jrwalte 17 Posted August 19, 2021 Posted August 19, 2021 Today ATSC3 went live in ATL. I'm using a HDhomerun connect 4k. The ATSC3 channels work fine in the HDhomerun app but with Emby, I don't get any audio. Video works but the Emby app is becoming unresponsive or crashing when I pull up the GUI (to display stats). I've tried with having play direct checked and unchecked. I submitted log under user 'Justin'.
Carlo 4561 Posted August 19, 2021 Posted August 19, 2021 Hi, The current beta server for windows has just added experimental AC-4 audio support. So in order to test this you would need to be on the beta branch vs the release branch. What server version are you currently running?
jrwalte 17 Posted August 19, 2021 Author Posted August 19, 2021 Server is 4.6.4.0 on Windows. Can I get on the beta?
jrwalte 17 Posted August 19, 2021 Author Posted August 19, 2021 (edited) Ok I saw how to get the beta download. going to try it. OK nevermind. I see the release notes but not an option to select it for download Edited August 19, 2021 by jrwalte
jrwalte 17 Posted August 19, 2021 Author Posted August 19, 2021 Unfortunately this did not help. Now most the time video won't even play. Sometimes I can get it to play, but still no audio. The stats are correctly identifying HEVC and AC-4 now though. I submitted another log under Justin for the app and attached server and some of the ffmpeg. embyserver (1).txt ffmpeg-logs.zip
ebr 16338 Posted August 19, 2021 Posted August 19, 2021 Hi. You should report this in the server beta area as the device is not going to understand AC4 so it will need to be transcoded on the server - and that process is in its infancy right now. Thanks.
