vfrjim 1 Posted August 12, 2021 Posted August 12, 2021 I am migrating both of my Windows 10 Emby servers to Linux Mint 20.2 and all is going well BUT, when a recording is made with the live DVR, it is locked and owned by the Emby - Server. What is the proper way to make it FULLY accessible to all programs (IE, needs to be able to be deleted by third party app for post-processing). Anyone help? Thanks.
dwasifar 1 Posted August 12, 2021 Posted August 12, 2021 (edited) Well, if you're just wanting to make individual files available to all comers on a one by one basis, the command for that is: sudo chmod 777 myfilename.abc Or you may be able to do it from the GUI by right-clicking the file, choosing Properties, then the Permissions tab. But I think the point of your question is not to modify a file's permissions on your own, but rather to set things up so that Emby creates the file with open permissions in the first place. There I cannot help you. However, as a workaround, you could put a variation of that chmod command into crontab and let the system change the permissions on everything in that directory every so often. Edited August 12, 2021 by dwasifar
Q-Droid 1011 Posted August 12, 2021 Posted August 12, 2021 What are the storage type(s) and filesystem(s) used for your media?
vfrjim 1 Posted August 12, 2021 Author Posted August 12, 2021 25 minutes ago, Q-Droid said: What are the storage type(s) and filesystem(s) used for your media? I am using a mechanical drive, 3 TB Hitachi, it is formatted Ext4, Mounted at /home/jimd/Media. Folders are located there, owned by my account.
Solution Q-Droid 1011 Posted August 12, 2021 Solution Posted August 12, 2021 Two links to read thru: https://support.emby.media/support/solutions/articles/44001962818-linux-unix-permissions https://emby.media/community/index.php?/topic/32218-file-permissions-guide-for-new-linux-users/
vfrjim 1 Posted August 13, 2021 Author Posted August 13, 2021 2 hours ago, Q-Droid said: Two links to read thru: https://support.emby.media/support/solutions/articles/44001962818-linux-unix-permissions The above link solved my problem for both Emby and Plex. I appreciate the help.
