zBernie 16 Posted August 4, 2021 Posted August 4, 2021 I have numerous playlists, and all but one I can play using voice commands. I say "Alexa, open Emby home", then say "Play the playlist Bernie's Country Playlist". It does not work. I have about a dozen other playlists that do work using voice commands. I've tried renaming the playlist, rescanning, updating metadata, to no avail. Any idea why this one playlist does not play with voice commands?
Solution zBernie 16 Posted August 4, 2021 Author Solution Posted August 4, 2021 7 minutes ago, zBernie said: I have numerous playlists, and all but one I can play using voice commands. I say "Alexa, open Emby home", then say "Play the playlist Bernie's Country Playlist". It does not work. I have about a dozen other playlists that do work using voice commands. I've tried renaming the playlist, rescanning, updating metadata, to no avail. Any idea why this one playlist does not play with voice commands? Never mind, I renamed it to "My Country Playlist" and it works now.
Carlo 4561 Posted August 4, 2021 Posted August 4, 2021 Glad you got it figured out. Just guessing but maybe it was the apostrophe mark causing the issue. You could try renaming it "Bernies" without it just to see if that was the problem or not.
