Meltx103 3 Posted August 9, 2021 Posted August 9, 2021 (edited) I have a drive which S.M.A.R.T. checks have started reporting as 'having a few bad sectors'. Its been like this for a while, and the disk seems fine but if it's about to die without warning perhaps I need to take it out of rotation. I'm not too familiar with S.M.A.R.T. or disk health (this is the first one I've had problems with) and I'm wondering if someone here has more experience and can tell me how bad it is. Here's the extended information from S.M.A.R.T. edit: better resolution upload of the picture. smartctl 7.2 2020-12-30 r5155 [x86_64-linux-5.10.0-7-amd64] (local build) Copyright (C) 2002-20, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Model Family: Seagate NAS HDD Device Model: ST4000VN000-2AH166 Serial Number: WDH099NQ LU WWN Device Id: 5 000c50 09c73f791 Firmware Version: SC60 User Capacity: 4,000,787,030,016 bytes [4.00 TB] Sector Sizes: 512 bytes logical, 4096 bytes physical Rotation Rate: 5980 rpm Form Factor: 3.5 inches Device is: In smartctl database [for details use: -P show] ATA Version is: ACS-3 T13/2161-D revision 5 SATA Version is: SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s) Local Time is: Mon Aug 9 05:13:03 2021 CEST SMART support is: Available - device has SMART capability. SMART support is: Enabled AAM feature is: Unavailable APM level is: 254 (maximum performance) Rd look-ahead is: Enabled Write cache is: Enabled DSN feature is: Unavailable ATA Security is: Disabled, frozen [SEC2] Wt Cache Reorder: Enabled === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED See vendor-specific Attribute list for marginal Attributes. General SMART Values: Offline data collection status: (0x82) Offline data collection activity was completed without error. Auto Offline Data Collection: Enabled. Self-test execution status: ( 0) The previous self-test routine completed without error or no self-test has ever been run. Total time to complete Offline data collection: ( 591) seconds. Offline data collection capabilities: (0x7b) SMART execute Offline immediate. Auto Offline data collection on/off support. Suspend Offline collection upon new command. Offline surface scan supported. Self-test supported. Conveyance Self-test supported. Selective Self-test supported. SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time: ( 1) minutes. Extended self-test routine recommended polling time: ( 621) minutes. Conveyance self-test routine recommended polling time: ( 2) minutes. SCT capabilities: (0x50bd) SCT Status supported. SCT Error Recovery Control supported. SCT Feature Control supported. SCT Data Table supported. SMART Attributes Data Structure revision number: 10 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAGS VALUE WORST THRESH FAIL RAW_VALUE 1 Raw_Read_Error_Rate POSR-- 083 064 044 - 180053203 3 Spin_Up_Time PO---- 094 093 000 - 0 4 Start_Stop_Count -O--CK 097 097 020 - 3341 5 Reallocated_Sector_Ct PO--CK 100 100 010 - 616 7 Seek_Error_Rate POSR-- 088 060 045 - 698744563 9 Power_On_Hours -O--CK 070 070 000 - 27089 (196 165 0) 10 Spin_Retry_Count PO--C- 100 100 097 - 0 12 Power_Cycle_Count -O--CK 100 100 020 - 714 184 End-to-End_Error -O--CK 100 100 099 - 0 187 Reported_Uncorrect -O--CK 097 097 000 - 3 188 Command_Timeout -O--CK 100 100 000 - 131074 189 High_Fly_Writes -O-RCK 100 100 000 - 0 190 Airflow_Temperature_Cel -O---K 066 040 040 Past 34 (Min/Max 28/41) 191 G-Sense_Error_Rate -O--CK 100 100 000 - 0 192 