Fredlys1912 0 Posted August 11, 2021 Posted August 11, 2021 Hello all, I need help , i want replace logo by cover on android TV app automatically, i guess modifiying the css can do that. Not native english language here so for be more clear : The original look : the wanted look : ( i changed manually the logo picture by the cover) Please, someone can help and give the CSS code to do that automatically ?
Happy2Play 9811 Posted August 11, 2021 Posted August 11, 2021 All clients have their own code and custom CSS only applies to the Web client, not the online Web client or any other client. At the same time you can not change logo to poster with css.
Fredlys1912 0 Posted August 11, 2021 Author Posted August 11, 2021 (edited) thanks for your answer ok, my mistake, i thought the css also applied to android TV seen in display option i can change the mode to TV. If we can't by CSS, is there some other way to change the logo to poster automatically? or just don't show the logo ? Edited August 11, 2021 by Fredlys1912
tomnjerry74 97 Posted August 11, 2021 Posted August 11, 2021 3 hours ago, Fredlys1912 said: thanks for your answer ok, my mistake, i thought the css also applied to android TV seen in display option i can change the mode to TV. If we can't by CSS, is there some other way to change the logo to poster automatically? or just don't show the logo ? Do you need to have the logos at all? If not, you could just set the library scraper to not download them in the first place. On android tv if there is no logo image then it uses the poster automatically. 1
