z3ndra 7 Posted August 4, 2021 Posted August 4, 2021 Hello I encounter a recurring problem on the ps4, some content remains frozen or read badly (sound but without image, frozen image etc.) as if the server had trouble slicing the file. I am attaching you the log of a transcoding with a bug, if you would have a solution, because this problem already dates from version 3.4.1.0, and when going to version 4.6.4.0, the problem still exists Log : >> ThrottleBySegmentRequest: Initialize - TargetBufferSize: 120s 2021-08-04 10:39:10.165 Operating System: Linux version 4.19.62-mod-std-ipv6-64-rescue (kernel@kernel.ovh.net) (gcc version 6.3.0 20170516 (Debian 6.3.0-18+deb9u1)) #828825 SMP Tue Jul 30 13:5 OS/Process: x64/x64 Emby Server version: 4.6.4.0 Operating system: Unix 4.19.62.6 Command Line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb App: Emby Mobile 4.6.4.0 Sony PlayStation http://media.moovix.eu/emby/videos/33978/hls1/main/0.ts?DeviceId=TW96aWxsYS81LjAgKFBsYXlTdGF0aW9uIDQgNi43MSkgQXBwbGVXZWJLaXQvNjA1LjEuMTUgKEtIVE1MLCBsaWtlIEdlY2tvKXwxNTU5OTg2MzEzMjg3&MediaSourceId=90e7af3e900dc8987d6c576fca2078cf&PlaySessionId=3da09b7f1fb740d2a75a79832bb6c9f4&api_key=30403decab574872932982c2dac41884&VideoCodec=h264&AudioCodec=aac&VideoBitrate=3552000&AudioBitrate=448000&AudioStreamIndex=1&TranscodingMaxAudioChannels=6&SegmentContainer=ts&MinSegments=1&BreakOnNonKeyFrames=False&h264-profile=high,main,baseline,constrainedbaseline,high10&h264-level=52&TranscodeReasons=ContainerNotSupported#t=41.237 {"Protocol":"File","Id":"90e7af3e900dc8987d6c576fca2078cf","Path":"/home/desktop/Moovix/Movies/save 46/28 Jours Plus Tard 2002 Multi 1080p BluRay HDlight x264~Tonyk~-ZT-WwW Annuaire-Telechargement CoM/28 Jours Plus Tard 2002 Multi 1080p BluRay HDlight.x264~Tonyk~-ZT-WwW.Annuaire-Telechargement.CoM.mkv","Type":"Default","Container":"mkv","Size":2881017833,"Name":"28 Jours Plus Tard 2002 Multi 1080p BluRay HDlight.x264~Tonyk~-ZT-WwW.Annuaire-Telechargement.CoM","IsRemote":false,"RunTimeTicks":67876160000,"SupportsTranscoding":true,"SupportsDirectStream":true,"SupportsDirectPlay":true,"IsInfiniteStream":false,"RequiresOpening":false,"RequiresClosing":false,"RequiresLooping":false,"SupportsProbing":false,"MediaStreams":[{"Codec":"h264","Language":"eng","TimeBase":"1/1000","CodecTimeBase":"583/27956","VideoRange":"SDR","DisplayTitle":"1080p H264","DisplayLanguage":"English","NalLengthSize":"4","IsInterlaced":false,"IsAVC":true,"BitRate":3395616,"BitDepth":8,"RefFrames":1,"IsDefault":false,"IsForced":false,"Height":1080,"Width":1920,"AverageFrameRate":23.975986,"RealFrameRate":23.975986,"Profile":"High","Type":"Video","AspectRatio":"16:9","Index":0,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Protocol":"File","PixelFormat":"yuv420p","Level":41,"IsAnamorphic":false},{"Codec":"ac3","Language":"fre","TimeBase":"1/1000","CodecTimeBase":"1/48000","Title":"AC3-5.1-VFI","DisplayTitle":"French AC3 5.1 (Default)","DisplayLanguage":"French","IsInterlaced":false,"ChannelLayout":"5.1","BitRate":448000,"Channels":6,"SampleRate":48000,"IsDefault":true,"IsForced":false,"Type":"Audio","Index":1,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Protocol":"File"},{"Codec":"ac3","Language":"eng","TimeBase":"1/1000","CodecTimeBase":"1/48000","Title":"AC3-5.1-VO","DisplayTitle":"English