Power-Off_Retract_Count -O--CK 099 099 000 - 2606 193 Load_Cycle_Count -O--CK 090 090 000 - 20204 194 Temperature_Celsius -O---K 034 060 000 - 34 (0 17 0 0 0) 197 Current_Pending_Sector -O--C- 100 100 000 - 8 198 Offline_Uncorrectable ----C- 100 100 000 - 8 199 UDMA_CRC_Error_Count -OSRCK 200 200 000 - 0 240 Head_Flying_Hours ------ 100 253 000 - 35640 (115 136 0) 241 Total_LBAs_Written ------ 100 253 000 - 79737096008 242 Total_LBAs_Read ------ 100 253 000 - 308695626833 ||||||_ K auto-keep |||||__ C event count ||||___ R error rate |||____ S speed/performance ||_____ O updated online |______ P prefailure warning General Purpose Log Directory Version 1 SMART Log Directory Version 1 [multi-sector log support] Address Access R/W Size Description 0x00 GPL,SL R/O 1 Log Directory 0x01 SL R/O 1 Summary SMART error log 0x02 SL R/O 5 Comprehensive SMART error log 0x03 GPL R/O 5 Ext. Comprehensive SMART error log 0x04 GPL,SL R/O 8 Device Statistics log 0x06 SL R/O 1 SMART self-test log 0x07 GPL R/O 1 Extended self-test log 0x09 SL R/W 1 Selective self-test log 0x10 GPL R/O 1 NCQ Command Error log 0x11 GPL R/O 1 SATA Phy Event Counters log 0x13 GPL R/O 1 SATA NCQ Send and Receive log 0x15 GPL R/W 1 Rebuild Assist log 0x21 GPL R/O 1 Write stream error log 0x22 GPL R/O 1 Read stream error log 0x24 GPL R/O 512 Current Device Internal Status Data log 0x30 GPL,SL R/O 9 IDENTIFY DEVICE data log 0x80-0x9f GPL,SL R/W 16 Host vendor specific log 0xa1 GPL,SL VS 24 Device vendor specific log 0xa2 GPL VS 8160 Device vendor specific log 0xa6 GPL VS 192 Device vendor specific log 0xa8-0xa9 GPL,SL VS 136 Device vendor specific log 0xab GPL VS 1 Device vendor specific log 0xb0 GPL VS 9048 Device vendor specific log 0xbe-0xbf GPL VS 65535 Device vendor specific log 0xc1 GPL,SL VS 16 Device vendor specific log 0xd1 GPL VS 136 Device vendor specific log 0xd2 GPL VS 10000 Device vendor specific log 0xd3 GPL VS 1920 Device vendor specific log 0xe0 GPL,SL R/W 1 SCT Command/Status 0xe1 GPL,SL R/W 1 SCT Data Transfer SMART Extended Comprehensive Error Log Version: 1 (5 sectors) Device Error Count: 3 CR = Command Register FEATR = Features Register COUNT = Count (was: Sector Count) Register LBA_48 = Upper bytes of LBA High/Mid/Low Registers ] ATA-8 LH = LBA High (was: Cylinder High) Register ] LBA LM = LBA Mid (was: Cylinder Low) Register ] Register LL = LBA Low (was: Sector Number) Register ] DV = Device (was: Device/Head) Register DC = Device Control Register ER = Error register ST = Status register Powered_Up_Time is measured from power on, and printed as DDd+hh:mm:SS.sss where DD=days, hh=hours, mm=minutes, SS=sec, and sss=millisec. It "wraps" after 49.710 days. Error 3 [2] occurred at disk power-on lifetime: 26110 hours (1087 days + 22 hours) When the command that caused the error occurred, the device was active or idle. After command completion occurred, registers were: ER -- ST COUNT LBA_48 LH LM LL DV DC -- -- -- == -- == == == -- -- -- -- -- 40 -- 53 00 00 00 01 a6 af e9 90 00 00 Error: UNC at LBA = 0x1a6afe990 = 7091513744 Commands leading to the command that caused the error were: CR FEATR COUNT LBA_48 LH LM LL DV DC Powered_Up_Time Command/Feature_Name -- == -- == -- == == == -- -- -- -- -- --------------- -------------------- 60 00 00 00 40 00 01 a6 b8 0c b8 40 00 7d+05:43:42.882 READ FPDMA QUEUED 60 00 00 01 00 00 01 a6 af e7 00 40 00 7d+05:43:42.869 READ FPDMA QUEUED 60 00 00 01 00 00 01 a6 af e6 00 40 00 7d+05:43:42.869 READ FPDMA QUEUED 60 00 00 