Guest Posted August 18, 2021 Posted August 18, 2021 i.ratingbutton-icon-withrating { color: #3086CF!important; } Hi, I use this code to change the green color to blue color in focused texts (Home and Favorites) but it doesn't seem to work in the new stable version. Thanks in advance for the adjustments.
Happy2Play 9811 Posted August 18, 2021 Posted August 18, 2021 12 minutes ago, CarlosLima said: i.ratingbutton-icon-withrating { color: #3086CF!important; } Hi, I use this code to change the green color to blue color in focused texts (Home and Favorites) but it doesn't seem to work in the new stable version. Thanks in advance for the adjustments. But that is code for the Favorite icon not focus text.
Guest Posted August 18, 2021 Posted August 18, 2021 Understand. Certainly I made a mess. Is it possible to create a code for me to replace this with a code that keeps the blue color in the focused item? Thank you very much
Happy2Play 9811 Posted August 18, 2021 Posted August 18, 2021 Really you should be looking at :root code as Luke is somewhat themed everything with that now, but yes there are still some outliers. Then click the --theme-accent-text-color to take you to the code So to change all you would do html:root { --theme-accent-text-color: #3086CF; } Unless you are just looking for a specific target?
Guest Posted August 18, 2021 Posted August 18, 2021 Understand. What I would really like is that all the hover links were shown in blue color and not just some specific links. Thanks so much.
Happy2Play 9811 Posted August 18, 2021 Posted August 18, 2021 (edited) 15 minutes ago, CarlosLima said: What I would really like is that all the hover links were shown in blue color and not just some specific links. Sorry are you talking about Hover on link or the Active buttons shown in the image above/title? As hover and active/focus are different. Just like links and buttons are different. Edited August 18, 2021 by Happy2Play
Guest Posted August 18, 2021 Posted August 18, 2021 Understand. I think I explained it carelessly. You managed to solve, as always, and the links (Home and Favorites) are now in the color I use as default. Thank you so much for this once again.
