Guest Speed3M0n521 Posted August 1, 2021 Posted August 1, 2021 After creating the mnt points for the TV Shows Location, all of the folders for the TV Series that i have has the same two pictures for all 108 Series folders. Can anyone help.
Luke 42237 Posted August 2, 2021 Posted August 2, 2021 Hi there, how are your TV shows named and organized? Have you taken a look at our TV naming guide? https://support.emby.media/support/solutions/articles/44001159110-tv-naming
Guest Speed3M0n521 Posted August 2, 2021 Posted August 2, 2021 TV naming order is: Parent Folder Season Number Folder Video File example... True Blood True Blood Season 1 True Blood 1X 1 True Blood 1X2 etc....
Luke 42237 Posted August 2, 2021 Posted August 2, 2021 13 minutes ago, Speed3M0n521 said: TV naming order is: Parent Folder Season Number Folder Video File example... True Blood True Blood Season 1 True Blood 1X 1 True Blood 1X2 etc.... Can you please provide exact file name examples? Thanks.
Guest Speed3M0n521 Posted August 2, 2021 Posted August 2, 2021 BABYLON 5 BABYLON 5 SEASON 1 BABYLON 5 1X2 SOUL HUNTER.MP4 Does that help any?
Happy2Play 9811 Posted August 2, 2021 Posted August 2, 2021 2 minutes ago, Speed3M0n521 said: BABYLON 5 BABYLON 5 SEASON 1 BABYLON 5 1X2 SOUL HUNTER.MP4 Does that help any? Not really as your images basically show another folder level taking over the entire library. Since the library points to /mnt we would need to start with the content of that folder.
Guest Speed3M0n521 Posted August 2, 2021 Posted August 2, 2021 folder structure is: /mnt/TV SERIES A-M/BABYLON 5/BABYLON 5 SEASON 1/BABYLON 5 1X2 SOUL HUNTER.mp4
Happy2Play 9811 Posted August 2, 2021 Posted August 2, 2021 Just now, Speed3M0n521 said: folder structure is: /mnt/TV SERIES A-M/BABYLON 5/BABYLON 5 SEASON 1/BABYLON 5 1X2 SOUL HUNTER.mp4 So the nested "TV Series A-M" is being recognized as a Series not a parent folder. Easiest fix should be assign each "/mnt/TV Series x-x" folder to the TV Shows Library.
Guest Speed3M0n521 Posted August 2, 2021 Posted August 2, 2021 So i have two folers for series....TV SERIES A-M and TV SERIES N-Z... You're saying that i need to delete that and add each folder seperately again?
Happy2Play 9811 Posted August 2, 2021 Posted August 2, 2021 (edited) 6 minutes ago, Speed3M0n521 said: So i have two folers for series....TV SERIES A-M and TV SERIES N-Z... You're saying that i need to delete that and add each folder seperately again? That would be the easiest way, both folder attached to one Library. Then Emby will not confuse the structure for a Series at parent level. But there may be content at that level causing the issue as Emby tries to figure out where the Series/Show level starts. Here is a generic example. As mentioned it shouldn't be required but Emby's content detection is getting confused on the correct series level. 4 minutes ago, Speed3M0n521 said: can both folders reside under /mnt? Yes Edited August 2, 2021 by Happy2Play
Guest Speed3M0n521 Posted August 2, 2021 Posted August 2, 2021 Thank you Happy2Play! That solved my problem.
Luke 42237 Posted August 3, 2021 Posted August 3, 2021 On 8/2/2021 at 12:40 AM, Speed3M0n521 said: Thank you Happy2Play! That solved my problem. Thanks for the feedback.