01 00 00 01 a6 af e5 00 40 00 7d+05:43:42.826 READ FPDMA QUEUED 60 00 00 01 00 00 01 a6 af e4 00 40 00 7d+05:43:42.826 READ FPDMA QUEUED Error 2 [1] occurred at disk power-on lifetime: 26109 hours (1087 days + 21 hours) When the command that caused the error occurred, the device was active or idle. After command completion occurred, registers were: ER -- ST COUNT LBA_48 LH LM LL DV DC -- -- -- == -- == == == -- -- -- -- -- 40 -- 53 00 00 00 01 a6 31 cd f8 00 00 Error: UNC at LBA = 0x1a631cdf8 = 7083249144 Commands leading to the command that caused the error were: CR FEATR COUNT LBA_48 LH LM LL DV DC Powered_Up_Time Command/Feature_Name -- == -- == -- == == == -- -- -- -- -- --------------- -------------------- 60 00 00 00 48 00 01 a6 34 b0 00 40 00 7d+05:32:50.394 READ FPDMA QUEUED 60 00 00 01 00 00 01 a6 31 cd c8 40 00 7d+05:32:48.221 READ FPDMA QUEUED 60 00 00 01 00 00 01 a6 31 cc c8 40 00 7d+05:32:48.220 READ FPDMA QUEUED 60 00 00 01 00 00 01 a6 31 cb c8 40 00 7d+05:32:48.220 READ FPDMA QUEUED 60 00 00 01 00 00 01 a6 31 c6 c8 40 00 7d+05:32:43.455 READ FPDMA QUEUED Error 1 [0] occurred at disk power-on lifetime: 26109 hours (1087 days + 21 hours) When the command that caused the error occurred, the device was active or idle. After command completion occurred, registers were: ER -- ST COUNT LBA_48 LH LM LL DV DC -- -- -- == -- == == == -- -- -- -- -- 40 -- 53 00 00 00 01 a6 15 f0 78 00 00 Error: UNC at LBA = 0x1a615f078 = 7081422968 Commands leading to the command that caused the error were: CR FEATR COUNT LBA_48 LH LM LL DV DC Powered_Up_Time Command/Feature_Name -- == -- == -- == == == -- -- -- -- -- --------------- -------------------- 60 00 00 01 00 00 01 a6 15 f0 90 40 00 7d+05:30:19.105 READ FPDMA QUEUED 60 00 00 01 00 00 01 a6 15 ee 90 40 00 7d+05:30:12.241 READ FPDMA QUEUED 60 00 00 01 00 00 01 a6 15 ed 90 40 00 7d+05:30:12.241 READ FPDMA QUEUED 60 00 00 01 00 00 01 a6 15 ec 90 40 00 7d+05:30:12.241 READ FPDMA QUEUED 60 00 00 01 00 00 01 a6 15 eb 90 40 00 7d+05:30:12.240 READ FPDMA QUEUED SMART Extended Self-test Log Version: 1 (1 sectors) Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error # 1 Extended offline Completed: read failure 90% 26413 6789119224 # 2 Extended offline Completed: read failure 10% 26412 7679130568 SMART Selective self-test log data structure revision number 1 SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS 1 0 0 Not_testing 2 0 0 Not_testing 3 0 0 Not_testing 4 0 0 Not_testing 5 0 0 Not_testing Selective self-test flags (0x0): After scanning selected spans, do NOT read-scan remainder of disk. If Selective self-test is pending on power-up, resume after 0 minute delay. SCT Status Version: 3 SCT Version (vendor specific): 522 (0x020a) Device State: Active (0) Current Temperature: 34 Celsius Power Cycle Min/Max Temperature: 28/41 Celsius Lifetime Min/Max Temperature: 17/61 Celsius Under/Over Temperature Limit Count: 0/303 SCT Temperature History Version: 2 Temperature Sampling Period: 3 minutes Temperature Logging Interval: 59 minutes Min/Max recommended Temperature: 0/ 0 Celsius Min/Max Temperature Limit: 0/ 0 Celsius Temperature History Size (Index): 128 (11) Index Estimated Time Temperature Celsius 12 2021-08-04 00:05 34 *************** 13 2021-08-04 01:04 35 **************** ... ..( 6 skipped). .. **************** 20 2021-08-04 07:57 35 **************** 21 2021-08-04 08:56 34 *************** 22 2021-08-04 09:55 35 **************** 23 2021-08-04 10:54 36 ***************** 24 2021-08-04 11:53 36 ***************** 25 2021-08-04 12:52 37 ****************** ... ..