ITGuy1024 18 Posted August 19, 2021 Posted August 19, 2021 (edited) Hey all, I built a new emby server and it doesn't seem to be using the GPUs for HWA. During playback I see ffmeg tax the CPU pretty heavily. Under the HWA settings > advanced both GPUs are selected for use. CPU: Intel Xeon E5-1607 Memory: 64GB GPU1: GeForce GTX 750 Ti GPU2: GeForce GTX 750 Ti OS: Server 2016 Nvidia Driver: 471.41 Emby Premier: Yes embyserver.txt embyserver-63764972398.txt ffmpeg-transcode-8b77e8e7-e6b4-4a9e-8f99-e56217fcbfa9_1.txt ffmpeg-transcode-64cd6977-764c-43f6-a325-7c0204cc75ad_1.txt ffmpeg-transcode-f1967ffd-c5d6-4a12-a969-88dacf55dbb7_1.txt hardware_detection-63764972430.txt Edited August 19, 2021 by ITGuy1024
rbjtech 5336 Posted August 19, 2021 Posted August 19, 2021 I would start by removing/disabling one of the GTX cards. I don't believe emby/ffmpeg can use more than one GPU anyway - so it might be confusing things - leading to neither of them working. Also ensure the Nvidia driver is the one from Nvidia, not the Microsoft one.
ITGuy1024 18 Posted August 19, 2021 Author Posted August 19, 2021 6 minutes ago, rbjtech said: I would start by removing/disabling one of the GTX cards. I don't believe emby/ffmpeg can use more than one GPU anyway - so it might be confusing things - leading to neither of them working. Also ensure the Nvidia driver is the one from Nvidia, not the Microsoft one. Thanks. I had tried it with one and it had the same behavior. The drive is also the one from Nvidia.
rbjtech 5336 Posted August 19, 2021 Posted August 19, 2021 @softworkz is the expert on this - so hopefully he'll be along to advise.
GrimReaper 4861 Posted August 19, 2021 Posted August 19, 2021 (edited) I've gone through your logs, they are used when applicable, like your 1st log, AVC 1080p: >>>>>> User policy for Emby EnablePlaybackRemuxing: True EnableVideoPlaybackTranscoding: True EnableAudioPlaybackTranscoding: True >>>>>> Affected codecs Encoder NVENC NVIDIA GeForce GTX 750 Ti - H.264 (AVC) Adapter #0: 'NVIDIA GeForce GTX 750 Ti' ComputeCapability: 5.0 Frame Sizes: max 4096x4096 - Width Alignment: 2 - Height Alignment: 2 Profiles: Baseline Profile (Level 6.2), Main Profile (Level 6.2), High Profile (Level 6.2), High 4:4:4 Predictive Profile (Level 6.2) Decoder NVDEC NVIDIA GeForce GTX 750 Ti - H.264 (AVC) Adapter #0: 'NVIDIA GeForce GTX 750 Ti' ComputeCapability: 5.0 Frame Sizes: 48x16...4096x4096 - Width Alignment: 2 - Height Alignment: 2 Profiles: Constrained Baseline Profile (Level 6), Baseline Profile (Level 6), Main Profile (Level 6), High Profile (Level 6), Constrained High Profile (Level 6), Progressive High Profile (Level 6) >>>>>> FindVideoEncoder - Media: h264, UseHardwareCodecs: True, Mode: Custom Info Checking: 'NVENC NVIDIA GeForce GTX 750 Ti - H.264 (AVC)' Info Check successful - selecting 'NVENC NVIDIA GeForce GTX 750 Ti - H.264 (AVC)' >>>>>> FindVideoDecoder - MediaType: h264, Mode: Custom Info Checking: 'NVDEC NVIDIA GeForce GTX 750 Ti - H.264 (AVC)' Info Check successful - selecting 'NVDEC NVIDIA GeForce GTX 750 Ti - H.264 (AVC)' >>>>>> Processing Plan Info Name CanDoInHardware WillDoInHardware Reason Info NVDEC NVIDIA GeForce GTX 750 Ti - H.2... >> True True Hardware Codec Info VideoInput >> True False Matching hardware context Info SubtitleOverlay >> False False Info VideoOutput >> True True Hardware encoder Info NVENC NVIDIA GeForce GTX 750 Ti - H.2... >> True True Hardware Codec >>>>>> Projected Processing Formats Info Previous HW-Context Format SW-Format Size Next Info h264_cuvid >> - nv12 nv12 1920x1080 >> overlay Info overlay >> - nv12 nv12 1920x1080 >> However, looks like the only Maxwell that supports HEVC 4K 10-bit decode in hardware is GTX 