Guest Posted August 13, 2021 Posted August 13, 2021 <div class="Personal-Links" style="top:100px;text-align:center;position:relative;"> <a is="emby-linkbutton" class="button-link" href="URL1" target="_blank" style="text-decoration: none;color: #D3D3D3" "margin: 0.7em;">Tv ao Vivo</a> <a is="emby-linkbutton" class="button-link" href="URL2" target="_blank" style="text-decoration: none;color: #D3D3D3" "margin: 0.7em;">Pedidos</a> <a is="emby-linkbutton" class="button-link" href="URL3" target="_blank" style="text-decoration: none;color: #D3D3D3" "margin: 0.7em;">Planos</a> <a is="emby-linkbutton" class="button-link" href="URL4" target="_blank" style="text-decoration: none;color: #D3D3D3" "margin: 0.7em;">Site</a> <a is="emby-linkbutton" class="button-link" href="URL5" target="_blank" style="text-decoration: none;color: #D3D3D3" "margin: 0.7em;">Suporte</a> </div> Hi I use external links on the home page and have noticed that between them contains a lot of space, breaking the line on smartphone screens. I would like some help, as I believe that something happened to the code to present this problem. Thanks for any tips.
Happy2Play 9811 Posted August 13, 2021 Posted August 13, 2021 You could adjust your "margin: 0.7em" you have set per link. Or change from em to %.
Guest Posted August 13, 2021 Posted August 13, 2021 Hey, Thank you so much for your attention. See the new image. I've tested it with several numbers but nothing has changed. I plan to have 2 or 3 blank spaces between each link. Thanks again.
Guest Posted August 13, 2021 Posted August 13, 2021 (edited) <div class="Personal-Links" style="top:60px;text-align:center;position:relative;"> <a is="emby-linkbutton" class="button-link" href="LINK1" target="_blank" style="text-decoration: none;color: #D3D3D3">TEXT1</a>   <a is="emby-linkbutton" class="button-link" href="LINK2" target="_blank" style="text-decoration: none;color: #D3D3D3">TEXT2</a>   <a is="emby-linkbutton" class="button-link" href="LINK5" target="_blank" style="text-decoration: none;color: #D3D3D3">TEXT3</a> </div> SOLVED ....After several edits in the code I managed to make it work with this code. I just removed "margin: 0 .7em" and applied one command   for each blank. As far as I've tested it worked fine now and I hope it doesn't conflict with the other codes. Thanks for all your help. Edited August 13, 2021 by CarlosLima
Solution Happy2Play 9811 Posted August 13, 2021 Solution Posted August 13, 2021 Your previous style code was actually broken. Missing semicolon and additional quotes <div class="Personal-Links" style="top:100px;text-align:center;position:relative;"> <a is="emby-linkbutton" class="button-link" href="URL1" target="_blank" style="text-decoration: none;color: #D3D3D3;margin: 0.7%;">Tv ao Vivo</a> <a is="emby-linkbutton" class="button-link" href="URL2" target="_blank" style="text-decoration: none;color: #D3D3D3;margin: 0.7%;">Pedidos</a> <a is="emby-linkbutton" class="button-link" href="URL3" target="_blank" style="text-decoration: none;color: #D3D3D3;margin: 0.7%;">Planos</a> <a is="emby-linkbutton" class="button-link" href="URL4" target="_blank" style="text-decoration: none;color: #D3D3D3;margin: 0.7%;">Site</a> <a is="emby-linkbutton" class="button-link" href="URL5" target="_blank" style="text-decoration: none;color: #D3D3D3;margin: 0.7%;">Suporte</a> </div>
Guest Posted December 16, 2021 Posted December 16, 2021 On 8/13/2021 at 6:03 PM, Happy2Play said: Your previous style code was actually broken. Missing semicolon and additional quotes <div class="Personal-Links" style="top:100px;text-align:center;position:relative;"> <a is="emby-linkbutton" class="button-link" href="URL1" target="_blank" style="text-decoration: none;color: #D3D3D3;margin: 0.7%;">Tv ao Vivo</a> <a is="emby-linkbutton" class="button-link" href="URL2" target="_blank" style="text-decoration: none;color: #D3D3D3;margin: 0.7%;">Pedidos</a> <a is="emby-linkbutton" class="button-link" href="URL3" target="_blank" style="text-decoration: none;color: #D3D3D3;margin: 0.7%;">Planos</a> <a is="emby-linkbutton" class="button-link" href="URL4" target="_blank" style="text-decoration: none;color: #D3D3D3;margin: 0.7%;">Site</a> <a is="emby-linkbutton" class="button-link" href="URL5" target="_blank" style="text-decoration: none;color: #D3D3D3;margin: 0.7%;">Suporte</a> </div> Hello again broke on emby server stable version 4670. Thanks again if you can help fix the code. What I need is to have the texts with only 2 blank spaces between them. I am gratefull for that.
