wazegermany 0 Posted August 8, 2021 Posted August 8, 2021 Hi - I have problems with Kamera-Upload Function - I have emby running on Portainer.io I want to upload from iphoneX to smb-share. ------------------------------------------------------------------------------------------------- I found that when I create a folder "iPhone_<name>/Camara Roll", the files load neatly into the folder. But - you can't open it. (they have 0KB) Error-Log is in the attatchment embyserver.txt
wazegermany 0 Posted August 8, 2021 Author Posted August 8, 2021 Fotos kann die Datei leider nicht öffnen,weil das Format leider nicht unterstützt wird oder die Datei beschädigt ist. Unfortunately, Photos cannot open the file because the format is not supported or the file is damaged.
wazegermany 0 Posted August 10, 2021 Author Posted August 10, 2021 (edited) Solved this - Permission Problems in Portainer.io Edited August 10, 2021 by wazegermany
Luke 42246 Posted August 11, 2021 Posted August 11, 2021 18 hours ago, wazegermany said: Solved this - Permission Problems in Portainer.io Thanks for the feedback !
