moviepalace4K 30 Posted August 10, 2021 Posted August 10, 2021 Hey, Is it possible to keep 1 particular theme (after server installation) that comes with the server in such a way that it is selected as default in the web app and one cannot switch themes? Intended to keep theme is "Dark (Red Accent)". I hope this is possible. regards
Happy2Play 9811 Posted August 10, 2021 Posted August 10, 2021 Would need a little tweaking but copying that C:\Users\username\AppData\Roaming\Emby-Server\system\dashboard-ui\modules\themes\dark-red\theme.css and pasting in the custom css box would accomplish that. I know one tweak is changing :root to html:root as that will override existing code instead of having to apply !important.
Happy2Play 9811 Posted August 10, 2021 Posted August 10, 2021 It is extra work with every upgrade but you could copy the contents of the dark-red theme folder into all the other themes. Create a bat/script file that can be run with every server update.
Solution moviepalace4K 30 Posted August 11, 2021 Author Solution Posted August 11, 2021 5 hours ago, Happy2Play said: 5 hours ago, Happy2Play said: It is extra work with every upgrade but you could copy the contents of the dark-red theme folder into all the other themes. Create a bat/script file that can be run with every server update. This is indeed the easiest solution for my purpose (No batch/script but copy and paste is fast enough)
TVTech 8 Posted November 9, 2025 Posted November 9, 2025 Which one of these solutions is the better option?
TVTech 8 Posted November 9, 2025 Posted November 9, 2025 On 8/10/2021 at 6:43 PM, Happy2Play said: It is extra work with every upgrade but you could copy the contents of the dark-red theme folder into all the other themes. Create a bat/script file that can be run with every server update. Does the Emby server need to be restarted afterwards for these changes to take effect? Also should I be deleting the contents of each theme folder before I copy the theme that I want into them?
