NSGMajor 1 Posted August 8, 2021 Posted August 8, 2021 (edited) Hello Guys, I am using Emby on my Synology 920+ for quite some time now and had no issues. But unfortunately since a few weeks I get overall performance issues with Emby, especially when I want to watch a movie which requires transcoding. After a lot of troubleshooting I may have found the issue. FFmpeg process which is performing the task of transcoding is only using 25% of max CPU usage. This issue is not related to upgrading from DSM 6.2.4 to DSM 7.0. It happened on both system versions. I also have another Synology 920+ with the exact same configuration and on this Emby works as expected and ffmpeg hits close to 80%-90% of CPU usage. I could find no differences between those to either in Synology settings or Emby settings. The only difference is that I am using Emby Premiere, while the other does not. It looks like the is some kind of limiter active for the transcoding process, but for the life of me I can't find any thing regarding this in my settings. Also my research in our World Wide Web came back empty. Does anyone have suggestion for me or maybe a solution for this problem? I am currently not able to use Emby at all since, transcoding does not work properly (too slow). Regards ffmpeg-transcode-de41db24-82d2-4c38-9ca0-ba5645fc3367_1.txt Edited August 8, 2021 by NSGMajor
Carlo 4561 Posted August 8, 2021 Posted August 8, 2021 Hi, try comparing the info on the transcoding menu between your two 920+ boxes. Set "Enable hardware acceleration when available:" to Advanced on both so you can see the selections made for hardware use. Let us know what you find.
NSGMajor 1 Posted August 15, 2021 Author Posted August 15, 2021 @Luke @cayars Sorry I was busy the last week and couldn't check until now. I switched both to advanced and both have exact same selection. The only difference is I am using DSM 7.0 while the other uses DSM 6.2.4, but that shouldn't make a real difference because I had the same issue on DSM 6.2.4 too. I played the same movie on both systems and on mine 25% ffmpeg max cpu, while at the other it is about 80-90% (see screenshots). I also attached both transcoding logs. I hope that you can help me out there, I am not that proficient with media encoding etc ffmpeg-transcode-bad.txt ffmpeg-transcode-good.txt
Carlo 4561 Posted August 15, 2021 Posted August 15, 2021 One transcode is using Hardware and the other is using Software which is why you see such a difference in CPU use. I would double check your transcode settings (set to advanced in first option) to look for differences between the two.
NSGMajor 1 Posted August 21, 2021 Author Posted August 21, 2021 I doubled checked them. They are exactly the same. Why is one using Hardware transcoding and the other software? Also the DSM920+ supports up to 4K hardware transcoding, shouldn't that be more performant than the software one?
Carlo 4561 Posted August 22, 2021 Posted August 22, 2021 There would likely have to be some difference between the two if the same media played back the same way on the same client produces different results with one NAS using hardware and the other using software. If you like I could do a remote session with you to look over both setups.
NSGMajor 1 Posted August 22, 2021 Author Posted August 22, 2021 Yeah I know there should be a difference. Either Im that stupid and blind or there is none. I set Transcoding => Enable Hardware acceleration to false on my system and now I get the same behaviour as the other. I checked logs to confirm it. It looks like while both have the same settings when hardware acceleration is enabled only my system (system1 named in screenshots) is respecting this setting. The other will still use software transcoding. It's strange. But shouldn't be hardware transcoding better than the software one?
Carlo 4561 Posted August 22, 2021 Posted August 22, 2021 Try moving the QuickSync to the top for each codec and see if this will use hardware transcoding. Yes using hardware should be better overall.
MateyTate 16 Posted August 25, 2021 Posted August 25, 2021 (edited) Having the same issue... or very similar only when I use a specific device it seems. When my son uses his Samsung TV, it says its direct playing, yet my DS916+ suddenly jumps to 25% CPU (+/- 2% every time) and then stays there - even when the TV is turned off it still sits at 25%. It then becomes unusable until I reboot the server, and then its fine again until he watches something. You can see in the images, I've stopped playing everything yet the usage is stuck at 25%. It will stay like that for hours until I reboot the server. Not sure if its the server or the app? I've attached logs as well. ffmpeg-directstream-550d2c77-1e6a-4b36-a41d-da946692fb80_1.txt embyserver.txt Edited August 25, 2021 by MateyTate
MateyTate 16 Posted August 25, 2021 Posted August 25, 2021 Just realised I am on the Beta so have posted this in the wrong section - sorry, my bad
Carlo 4561 Posted August 25, 2021 Posted August 25, 2021 Hi, Try turning on this option and see if it helps.
MateyTate 16 Posted August 25, 2021 Posted August 25, 2021 Didn’t do anything, just tried on my Shield as well. It seems as soon as I play anything, even Direct Play where it’s not transcoding, it ramps up the CPU up to 25% and will not go down. Even if I stop playing everything and quit all the clients. Do the logs show anything strange?
MateyTate 16 Posted August 25, 2021 Posted August 25, 2021 I just downgraded to the official release and it’s fine now. Something strange with the Beta. Anyway, you have the logs. Thanks.
Carlo 4561 Posted August 26, 2021 Posted August 26, 2021 Your server log is showing you were running Beta with debug logging turned on which will take more resources than normal and more IO as well. You can turn debug logging off unless asked to turn it on.
NSGMajor 1 Posted September 1, 2021 Author Posted September 1, 2021 @cayars Thank you for your suggestion. I tried it and it worked. Hardware transcoding is active and I have no issues while playing a movie that is in need for transcoding 1
