N0X 6 Posted August 11, 2021 Author Posted August 11, 2021 On 8/6/2021 at 1:56 PM, Luke said: Let's look at a specific example: Thanks. Same account playing in two different devices, in the account options it is set to be a single simultaneous reproduction, I have a premier subscription ... with some accounts it happens and with others not, all my accounts use the web
N0X 6 Posted August 11, 2021 Author Posted August 11, 2021 12 minutes ago, Luke said: Server log from that time? I do not have it ... as soon as it happens again I take all the data
Luke 42200 Posted August 11, 2021 Posted August 11, 2021 8 minutes ago, N0X said: I do not have it ... as soon as it happens again I take all the data Thanks.
N0X 6 Posted August 24, 2021 Author Posted August 24, 2021 On 8/11/2021 at 1:00 PM, Luke said: Thanks. embyserver.txt
Carlo 4561 Posted August 25, 2021 Posted August 25, 2021 @Luke I can reproduce this on 4.7.0.7 on two devices on my LAN. With 1 stream set for user. I can do this using a web player and ATV. I click play at the same time on both and they will play. If I start one then the other a couple of seconds later it will trip the stream count.
N0X 6 Posted August 25, 2021 Author Posted August 25, 2021 (edited) 17 hours ago, cayars said: @Luke I can reproduce this on 4.7.0.7 on two devices on my LAN. With 1 stream set for user. I can do this using a web player and ATV. I click play at the same time on both and they will play. If I start one then the other a couple of seconds later it will trip the stream count. there is something in the detection mechanism that is not working 100% ... is what i try to say from the start Edited August 25, 2021 by N0X
