Desafino 0 Posted August 1, 2021 Posted August 1, 2021 Hello, Having "connection failure" screen when trying to add server. I have no prob login in via emby connect....But then my server is not listed & when trying to add it....What gives? Ive opened the port in windows firewall. No issues with the router. was able to connect via my iphone...but for whatever reason its not working on Apple TV 4k.
Luke 42241 Posted August 2, 2021 Posted August 2, 2021 Hi there, are you trying to connect to your own Emby Server, or someone else's?
Desafino 0 Posted August 2, 2021 Author Posted August 2, 2021 my own server. now the server is listed...but I get "we're unable to connect to the selected server right now". I've attached the logs... App was working fine on my Amazon Cube....Switched to Apple 4k Tv and shit went south... embyserver.txt
Luke 42241 Posted August 10, 2021 Posted August 10, 2021 @Desafino are you still running into this? Did you try adding the server into the app manually by entering the address?
Desafino 0 Posted August 10, 2021 Author Posted August 10, 2021 Hi Luke, It was an issue with my Huawei AX3 router. Swapped it out for my old ASUS router and the issue is resolved. It didn’t like being in bridge mode etc… thx and cheers!
Luke 42241 Posted August 11, 2021 Posted August 11, 2021 5 hours ago, Desafino said: Hi Luke, It was an issue with my Huawei AX3 router. Swapped it out for my old ASUS router and the issue is resolved. It didn’t like being in bridge mode etc… thx and cheers! Thanks for the feedback.
