Kraszer 4 Posted August 7, 2021 Posted August 7, 2021 Can I batch change default audio and subtitles language for all episodes in series? If for example Spanish subtitles are default, but I want English subtitles on all episode in the series to be default, can I change that? The same goes with audio track. If I can't do that, It would be a really useful feature.
rodainas 191 Posted August 7, 2021 Posted August 7, 2021 You can select default audio and subtitle language at emby settings, this applies to all the libraries at the same time.
Kraszer 4 Posted August 8, 2021 Author Posted August 8, 2021 I see only ability to change default sound language, not subtitles. Changing it by TV series basis would be cool because I don't want to only one default language in all of my library.
rodainas 191 Posted August 8, 2021 Posted August 8, 2021 4 minutes ago, Kraszer said: I see only ability to change default sound language, not subtitles. Changing it by TV series basis would be cool because I don't want to only one default language in all of my library. Below Playback you have Subtitles on the emby client settings. There are some requests on the Feature Request forum for default language setting by Library and other to set a language by tv show to avoid changing it every time.
