Carlo 4561 Posted September 4, 2021 Posted September 4, 2021 All channels you get from TVE are part of a lineup that should be available via cable provider in your area. So you could setup the guide using Emby guide data and manually map your channels if needed. However when I've helped many users with TVE channel integration into Emby I've not noticed an issue with missing season/episode data. Are you using the XML file provided by Channels DVR for guide data presently?
Maisy 37 Posted September 6, 2021 Posted September 6, 2021 Yes I am using that XML from Channels DVR. I have used Python before to do other things in the past, but this current time, I didn't have Python installed so I got that working but the script to help with season and episode numbers is not working for me. I got rid of it (python3.8) for now. Frustrated with it. I have MCE Buddy pick up recordings to rename and h265 everything. It successfully renames a lot of this stuff, but I'm having to manually figure stuff out as well. Annoying. So about mapping I hadn't done that and I really need to I guess.
Maisy 37 Posted September 6, 2021 Posted September 6, 2021 I got some (the more important ones) of TVE channels remapped to ota and some to comcasts cable lineup. Much better. 1
