mikeraburn 71 Posted August 7, 2021 Posted August 7, 2021 Cam back to civilization after a period and I did not expect a move from DSM6 to DSM7. That move is complete and water under bridge. I am committed to a fresh new Emby install. I have the latest DSM7 up and running at the latest EMBY installed. https://emby.media/synology7-server.html I am having issues getting Emby and the libraries seeing each other. I grabbed the instructions and believe I have followed them correctly x5 I need a little shove in the correct way for this. Nothing is indicating that the Movie library add is correct. The png of the library path for Movies as taken 5 minutes after library path created Thanks
FrostByte 5454 Posted August 7, 2021 Posted August 7, 2021 Did you accomplish the last step of the procedures to give Emby access to your shared folders? This has changed in DSM 7 and you need to use the system internal user now 2
FrostByte 5454 Posted August 7, 2021 Posted August 7, 2021 Here is a pic of my movie folder within Emby 2
mikeraburn 71 Posted August 7, 2021 Author Posted August 7, 2021 (edited) @FrostByte That was the PERFECT shove. I did NOT give the EMBY folder access in the System Internal User drop down as shown in your jpg. Thank YOU!!! Edited August 8, 2021 by mikeraburn 2
