martymoe 0 Posted August 16, 2021 Posted August 16, 2021 Does anyone have a step by step how to install Emby server on TrueNas? i've had a Win install for years, but i cant even get the UI to come up on TrueNas thanks.
Luke 42246 Posted August 16, 2021 Posted August 16, 2021 Hi there, what exactly is the problem that you're having?
martymoe 0 Posted August 19, 2021 Author Posted August 19, 2021 HI, thanks for you reply. i've tried installing it a couple of times, the first time it seemed to be ok (i used nat because dhcp failed) and i cant see the service when i try to connect with a web browser. i tried a few different methods to install it other ways (things i found on the internet) now when i setup the jail as soon as i take it off line to configure it, the whole thing goes away.. i'm afraid i've messed something up.. super new to freenas/truenas is there some way to reset all of the jails and start fresh? thanks
Luke 42246 Posted August 19, 2021 Posted August 19, 2021 You could just delete the jail and start again if you wish.
jmccl069 7 Posted September 27, 2021 Posted September 27, 2021 I have set up a linux VM in my TrueNAS and am running the Ubuntu version of Emby Server 4.7.0.9 beta through the VM without issue. Has been reliable for a couple of years now.