Happy2Play 9811 Posted December 16, 2021 Posted December 16, 2021 1 hour ago, CarlosLima said: Hello again broke on emby server stable version 4670. Thanks again if you can help fix the code. What I need is to have the texts with only 2 blank spaces between them. I am gratefull for that. What is broke? All I had to do is adjust top. As for space between links adjust or remove the margin per link.
Guest Posted December 16, 2021 Posted December 16, 2021 <div class="Personal-Links" style="top:90px;text-align:center;position:relative;text-decoration:none;color:#D3D3D3;"> <a is="emby-linkbutton" class="button-link" href="LINK1" target="_blank;">TEXT1</a> <a is="emby-linkbutton" class="button-link" href="LINK2" target="_blank;">TEXT2</a> <a is="emby-linkbutton" class="button-link" href="LINK3" target="_blank;">TEXT3</a> <a is="emby-linkbutton" class="button-link" href="LINK4" target="_blank;">TEXT4</a> <a is="emby-linkbutton" class="button-link" href="LINK5" target="_blank;">TEXT5</a> <a is="emby-linkbutton" class="button-link" href="LINK6" target="_blank;">TEXT6</a> </div> I'm trying to start over from scratch. Can you let me know if there is something wrong with this code?
Happy2Play 9811 Posted December 16, 2021 Posted December 16, 2021 1 hour ago, CarlosLima said: <div class="Personal-Links" style="top:90px;text-align:center;position:relative;text-decoration:none;color:#D3D3D3;"> <a is="emby-linkbutton" class="button-link" href="LINK1" target="_blank;">TEXT1</a> <a is="emby-linkbutton" class="button-link" href="LINK2" target="_blank;">TEXT2</a> <a is="emby-linkbutton" class="button-link" href="LINK3" target="_blank;">TEXT3</a> <a is="emby-linkbutton" class="button-link" href="LINK4" target="_blank;">TEXT4</a> <a is="emby-linkbutton" class="button-link" href="LINK5" target="_blank;">TEXT5</a> <a is="emby-linkbutton" class="button-link" href="LINK6" target="_blank;">TEXT6</a> </div> I'm trying to start over from scratch. Can you let me know if there is something wrong with this code? Seem to work fine for me. Only adjusted top. home.html Spoiler <div class="view flex flex-direction-column withTabs"> <div class="tabContent flex flex-grow" data-index="0"> <div is="emby-scroller" data-horizontal="false" data-centerfocus="true" data-navcommands="card" data-forcescrollbar="true" class="scrollFrameY flex flex-direction-column flex-grow focuscontainer-down" data-bindheader="true"> <div class="Personal-Links" style="top:150px;text-align:center;position:relative;text-decoration:none;color:#D3D3D3;"> <a is="emby-linkbutton" class="button-link" href="LINK1" target="_blank;">TEXT1</a> <a is="emby-linkbutton" class="button-link" href="LINK2" target="_blank;">TEXT2</a> <a is="emby-linkbutton" class="button-link" href="LINK3" target="_blank;">TEXT3</a> <a is="emby-linkbutton" class="button-link" href="LINK4" target="_blank;">TEXT4</a> <a is="emby-linkbutton" class="button-link" href="LINK5" target="_blank;">TEXT5</a> <a is="emby-linkbutton" class="button-link" href="LINK6" target="_blank;">TEXT6</a> </div> <div class="scrollSlider flex-grow padded-top-page sections"> </div> <div class="padded-bottom-page"></div> </div> </div> <div class="tabContent flex flex-grow" data-index="1"> <div is="emby-scroller" data-horizontal="false" data-centerfocus="true" data-navcommands="card" data-forcescrollbar="true" class="scrollFrameY flex flex-direction-column flex-grow focuscontainer-down" data-bindheader="true"> <div class="scrollSlider flex-grow padded-top-page sections"> </div> <div class="padded-bottom-page"></div> </div> </div> </div>
