Jammi3D 9 Posted August 1, 2021 Posted August 1, 2021 (edited) Hi, For the past week I've noticed Emby Theatre will only display 30 episodes in a Season folder. Take The Bill Series 18 for instance, there is 86 files in the folder and used to display correctly but now I can only see 30 episodes same for other shows with more than 30 episodes. This is only happening in Emby Theatre as all episodes show up in the web app and android app. For shows with unwatched episodes it does display the "Next Up" episodes incl higher episode numbers than 30. To test it is not my HTPC I've grabbed the zip files off github and ran on my PC along with setting up a new Library but have the same result. Any help would be appreciated cheers. Edited August 5, 2021 by Jammi3D
Carlo 4561 Posted August 1, 2021 Posted August 1, 2021 Hi your log is showing duplicate entries for Info App: Found duplicate path: G:\TV Shows 1\The Bill\Season 18 What folders do you have added to this library?
Happy2Play 9811 Posted August 1, 2021 Posted August 1, 2021 @Lukethis is reproducible. Season level appears to limited to 30 items but indicator on Season is correct, where the Series Next Up scroller will show all. Only tested Emby Theater 3.0.15 1
Carlo 4561 Posted August 1, 2021 Posted August 1, 2021 I'm seeing the same in Theater as well. Anger Management Season 2 shows 30 episodes while in Web shows 90+
Happy2Play 9811 Posted August 1, 2021 Posted August 1, 2021 Note this does not happen on store version 1.1.361.0. So in my tests if is only a Desktop issue. 1
Jammi3D 9 Posted August 1, 2021 Author Posted August 1, 2021 2 hours ago, cayars said: Hi your log is showing duplicate entries for Info App: Found duplicate path: G:\TV Shows 1\The Bill\Season 18 What folders do you have added to this library? That was a test library mate, it's been removed now. There are 4x drives in total added to the TV library TV Shows 1,2,3,4
Jammi3D 9 Posted August 1, 2021 Author Posted August 1, 2021 1 hour ago, Happy2Play said: Note this does not happen on store version 1.1.361.0. So in my tests if is only a Desktop issue. Correct mate, I'm using the desktop release and have tried the last 2 releases on github 1
Luke 42239 Posted August 2, 2021 Posted August 2, 2021 We'll take a look at it. Thanks for reporting.
Jammi3D 9 Posted August 5, 2021 Author Posted August 5, 2021 @Luke All seems to be fixed in the 4.7.0.5 Beta Server release mate, thank you for fixing quickly.