960/950, so you're only getting HW encode in that case: >>>>>> FindVideoEncoder - Media: h264, UseHardwareCodecs: True, Mode: Custom Info Checking: 'NVENC NVIDIA GeForce GTX 750 Ti - H.264 (AVC)' Info Check successful - selecting 'NVENC NVIDIA GeForce GTX 750 Ti - H.264 (AVC)' >>>>>> FindVideoDecoder - MediaType: hevc, Mode: Custom Info Checking: 'DX11VA NVIDIA GeForce GTX 750 Ti - H.265 (HEVC)' NoMatch Encoder is not compatible with 'D3d11va' decoders Info Checking: 'DX11VA NVIDIA GeForce GTX 750 Ti [1] - H.265 (HEVC)' NoMatch Encoder is not compatible with 'D3d11va' decoders Info Checking: 'DX11VA NVIDIA GeForce GTX 750 Ti - H.265 (HEVC)' NoMatch Encoder is not compatible with 'D3d11va' decoders Info Checking: 'DX11VA NVIDIA GeForce GTX 750 Ti [1] - H.265 (HEVC)' NoMatch Encoder is not compatible with 'D3d11va' decoders Info Checking: 'Automatic software decoder' Info Check successful - selecting 'Automatic software decoder' Info Tone Mapping would be desired, but hardware tone mapping is disabled >>>>>> Processing Plan Info Name CanDoInHardware WillDoInHardware Reason Info Automatic software decoder >> False False Software Codec Info VideoInput >> False False Not a hardware decoder Info ToneMapping (when possible) >> True True Info VideoOutput >> True True Hardware encoder Info NVENC NVIDIA GeForce GTX 750 Ti - H.2... >> True True Hardware Codec >>>>>> Projected Processing Formats Info Previous HW-Context Format SW-Format Size Next Info hevc >> - yuv420p10 yuv420p10 3840x2160 >> hwupload_cuda Info hwupload_cuda >> CUDA cuda yuv420p10 3840x2160 >> scale_cuda Info scale_cuda >> CUDA cuda nv12 3840x2160 >> setsar Info setsar >> CUDA cuda nv12 3840x2160 >> Edited August 19, 2021 by GrimReaper76
rbjtech 5336 Posted August 19, 2021 Posted August 19, 2021 On the 1080 log - it does appear to be using the GPU ? 12:22:22.962 Stream mapping: 12:22:22.962 Stream #0:0 (h264_cuvid) -> overlay:main (graph 0) 12:22:22.962 Stream #0:3 (pgssub) -> scale (graph 0) 12:22:22.962 overlay (graph 0) -> Stream #0:0 (h264_nvenc) Try swapping the priority on the decoder and putting CUVID at the bottom ?
Carlo 4561 Posted August 19, 2021 Posted August 19, 2021 The 750 TI is only going to decode mpeg2 and AVC streams in hardware so it won't decode HEVC if you have files using that.
ITGuy1024 18 Posted August 19, 2021 Author Posted August 19, 2021 2 minutes ago, cayars said: The 750 TI is only going to decode mpeg2 and AVC streams in hardware so it won't decode HEVC if you have files using that. Would a quadro k620 do hevc?
GrimReaper 4861 Posted August 19, 2021 Posted August 19, 2021 2 minutes ago, cayars said: The 750 TI is only going to decode mpeg2 and AVC streams in hardware so it won't decode HEVC if you have files using that. He has, streams 2 and 3 are HEVC, no HW decode. 1
Carlo 4561 Posted August 19, 2021 Posted August 19, 2021 1 minute ago, ITGuy1024 said: Would a quadro k620 do hevc? https://developer.nvidia.com/video-encode-and-decode-gpu-support-matrix-new You can look up both encode and decode here for different Nvidia GPUs. 2
GrimReaper 4861 Posted August 19, 2021 Posted August 19, 2021 1 minute ago, ITGuy1024 said: Would a quadro k620 do hevc? It's still Maxwell, so I'd guess nope. 1
Carlo 4561 Posted August 19, 2021 Posted August 19, 2021 Yes it's a Maxwell 1st gen chip so basically the same abilities for transcoding as the 750-TI 1
softworkz 5129 Posted August 23, 2021 Posted August 23, 2021 @ITGuy1024 - No way to get hw decoding for HEVC 10bit - BUT: For the first ffmpeg log: You could try the Emby Server beta which supports hw accelerated subtitle overlay For the other two logs: You could try to enable hw tone mapping. It might or might not be faster