AC3 5.1","DisplayLanguage":"English","IsInterlaced":false,"ChannelLayout":"5.1","BitRate":448000,"Channels":6,"SampleRate":48000,"IsDefault":false,"IsForced":false,"Type":"Audio","Index":2,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Protocol":"File"},{"Codec":"subrip","Language":"fre","TimeBase":"1/1000","CodecTimeBase":"0/1","Title":"forcé","DisplayTitle":"French (Default SUBRIP)","DisplayLanguage":"French","IsInterlaced":false,"IsDefault":true,"IsForced":false,"Type":"Subtitle","Index":3,"IsExternal":false,"IsTextSubtitleStream":true,"SupportsExternalStream":true,"Protocol":"File"},{"Codec":"subrip","Language":"fre","TimeBase":"1/1000","CodecTimeBase":"0/1","Title":"complet","DisplayTitle":"French (SUBRIP)","DisplayLanguage":"French","IsInterlaced":false,"IsDefault":false,"IsForced":false,"Type":"Subtitle","Index":4,"IsExternal":false,"IsTextSubtitleStream":true,"SupportsExternalStream":true,"Protocol":"File"},{"Codec":"subrip","Language":"eng","TimeBase":"1/1000","CodecTimeBase":"0/1","Title":"complet","DisplayTitle":"English (SUBRIP)","DisplayLanguage":"English","IsInterlaced":false,"IsDefault":false,"IsForced":false,"Type":"Subtitle","Index":5,"IsExternal":false,"IsTextSubtitleStream":true,"SupportsExternalStream":true,"Protocol":"File"},{"Codec":"subrip","Language":"spa","TimeBase":"1/1000","CodecTimeBase":"0/1","Title":"complet","DisplayTitle":"Spanish (SUBRIP)","DisplayLanguage":"Spanish","IsInterlaced":false,"IsDefault":false,"IsForced":false,"Type":"Subtitle","Index":6,"IsExternal":false,"IsTextSubtitleStream":true,"SupportsExternalStream":true,"Protocol":"File"}],"Formats":[],"Bitrate":3395616,"RequiredHttpHeaders":{},"ReadAtNativeFramerate":false} >>>>>> User policy for test EnablePlaybackRemuxing: True EnableVideoPlaybackTranscoding: True EnableAudioPlaybackTranscoding: True >>>>>> Processing Plan Info Name CanDoInHardware WillDoInHardware Reason Info Copy video stream >> False False Software Codec Info VideoInput >> False False Not a hardware decoder Info VideoOutput >> False False Not a hardware encoder Info Copy video stream >> False False Software Codec >>>>>> Projected Processing Formats Info Previous HW-Context Format SW-Format Size Next Info h264 >> - yuv420p yuv420p 1920x1080 >> /opt/emby-server/bin/ffmpeg -loglevel +timing -y -print_graphs_file "/var/lib/emby/logs/ffmpeg-remux-ba207dab-fe37-4189-8069-790fb14ca1c8_1graph.txt" -copyts -start_at_zero -f matroska,webm -c:v:0 h264 -i "/home/desktop/Moovix/Movies/save 46/28 Jours Plus Tard 2002 Multi 1080p BluRay HDlight x264~Tonyk~-ZT-WwW Annuaire-Telechargement CoM/28 Jours Plus Tard 2002 Multi 1080p BluRay HDlight.x264~Tonyk~-ZT-WwW.Annuaire-Telechargement.CoM.mkv" -map 0:0 -map 0:1 -sn -c:v:0 copy -bsf:v:0 h264_mp4toannexb -c:a:0 aac -ab:a:0 384000 -ac:a:0 6 -metadata:s:a:0 language=fre -disposition:a:0 default -max_delay 5000000 -avoid_negative_ts disabled -f segment -map_metadata -1 -map_chapters -1 -segment_format mpegts -segment_list "/var/lib/emby/transcoding-temp/0A6ABE.m3u8" -segment_list_type