend the photos are posted here what are in Spanish
vdatanet 1619 Posted August 20, 2021 Posted August 20, 2021 1 minute ago, reiniertaller said: My friend the photos are posted here what are in Spanish Esta advertencia sale aunque tengas Premiere comprado. Yo tengo Premiere comprado y también veo la advertencia y Live TV funciona a la perfección. Debes tener otro problema. ¿Qué sucede cuando intentas sintonizar un canal? Pon los logs del servidor, posiblemente debe tratarse de otro problema.
ebr 16334 Posted August 20, 2021 Posted August 20, 2021 Hi. Yes, as we indicated before, that is not telling you that Premiere is not working. Your very first screen shot is showing that it validated properly. Can you please describe exactly what problem you are having and exactly how you setup your Live TV? You do not have problem with the Premiere activation (that we can see at this point).
reiniertaller 0 Posted August 20, 2021 Author Posted August 20, 2021 10 minutes ago, vdatanet said: Esta advertencia sale aunque tengas Premiere comprado. Yo tengo Premiere comprado y también veo la advertencia y Live TV funciona a la perfección. Debes tener otro problema. ¿Qué sucede cuando intentas sintonizar un canal? Pon los logs del servidor, posiblemente debe tratarse de otro problema. No me sale canales solo las películas
reiniertaller 0 Posted August 20, 2021 Author Posted August 20, 2021 11 minutes ago, ebr said: Hi. Yes, as we indicated before, that is not telling you that Premiere is not working. Your very first screen shot is showing that it validated properly. Can you please describe exactly what problem you are having and exactly how you setup your Live TV? You do not have problem with the Premiere activation (that we can see at this point). As I was saying, I have my lists working and a tuner, previously I paid for the monthly service and I had no problems, now I pay that one and I do not get the channels on the main screen, only the movies, I go to live tv and everything is fine except that I it says I don't have prime
reiniertaller 0 Posted August 20, 2021 Author Posted August 20, 2021 22 minutes ago, ebr said: Hi. Yes, as we indicated before, that is not telling you that Premiere is not working. Your very first screen shot is showing that it validated properly. Can you please describe exactly what problem you are having and exactly how you setup your Live TV? You do not have problem with the Premiere activation (that we can see at this point). Look so you can see, I don't get any channels because I don't have prime activated
ebr 16334 Posted August 20, 2021 Posted August 20, 2021 1 hour ago, reiniertaller said: Look so you can see, I don't get any channels because I don't have prime activated There is nothing on that screen telling you that Emby Premiere is not activated. Would you be willing to let @cayars have access to your system to troubleshoot why your channels are not showing?
Carlo 4561 Posted August 20, 2021 Posted August 20, 2021 @reiniertaller Can we do a remote session and get you fixed up?
ebr 16334 Posted August 23, 2021 Posted August 23, 2021 He accepted a refund through PayPal. @reiniertaller if you ever want to revisit this we're happy to help. Your issue was not with activation. Thanks.
