Jogi1986 9 Posted August 9, 2021 Posted August 9, 2021 Guten Tag, ist es möglich mit Emby 4k HDR / Doby Vision Inhalte wiederzugeben? Habe seit letzter Wochen Den LG OLED55B19LA der HDR10+ und Dolby Vision kann. Jetzt habe ich mir mal testweise 2 4K HDR10+ Filme in Emmy geladen. Emby selbst zeigt auch an das der Film in "4K HEVC HDR10" vorliegt. Wenn ich den Film jetzt über die Emby App abspiele, spielt er zwar ab, allerdings springt mein Tv nicht in den HDR Modus, was er bei Dysney+, Netflix etc auch automatisch macht. (An Inhalte anpassen ist an) Was mache ich falsch? Oder muss im Server noch was eingestellt werden? Hardware Server: Mac mini 2014; 2,6Ghz i5; 8GB Ram - Emby 4.6.1.0 Player: Apple TV 4K (2017) mit aktuellster Emby App
Carlo 4561 Posted August 9, 2021 Posted August 9, 2021 Hi, this is going to depend on a few things. First for good 4K viewing in house (same LAN as server) you want to make sure your media is direct played so check stats for nerds (cog menu) during playback. Let us know what stats for nerds show you. Can you download MediaInfo and show us what this shows for the media you are trying to play back?
Jogi1986 9 Posted August 9, 2021 Author Posted August 9, 2021 My Server and and Apple TV are connected With 1GBit Ethernet over Lan Cable. Die 4K File runs Good on my AppleTV and i have no laggs. But die Emby App shows Not the HDR Colors, while my TV dont change the Modus from SDR to HDR. Normaly the Apple TV makes this automaticly
Carlo 4561 Posted August 9, 2021 Posted August 9, 2021 Still need the info asked for in my previous post.
Jogi1986 9 Posted August 9, 2021 Author Posted August 9, 2021 Ok, when I am at home. I hope that’s ok. I am work 1
Jogi1986 9 Posted August 11, 2021 Author Posted August 11, 2021 On 8/9/2021 at 6:14 PM, cayars said: Still need the info asked for in my previous post. Sorry for the late reply .. Please find attached the requested pictures
Carlo 4561 Posted August 11, 2021 Posted August 11, 2021 Sorry, can you post the text version of that screen which contains more info.
Jogi1986 9 Posted August 11, 2021 Author Posted August 11, 2021 (edited) Please. A Screenshot from the Emby Fileinfo Sorry, I can’t copy the media infos as a text from emby Edited August 11, 2021 by Jogi1986
Carlo 4561 Posted August 11, 2021 Posted August 11, 2021 Need this from the program Media Info in the tree view with the options for levels and profiles turned on. We want to see the levels/profiles for the video which Emby doesn't have.
Happy2Play 9811 Posted August 11, 2021 Posted August 11, 2021 6 minutes ago, cayars said: We want to see the levels/profiles for the video which Emby doesn't have. But provided images show that L5.1/level 153 and profile Main10 High/Main 10, or am I missing something?
Carlo 4561 Posted August 11, 2021 Posted August 11, 2021 (edited) Based on ffprobe which doesn't always get this correct. It's likely correct, but just want to double check. Edited August 11, 2021 by cayars
Jogi1986 9 Posted August 11, 2021 Author Posted August 11, 2021 Ok. In afternoon I can Make a screenshot from Media Info 1
Jogi1986 9 Posted August 12, 2021 Author Posted August 12, 2021 (edited) Good morning, here is the information from Mediainfo as text Spoiler ID : 1 Format : HEVC Format/Info : High Efficiency Video Coding Commercial name : HDR10 Format profile : Main 10@L5.1@High Codec ID : V_MPEGH/ISO/HEVC Duration : 2 h 3 min Bit rate : 41.8 Mb/s Width : 3 840 pixels Height : 2 160 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 23.976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 (Type 2) Bit depth : 10 bits Bits/(Pixel*Frame) : 0.210 Stream size : 36.2 GiB (98%) Language : English Default : Yes Forced : No Color range : Limited Color primaries : BT.2020 Transfer characteristics : PQ Matrix coefficients : BT.2020 non-constant Mastering display color primaries : Display P3 Mastering display luminance : min: 0.0050 cd/m2, max: 4000 cd/m2 Maximum Content Light Level : 1000 cd/m2 Maximum Frame-Average Light Level : 657 cd/m2 Edited August 12, 2021 by Jogi1986
Carlo 4561 Posted August 12, 2021 Posted August 12, 2021 Thanks for that confirmation and of course @Happy2Play was correct. When playing this file back to the TV what does Emby Server show for the playback? Direct Play, Direct Stream or Transcoding?
Jogi1986 9 Posted August 12, 2021 Author Posted August 12, 2021 I use the emby App for Apple TV and the Kodi Sync Addon. With no from these 2 I have HDR Mode on my TV. With Apple TV+, Netflix etc I have HDR because Dolby Vision. But with Emby my TV didn’t switch in the HDR Mode. Apple TV is corrected configuring. adapt to content. Is activated on Apple TV. I think it is a problem with server or App/Addon. While, when I play the file on a test Plex Server, my tv goes in HDR Mode.
Carlo 4561 Posted August 12, 2021 Posted August 12, 2021 Refer to my previous question in the post above yours.
Jogi1986 9 Posted August 12, 2021 Author Posted August 12, 2021 (edited) I have the Emby standard settings where can I actually set that Edited August 12, 2021 by Jogi1986
Carlo 4561 Posted August 12, 2021 Posted August 12, 2021 It's not a setting but the Dashboard show this when you playback a video. Look at the device on the Dashboard when playing back this media and it will show one of the 3 values.
Jogi1986 9 Posted August 14, 2021 Author Posted August 14, 2021 Good Morning, sorry for the late answer. I checked the playback variant on emby app and Kodi add-on. The Variant is direct Playback
Carlo 4561 Posted August 14, 2021 Posted August 14, 2021 Does that translate to "Direct Play" or "Direct Stream" ? If it's Direct Play I'm not sure what the issue could be and we will need to hear from one of the AppleTV devs.
Jogi1986 9 Posted August 14, 2021 Author Posted August 14, 2021 (edited) Direct Play is right. Edited August 14, 2021 by Jogi1986
Jogi1986 9 Posted August 15, 2021 Author Posted August 15, 2021 I think the problem ist the Emby app and the kodi sync Addon. I tested a 4K HDR Video on my Emby Server with MrMc (the same, what I tested with the emby app) and MrMC show me the HDR Colors and my tv goes into the HDR Mode. Same with a Dolby Vision File. With Emby App no Dolby Vision. In MrMc I have Dolby Vision Colors
Luke 42241 Posted August 16, 2021 Posted August 16, 2021 Have you tried the Emby app on your Apple TV instead of Kodi?
Jogi1986 9 Posted August 16, 2021 Author Posted August 16, 2021 Yes. I've tried both. I also tried the stable add-on and the beta add-on at kodi. The apple TV app is also up to date.