m3u8 -segment_time 6 -segment_start_number 0 -individual_header_trailer 0 -write_header_trailer 0 -segment_write_temp 1 "/var/lib/emby/transcoding-temp/0A6ABE_%d.ts" 10:39:10.175 ffmpeg version 4.3.0-emby_2021_02_27 Copyright (c) 2000-2021 the FFmpeg developers and softworkz for Emby LLC 10:39:10.175 built with gcc 8.3.0 (crosstool-NG 1.24.0) 10:39:10.175 Execution Date: 2021-08-04 10:39:10 10:39:10.191 Input #0, matroska,webm, from '/home/desktop/Moovix/Movies/save 46/28 Jours Plus Tard 2002 Multi 1080p BluRay HDlight x264~Tonyk~-ZT-WwW Annuaire-Telechargement CoM/28 Jours Plus Tard 2002 Multi 1080p BluRay HDlight.x264~Tonyk~-ZT-WwW.Annuaire-Telechargement.CoM.mkv': 10:39:10.192 Metadata: 10:39:10.192 encoder : libebml v1.3.0 + libmatroska v1.4.1 10:39:10.192 creation_time : 2014-07-07T10:00:25.000000Z 10:39:10.192 Duration: 01:53:07.62, start: 0.078000, bitrate: 3395 kb/s 10:39:10.192 Stream #0:0(eng): Video: h264 (High), yuv420p(progressive), 1920x1080 [SAR 1:1 DAR 16:9], Level 41, 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc, Start-Time 0.083s 10:39:10.192 Metadata: 10:39:10.192 BPS : 2497440 10:39:10.192 BPS-eng : 2497440 10:39:10.192 DURATION : 01:53:07.583000000 10:39:10.192 DURATION-eng : 01:53:07.583000000 10:39:10.192 NUMBER_OF_FRAMES: 162739 10:39:10.192 NUMBER_OF_FRAMES-eng: 162739 10:39:10.192 NUMBER_OF_BYTES : 2118947996 10:39:10.192 NUMBER_OF_BYTES-eng: 2118947996 10:39:10.192 Stream #0:1(fre): Audio: ac3, 48000 Hz, 5.1(side), fltp, 448 kb/s, Start-Time 0.078s (default) 10:39:10.192 Metadata: 10:39:10.192 title : AC3-5.1-VFI 10:39:10.192 BPS : 448000 10:39:10.192 BPS-eng : 448000 10:39:10.192 DURATION : 01:53:07.616000000 10:39:10.192 DURATION-eng : 01:53:07.616000000 10:39:10.192 NUMBER_OF_FRAMES: 212113 10:39:10.192 NUMBER_OF_FRAMES-eng: 212113 10:39:10.192 NUMBER_OF_BYTES : 380106496 10:39:10.192 NUMBER_OF_BYTES-eng: 380106496 10:39:10.192 Stream #0:2(eng): Audio: ac3, 48000 Hz, 5.1(side), fltp, 448 kb/s, Start-Time 0.078s 10:39:10.192 Metadata: 10:39:10.192 title : AC3-5.1-VO 10:39:10.192 BPS : 448000 10:39:10.192 BPS-eng : 448000 10:39:10.192 DURATION : 01:53:07.613000000 10:39:10.192 DURATION-eng : 01:53:07.613000000 10:39:10.192 NUMBER_OF_FRAMES: 212113 10:39:10.192 NUMBER_OF_FRAMES-eng: 212113 10:39:10.192 NUMBER_OF_BYTES : 380106496 10:39:10.192 NUMBER_OF_BYTES-eng: 380106496 10:39:10.192 Stream #0:3(fre): Subtitle: subrip, Start-Time 0.078s (default) 10:39:10.192 Metadata: 10:39:10.192 title : forcé 10:39:10.192 BPS : 0 10:39:10.192 BPS-eng : 0 10:39:10.192 DURATION : 01:46:00.771000000 10:39:10.192 DURATION-eng : 01:46:00.771000000 10:39:10.192 NUMBER_OF_FRAMES: 11 10:39:10.192 NUMBER_OF_FRAMES-eng: 11 10:39:10.192 NUMBER_OF_BYTES : 458 10:39:10.192 NUMBER_OF_BYTES-eng: 458 10:39:10.192 Stream #0:4(fre): Subtitle: subrip, Start-Time 0.078s 10:39:10.192 Metadata: 10:39:10.192 title : complet 10:39:10.192 BPS : 25 10:39:10.192 BPS-eng : 25 10:39:10.192 DURATION : 01:51:25.447000000 10:39:10.192 DURATION-eng : 01:51:25.447000000 10:39:10.192 NUMBER_OF_FRAMES: 645 10:39:10.192 NUMBER_OF_FRAMES-eng: 645 10:39:10.192 NUMBER_OF_BYTES : 21329 10:39:10.192 