SmileFlower 21 Posted August 13, 2021 Posted August 13, 2021 Some built-in ass subtitles with special effects cannot be read and displayed AllLog.txt
SmileFlower 21 Posted August 13, 2021 Author Posted August 13, 2021 Tips E/libass_jni(22611): Failed to lock the native window. Error: -22
ebr 16338 Posted August 13, 2021 Posted August 13, 2021 Hi. What exactly is happening? What is different about these subs vs others that do work?
SmileFlower 21 Posted August 13, 2021 Author Posted August 13, 2021 Just now, ebr said: Hi. What exactly is happening? What is different about these subs vs others that do work? Some mkvs with built-in ass subtitles will not display subtitles
SmileFlower 21 Posted August 13, 2021 Author Posted August 13, 2021 11 minutes ago, ebr said: Hi. What exactly is happening? What is different about these subs vs others that do work? The video sample has a size of 11gb. Do I want to upload it to Google drive?
ebr 16338 Posted August 13, 2021 Posted August 13, 2021 2 minutes ago, ilolita945 said: The video sample has a size of 11gb. Do I want to upload it to Google drive? If you can, sure. Or, if a one minute clip of it exhibits the same behavior and you can create that, then that will work too. Thanks.
SmileFlower 21 Posted August 14, 2021 Author Posted August 14, 2021 (edited) 9 hours ago, ebr said: If you can, sure. Or, if a one minute clip of it exhibits the same behavior and you can create that, then that will work too. Thanks. The following built-in ass subtitle TV client of this type cannot display normally This is the file link: https://drive.google.com/file/d/1wBWqI6TRLdblErCKjQuZ7wqs-gfe9MGt/view?usp=sharing Mobile client display Web client display Edited August 14, 2021 by ilolita945
ebr 16338 Posted August 14, 2021 Posted August 14, 2021 It is downloading (which will take a while) but I just played it directly from your link and no subs showed.
SmileFlower 21 Posted August 14, 2021 Author Posted August 14, 2021 1 minute ago, ebr said: It is downloading (which will take a while) but I just played it directly from your link and no subs showed. Built in two ass subtitles
rodainas 191 Posted August 14, 2021 Posted August 14, 2021 2 minutes ago, ebr said: It is downloading (which will take a while) but I just played it directly from your link and no subs showed. Thats normal with that type of link, the google player doesn't show embedded subtitles those mkv videos (nor srt, nor ass).
ebr 16338 Posted August 14, 2021 Posted August 14, 2021 They display fine for me with your sample file. What device are you playing on?
SmileFlower 21 Posted August 14, 2021 Author Posted August 14, 2021 1 minute ago, ebr said: They display fine for me with your sample file. What device are you playing on? Emby for Android TV Toshiba 65u 6900c TV The following is the equipment information
ebr 16338 Posted August 14, 2021 Posted August 14, 2021 Unless it is related to being all the way back on Android 6.0, I'm not sure why it isn't working for you.
SmileFlower 21 Posted August 14, 2021 Author Posted August 14, 2021 Just now, ebr said: Unless it is related to being all the way back on Android 6.0, I'm not sure why it isn't working for you. I have the same problem when installing emby for Android TV on my mobile phone. I can't display this built-in ass subtitle
Carlo 4561 Posted August 14, 2021 Posted August 14, 2021 4 minutes ago, ilolita945 said: I have the same problem when installing emby for Android TV on my mobile phone. I can't display this built-in ass subtitle Why/how are you installing this version on a mobile device?
SmileFlower 21 Posted August 14, 2021 Author Posted August 14, 2021 2 minutes ago, cayars said: Why/how are you installing this version on a mobile device? To test the built-in ass subtitles of the media
Carlo 4561 Posted August 14, 2021 Posted August 14, 2021 But how are you installing the TV version on the Mobile OS is what I'm asking.
ebr 16338 Posted August 14, 2021 Posted August 14, 2021 I'm afraid I'm befuddled at the moment... @cayars can you try his sample?
SmileFlower 21 Posted August 14, 2021 Author Posted August 14, 2021 1 minute ago, ebr said: I'm afraid I'm befuddled at the moment... @cayars can you try his sample? The sample has two subtitles. Can you show the second subtitle?
SmileFlower 21 Posted August 14, 2021 Author Posted August 14, 2021 1 minute ago, cayars said: Yes, downloading it right now. Try both subtitles
Carlo 4561 Posted August 14, 2021 Posted August 14, 2021 (edited) On Shield TV playing direct both subs work for me. In web either direct streaming or transcoding neither sub plays for me. Synology 4.7.0.7 Server Edited August 14, 2021 by cayars
SmileFlower 21 Posted August 14, 2021 Author Posted August 14, 2021 15 minutes ago, cayars said: On Shield TV playing direct both subs work for me. In web either direct streaming or transcoding neither sub plays for me. Synology 4.7.0.7 Server Play normal display on mobile phone
ebr 16338 Posted August 14, 2021 Posted August 14, 2021 Both subs work for me on Android TV (Sony) as well.
Luke 42246 Posted August 14, 2021 Posted August 14, 2021 Both subs play just fine for me in the web app?
