serpi 82 Posted August 8, 2021 Posted August 8, 2021 Hi, in the Tizen app the light themes (including AppleTV) are pretty unusable. The problem exists in the latest 1.1.0 version and is there for already some versions. The problem is, if you enter detail screen or open the "logout/exit" menu, you get black font on darkened background, which is unreadable. It seems to only work right on the home screen, where you have black font on lightened background (which looks good). Could this please be checked? Thanks & Ciao, Alfred 1
serpi 82 Posted September 9, 2021 Author Posted September 9, 2021 Still not changed in version 1.1.2.
Luke 42241 Posted September 9, 2021 Posted September 9, 2021 Can you show a screenshot of what you see? Thanks.
serpi 82 Posted September 11, 2021 Author Posted September 11, 2021 (edited) OK, so here is the home screen in the light theme: You can see black font on lightened background, everything looks fine. Now entering a next up episode: Black font on darkened background btw, same background as in the picture before), unreadable. Same problem when pressing back on home screen, the lightened background gets darkened (?!), button font is unreadable (maybe here it should be darkened, but the font for the buttons should be white): Something different, here is a series library in the light theme: Everything looks fine, but when entering an series: Back to darkened background. And now, when entering a next up episode from here: It displays white font on darkened background, which would be normaly found on the dark themes. As you can see, most of the time the light themes are pretty unusable, some versions ago also the buttons where broken, but at least this has been fixed. BTW: Theres also a problem with long episode titles in the episodes detail screen, that these are writing above the logo at the right, but I think, I have seen this already mentioned before (here you can see it in the second picture). Ciao, Alfred Edited September 11, 2021 by serpi
FrostByte 5453 Posted September 11, 2021 Posted September 11, 2021 No, mine doesn't switch between dark and light font colors like that. This is with "Light" theme, on serpi's pic the fonts turned dark in the same spot.
serpi 82 Posted September 12, 2021 Author Posted September 12, 2021 17 hours ago, FrostByte said: No, mine doesn't switch between dark and light font colors like that. This is with "Light" theme, on serpi's pic the fonts turned dark in the same spot. But shouldn't this be black font on lightened background like on the homescreen or series on light themes?
Luke 42241 Posted September 12, 2021 Posted September 12, 2021 No the detail screen does it's own thing to put emphasis on the background image.
serpi 82 Posted October 31, 2021 Author Posted October 31, 2021 Light themes are still broken with version 1.1.6. Sometimes it works (white font), sometimes it doesn't (block font), just after reentering the same item. Dark themes always work. Ciao, Alfred
Luke 42241 Posted October 31, 2021 Posted October 31, 2021 Hi, yes sorry, I just haven't been able to reproduce on my Tizen TV's. @FrostByte can you try again? Thanks.
FrostByte 5453 Posted October 31, 2021 Posted October 31, 2021 (edited) Yes, I think I finally made it happen. I had to literally go in and out of seasons and episodes for about 20 minutes before I finally saw it. This is using the Light theme Then if I went out and back a couple more times it reverted back to normal Edited October 31, 2021 by FrostByte
Luke 42241 Posted October 31, 2021 Posted October 31, 2021 That's interesting, thanks for the info. 1
Luke 42241 Posted March 27, 2022 Posted March 27, 2022 4 hours ago, serpi said: Still broken in 1.2.5. Strange. I'm unable to reproduce.
serpi 82 Posted March 28, 2022 Author Posted March 28, 2022 20 hours ago, Luke said: Strange. I'm unable to reproduce. Home Screen, entering first Next Up object - looks good. Going back, re-enter same object - looks bad. It's a 50:50 if it works or not. 1
Luke 42241 Posted March 28, 2022 Posted March 28, 2022 1 hour ago, serpi said: Home Screen, entering first Next Up object - looks good. Going back, re-enter same object - looks bad. It's a 50:50 if it works or not. OK thanks for the info.
serpi 82 Posted May 24, 2022 Author Posted May 24, 2022 Thanks, it seems to be fixed in 1.2.8 (I also like the seperated color select). One small problem remains: With light theme, the audio/subtitle selection on detail screen is white on white, only readable when selected. Ciao, Alfred 1
Luke 42241 Posted May 25, 2022 Posted May 25, 2022 22 hours ago, serpi said: Thanks, it seems to be fixed in 1.2.8 (I also like the seperated color select). One small problem remains: With light theme, the audio/subtitle selection on detail screen is white on white, only readable when selected. Ciao, Alfred Thanks, we'll take a look.