NUMBER_OF_BYTES-eng: 21329 10:39:10.192 Stream #0:5(eng): Subtitle: subrip, Start-Time 0.078s 10:39:10.192 Metadata: 10:39:10.192 title : complet 10:39:10.192 BPS : 31 10:39:10.192 BPS-eng : 31 10:39:10.192 DURATION : 01:51:12.381000000 10:39:10.192 DURATION-eng : 01:51:12.381000000 10:39:10.192 NUMBER_OF_FRAMES: 860 10:39:10.192 NUMBER_OF_FRAMES-eng: 860 10:39:10.192 NUMBER_OF_BYTES : 26566 10:39:10.192 NUMBER_OF_BYTES-eng: 26566 10:39:10.192 Stream #0:6(spa): Subtitle: subrip, Start-Time 0.078s 10:39:10.192 Metadata: 10:39:10.192 title : complet 10:39:10.192 BPS : 34 10:39:10.192 BPS-eng : 34 10:39:10.192 DURATION : 01:46:20.353000000 10:39:10.192 DURATION-eng : 01:46:20.353000000 10:39:10.192 NUMBER_OF_FRAMES: 817 10:39:10.192 NUMBER_OF_FRAMES-eng: 817 10:39:10.192 NUMBER_OF_BYTES : 27478 10:39:10.192 NUMBER_OF_BYTES-eng: 27478 10:39:10.193 Stream mapping: 10:39:10.193 Stream #0:0 -> #0:0 (copy) 10:39:10.193 Stream #0:1 -> #0:1 (ac3 (native) -> aac (native)) 10:39:10.193 Press [q] to stop, [?] for help 10:39:10.196 Output #0, segment, to '/var/lib/emby/transcoding-temp/0A6ABE_%d.ts': 10:39:10.196 Metadata: 10:39:10.196 encoder : Lavf58.35.100 10:39:10.196 Stream #0:0: Video: h264 (High), yuv420p(progressive), 1920x1080 [SAR 1:1 DAR 16:9], q=2-31, Level 41, 23.98 fps, 23.98 tbr, 90k tbn, 23.98 tbc 10:39:10.196 Stream #0:1(fre): Audio: aac (LC), 48000 Hz, 5.1, fltp, 384 kb/s (default) 10:39:10.196 Metadata: 10:39:10.196 encoder : Lavc58.62.100 aac 10:39:10.695 frame= 135 fps=0.0 q=-1.0 size= 1843kB time=00:00:05.80 bitrate=N/A throttle=off speed= 0x 10:39:11.032 [segment @ 0x6baf00] Opening '/var/lib/emby/transcoding-temp/0A6ABE.m3u8.tmp' for writing 10:39:11.032 SegmentComplete=video:0 Index=0 Start=0.000000 End=11.975000 Duration=11.975000 offset_pts=0 start_pts=0 Frames=287 filename=0A6ABE_0.ts 10:39:11.032 [segment @ 0x6baf00] Opening '/var/lib/emby/transcoding-temp/0A6ABE_1.ts.tmp' for writing 10:39:11.197 frame= 354 fps=353 q=-1.0 size= 6290kB time=00:00:14.86 bitrate=5683.4kbits/s throttle=off speed=9.05x 10:39:11.585 [segment @ 0x6baf00] Opening '/var/lib/emby/transcoding-temp/0A6ABE.m3u8.tmp' for writing 10:39:11.602 SegmentComplete=video:0 Index=1 Start=11.975000 End=21.943000 Duration=9.968000 offset_pts=0 start_pts=11975000 Frames=239 filename=0A6ABE_1.ts 10:39:11.602 [segment @ 0x6baf00] Opening '/var/lib/emby/transcoding-temp/0A6ABE_2.ts.tmp' for writing 10:39:11.697 frame= 564 fps=375 q=-1.0 size= 9472kB time=00:00:23.50 bitrate=4382.2kbits/s throttle=off speed=11.8x >> ThrottleBySegmentRequest: Latest request position unknown 10:39:12.169 [segment @ 0x6baf00] Opening '/var/lib/emby/transcoding-temp/0A6ABE.m3u8.tmp' for writing 10:39:12.170 SegmentComplete=video:0 Index=2 Start=21.944000 End=31.911000 Duration=9.967000   Â
Luke 42237 Posted August 4, 2021 Posted August 4, 2021 Hi, is this the complete ffmpeg log? Please attach the emby server log file as well. thanks.
z3ndra 7 Posted August 8, 2021 Author Posted August 8, 2021 ffmpeg-remux-ba207dab-fe37-4189-8069-790fb14ca1c8_1.txt
Luke 42237 Posted August 9, 2021 Posted August 9, 2021 Can you please attach the main emby server log as well? Thanks.
