GrimReaper 4902 Posted August 5, 2021 Posted August 5, 2021 (edited) Did something change in how the Guide data is fetched from the server? Link to the issue here:  Edit: Disregard, found the issue: Android TV client defaulted to December 31, 2008 upon reboot while Offline. No wonder there's no Guide data.  Edited August 5, 2021 by GrimReaper76 Findings 1
ebr 16338 Posted August 5, 2021 Posted August 5, 2021 1 hour ago, GrimReaper76 said: Android TV client defaulted to December 31, 2008 upon reboot while Offline You mean the actual device date was set to that? The app doesn't do anything with dates.
Solution GrimReaper 4902 Posted August 5, 2021 Author Solution Posted August 5, 2021 Just now, ebr said: You mean the actual device date was set to that? The app doesn't do anything with dates. Yep, the device resets to 2008 upon every reboot as my travel router obviously does not propagate time so option "Use network time" is moot while offline, it needs to be manually adjusted upon every reboot. Nothing to do with Emby client app, this is all device-based.Â