( 2 skipped). .. ****************** 28 2021-08-04 15:49 37 ****************** 29 2021-08-04 16:48 36 ***************** 30 2021-08-04 17:47 36 ***************** 31 2021-08-04 18:46 37 ****************** ... ..( 2 skipped). .. ****************** 34 2021-08-04 21:43 37 ****************** 35 2021-08-04 22:42 36 ***************** 36 2021-08-04 23:41 36 ***************** 37 2021-08-05 00:40 36 ***************** 38 2021-08-05 01:39 35 **************** ... ..( 6 skipped). .. **************** 45 2021-08-05 08:32 35 **************** 46 2021-08-05 09:31 36 ***************** 47 2021-08-05 10:30 37 ****************** 48 2021-08-05 11:29 37 ****************** 49 2021-08-05 12:28 38 ******************* 50 2021-08-05 13:27 38 ******************* 51 2021-08-05 14:26 37 ****************** ... ..( 7 skipped). .. ****************** 59 2021-08-05 22:18 37 ****************** 60 2021-08-05 23:17 36 ***************** ... ..( 2 skipped). .. ***************** 63 2021-08-06 02:14 36 ***************** 64 2021-08-06 03:13 35 **************** ... ..( 4 skipped). .. **************** 69 2021-08-06 08:08 35 **************** 70 2021-08-06 09:07 36 ***************** 71 2021-08-06 10:06 36 ***************** 72 2021-08-06 11:05 37 ****************** ... ..( 3 skipped). .. ****************** 76 2021-08-06 15:01 37 ****************** 77 2021-08-06 16:00 36 ***************** ... ..( 7 skipped). .. ***************** 85 2021-08-06 23:52 36 ***************** 86 2021-08-07 00:51 35 **************** ... ..( 19 skipped). .. **************** 106 2021-08-07 20:31 35 **************** 107 2021-08-07 21:30 34 *************** ... ..( 7 skipped). .. *************** 115 2021-08-08 05:22 34 *************** 116 2021-08-08 06:21 33 ************** 117 2021-08-08 07:20 34 *************** 118 2021-08-08 08:19 34 *************** 119 2021-08-08 09:18 34 *************** 120 2021-08-08 10:17 35 **************** 121 2021-08-08 11:16 36 ***************** ... ..( 5 skipped). .. ***************** 127 2021-08-08 17:10 36 ***************** 0 2021-08-08 18:09 35 **************** 1 2021-08-08 19:08 35 **************** 2 2021-08-08 20:07 34 *************** 3 2021-08-08 21:06 33 ************** ... ..( 2 skipped). .. ************** 6 2021-08-09 00:03 33 ************** 7 2021-08-09 01:02 34 *************** 8 2021-08-09 02:01 33 ************** ... ..( 2 skipped). .. ************** 11 2021-08-09 04:58 33 ************** SCT Error Recovery Control: Read: 70 (7.0 seconds) Write: 70 (7.0 seconds) Device Statistics (GP Log 0x04) Page Offset Size Value Flags Description 0x01 ===== = = === == General Statistics (rev 1) == 0x01 0x008 4 714 --- Lifetime Power-On Resets 0x01 0x010 4 27089 --- Power-on Hours 0x01 0x018 6 79739553748 --- Logical Sectors Written 0x01 0x020 6 173194182 --- Number of Write Commands 0x01 0x028 6 308767615482 --- Logical Sectors Read 0x01 0x030 6 1419898676 --- Number of Read Commands 0x01 0x038 6 - --- Date and Time TimeStamp 0x03 ===== = = === == Rotating Media Statistics (rev 1) == 0x03 0x008 4 3771289598 N-- Spindle Motor Power-on Hours 0x03 0x010 4 3771273568 N-- Head Flying Hours 0x03 0x018 4 20204 --- Head Load Events 0x03 0x020 4 616 --- Number of Reallocated Logical Sectors 0x03 0x028 4 0 --- Read Recovery Attempts 0x03 0x030 4 0 --- Number of Mechanical Start Failures 0x03 0x038 4 8 --- Number of Realloc. Candidate Logical Sectors 0x03 0x040 4 2607 --- Number of High Priority Unload