GuinUK 1 Posted August 3, 2021 Posted August 3, 2021 (edited) Hi guys, I didn't realise Jellyfin was so close to emby in terms of, well everything, and was planning to install it as a lite version so it was easier for my mother-in-law to use on our main tv. My plan was to change the port number as it installed jellyfin, but sadly it autoed (I must have selected the wrong option when installing) and when it loaded it loaded up Emby. I tried to uninstall jellyfin and reinstall it when I realised I had autoed it but I still had the same error. When I realised it wasn't going to be an easy option to complete I decided to abandon the idea, uninstall jellyfin, but now when I try to launch emby I'm getting all sorts of weird things happening. I get the Emby logo, it calls itself Jellyfin and occasionally I see a members list of my emby server, but usually it is just a black screen. I also get a lock of flickering that suggests it is looking for things that are no longer there. My guess is I need to reinstall Emby server but I was hoping to find a way where I didn't have to re-impoort everything. I did a server back up not THAT long ago, and have the library.db from then but I have messed with it quite a lot since then so if there was a better way I thought I would ask, like I should have done initially. Thanks in advance for any help, Guin Edited August 3, 2021 by GuinUK
Abobader 3485 Posted August 3, 2021 Posted August 3, 2021 Hello GuinUK, ** This is an auto reply ** Please wait for someone from staff support or our members to reply to you. It's recommended to provide more info, as it explain in this thread: Thank you. Emby Team
GrimReaper 4861 Posted August 3, 2021 Posted August 3, 2021 (edited) 17 minutes ago, GuinUK said: I didn't realise Jellyfin was so close to emby in terms of, well everything Well, no surprise there considering it's a fork of Emby from some time ago. 17 minutes ago, GuinUK said: My plan was to change the port number as it installed jellyfin, but sadly it autoed (I must have selected the wrong option when installing) and when it loaded it loaded up Emby. What you should have done is simply shut down Emby instance before starting Jellyfin and then change its port number. 17 minutes ago, GuinUK said: When I realised it wasn't going to be an easy option to complete I decided to abandon the idea, uninstall jellyfin, but now when I try to launch emby I'm getting all sorts of weird things happening. Considering they are both self-contained instances they should not interfere with one another, might be your browser cache messing things up there - did you try clearing the cache? Rebooting the PC? Accessing Emby server instance from another browser? Edited August 3, 2021 by GrimReaper76 Typo 1
GuinUK 1 Posted August 3, 2021 Author Posted August 3, 2021 1 minute ago, GrimReaper76 said: Considering they are both self-contained instances they sprigs not interfere with one another, might be your browser cache messing things up there - did you try clearing the cache? Rebooting the PC? Accessing Emby server instance from another browser? I haven't done anything yet, having decided I ought to ask before breaking it further. I shall try these now. Cheers
GuinUK 1 Posted August 3, 2021 Author Posted August 3, 2021 7 minutes ago, GrimReaper76 said: might be your browser cache messing things up there - did you try clearing the cache This did the trick. Thanks! 7 minutes ago, GrimReaper76 said: What you should have done is simply shut down Emby instance before starting Jellyfin and then change its port number. I kind of did this but somehow it confused itself. I now presume this information was still in cache too. Thanks again bud, panic over, and a reminder I ought to back up my library again! 1
ebr 16309 Posted August 3, 2021 Posted August 3, 2021 5 hours ago, GuinUK said: so it was easier for my mother-in-law to use on our main tv Hi. Can we talk about what you were really trying to accomplish? What is making it hard for her on the TV? 1
speechles 2062 Posted August 3, 2021 Posted August 3, 2021 (edited) Indeed. How exactly was using other software that was similar going to accomplish your goal? Where exactly was there an issue? Can you give us clues where the other software was successful where this software was not? Why is it easier to use a competitors software than our own? We are very interested in how you came about that decision and what we can do to make it easier for you not to have to come to this decision. How can we help you? How can we help your mother? Without knowing we cannot offer assistance only apologies. Can you take the time to offer us some insight? Thanks. Edited August 3, 2021 by speechles 1
Luke 42201 Posted August 3, 2021 Posted August 3, 2021 Hi, regarding the web app, please try clearing browsing data and see if that helps. Thanks.
