VisNatiC 0 Posted August 2, 2021 Posted August 2, 2021 Hello, http://nas01:8096/ dosent start lsof -i -P -n | grep LISTEN dont see any Emby Server install the version from emby.media qnap page https://github.com/MediaBrowser/Emby.Releases/releases/download/4.6.4.0/emby-server-qnap_4.6.4.0_x86_64.qpkg can you help me? Thanks VisNatiC
gillmacca01 220 Posted August 2, 2021 Posted August 2, 2021 Someone will correct me if I'm wrong, but where you put nas01, you need to put your nas's IP address
VisNatiC 0 Posted August 2, 2021 Author Posted August 2, 2021 its the same problem hostname or ip Diese Seite funktioniert nicht 192.168.0.234 hat keine Daten gesendet. ERR_EMPTY_RESPONSE
gillmacca01 220 Posted August 2, 2021 Posted August 2, 2021 Have you tried going into the app center on the NAS, and opening Emby from there. It should open it in a browser tab
Luke 42240 Posted August 3, 2021 Posted August 3, 2021 5 hours ago, gillmacca01 said: Have you tried going into the app center on the NAS, and opening Emby from there. It should open it in a browser tab Hi, yes please try this and let us know if it helps. thanks.
VisNatiC 0 Posted August 3, 2021 Author Posted August 3, 2021 the webside dosend open it. i press on emby in appcenter an only the message is ERR_EMPTY_RESPONSE Emby 4.6.4.0 QTS 4.2.6 can i enby install with a sh script? or some fix tools? thanks
VisNatiC 0 Posted August 5, 2021 Author Posted August 5, 2021 /share/MD0_DATA/.qpkg/EmbyServer/system/EmbyServer: error while loading shared libraries: libdl.so.2: wrong ELF class: ELFCLASS32 can anybody help me?
Luke 42240 Posted August 14, 2021 Posted August 14, 2021 Hi, our packages do not support the older x86 32-bit QNAP models at this time, sorry.