Events 0x04 ===== = = === == General Errors Statistics (rev 1) == 0x04 0x008 4 0 --- Number of Reported Uncorrectable Errors 0x04 0x010 4 2 --- Resets Between Cmd Acceptance and Completion 0x05 ===== = = === == Temperature Statistics (rev 1) == 0x05 0x008 1 34 --- Current Temperature 0x05 0x010 1 34 --- Average Short Term Temperature 0x05 0x018 1 34 --- Average Long Term Temperature 0x05 0x020 1 61 --- Highest Temperature 0x05 0x028 1 0 --- Lowest Temperature 0x05 0x030 1 52 --- Highest Average Short Term Temperature 0x05 0x038 1 25 --- Lowest Average Short Term Temperature 0x05 0x040 1 42 --- Highest Average Long Term Temperature 0x05 0x048 1 26 --- Lowest Average Long Term Temperature 0x05 0x050 4 0 --- Time in Over-Temperature 0x05 0x058 1 70 --- Specified Maximum Operating Temperature 0x05 0x060 4 0 --- Time in Under-Temperature 0x05 0x068 1 0 --- Specified Minimum Operating Temperature 0x06 ===== = = === == Transport Statistics (rev 1) == 0x06 0x008 4 2226 --- Number of Hardware Resets 0x06 0x010 4 654 --- Number of ASR Events 0x06 0x018 4 0 --- Number of Interface CRC Errors |||_ C monitored condition met ||__ D supports DSN |___ N normalized value Pending Defects log (GP Log 0x0c) not supported SATA Phy Event Counters (GP Log 0x11) ID Size Value Description 0x000a 2 15 Device-to-host register FISes sent due to a COMRESET 0x0001 2 0 Command failed due to ICRC error 0x0003 2 0 R_ERR response for device-to-host data FIS 0x0004 2 0 R_ERR response for host-to-device data FIS 0x0006 2 0 R_ERR response for device-to-host non-data FIS 0x0007 2 0 R_ERR response for host-to-device non-data FIS Edited August 9, 2021 by Meltx103
Carlo 4561 Posted August 9, 2021 Posted August 9, 2021 What I can tell you from my own experience is once drives start having sectors moved because the disc is going bad it's just a matter of time. I personally would move the data off this disc to other drives. At that point, depending on need, maybe use the drive in a USB enclosure and use it for backup. Fill it and then take it offline. The drive shouldn't get any worse than it already is if stored. This is not the best advise for backup (using a semi-bad drive) but if you don't have a backup at all then it's better than nothing and at least gives you some use of the drive. Again I'd only do this if you don't already have a good backup or want a 2nd backup.
rbjtech 5341 Posted August 16, 2021 Posted August 16, 2021 (edited) The only advice I can give mirrors @cayars - get the data off that drive ASAP. The other free advice I can give you is for future purchases, stay clear of SEAGATE disks full stop. I've been in the IT industry for many many years, and in all that time, the only disk failures I have seen is from Seagate disks. My last 2Gb seagate ST 'Barracuda' drive failed about a month ago and tbh I'm glad it did, as I'm glad to get shot of it as it was a ticking time bomb. It was only used as a backup drive, as I knew it was unreliable. It's now in the bin as the bad sectors started creeping up, the exact same pattern as all the other Seagate drives I purchased over the years (and are now all dead). I have Toshiba, WD, Samsung and Hitachi disks that have zero bad sectors after spinning for literally 6+ years non stop, so I have treated the Seagate no differently, they just 'degrade' after time. I'm sure others will disagree - but if you want reliable long term data, my advice is to stay well clear of SEAGATE .. Edited August 16, 2021 by rbjtech
