heruofan 4 Posted August 19, 2021 Posted August 19, 2021 When playing 4K HEVC HDR10 video in my Emby Theater APP, it doesnt have pic, but have others, like sound or subs, checked the server and showed was playing directly, no transcode. How can I fix this~? Appreicate~!
Carlo 4561 Posted August 19, 2021 Posted August 19, 2021 Hi, do you have this issue with other HDR 4K media or just this one movie?
Solution Guest Posted August 19, 2021 Solution Posted August 19, 2021 Do you have the Windows hevc extension installed? You should probably just use the desktop app, instead. https://emby.media/emby-theater.html
heruofan 4 Posted August 19, 2021 Author Posted August 19, 2021 32 minutes ago, cayars said: Hi, do you have this issue with other HDR 4K media or just this one movie? seem all similar files have the same problem...paste one other video having same problem Server 4.7.0.7 on NAS 64bit DS918+ APP should be up-to-date
Carlo 4561 Posted August 19, 2021 Posted August 19, 2021 Is this the store version of Theater? If so open a web browser and copy/paste this in the URL and hit enter. ms-windows-store://pdp/?ProductId=9n4wgh0z6vhq You should get a prompt to open the MS store. Click that and it will take you to the HEVC extensions which you can now install. Let us know if this fixes your problem. 1 1
Guest Posted August 19, 2021 Posted August 19, 2021 1 hour ago, cayars said: Is this the store version of Theater?. If you look at the second picture, the app version is 1.1.365.0. That tells us it's the store version of the app
