Carlo 4561 Posted August 8, 2021 Posted August 8, 2021 Some providers have super large guides that can really hog up the space. @Luke is there any reason we need to hold on to this data after it's loaded (guide data that is)? Or maybe better asked, is there any reason to keep anything other than the latest download of the guide when XML?
normanmurcheson 7 Posted August 8, 2021 Author Posted August 8, 2021 I'm strictly using your Emby data, not the data from the IPTV service. Each xml file generated is in the neighbourhood of 160+ megabytes. It adds up very quickly. I did remove a number of the past ones and there was no ill effect.
Carlo 4561 Posted August 8, 2021 Posted August 8, 2021 OK that's good to know. Which folder did you delete these from?
normanmurcheson 7 Posted August 10, 2021 Author Posted August 10, 2021 (edited) @cayars from the cache/xmltv directory. I left the last two. All had the very same size. Edited August 10, 2021 by normanmurcheson 1
Luke 42237 Posted August 11, 2021 Posted August 11, 2021 That's safe to delete anytime you want. The server will also eventually delete them automatically as well
normanmurcheson 7 Posted August 12, 2021 Author Posted August 12, 2021 No actual issue with the xml files at this point. Emby does build a new xml file each time I edit anything to do with a channel. I am basically every once in a while deleting the extra xml files. How frequently does the server normally automatically delete the extra xml files?
Luke 42237 Posted August 14, 2021 Posted August 14, 2021 On 8/11/2021 at 8:05 PM, normanmurcheson said: No actual issue with the xml files at this point. Emby does build a new xml file each time I edit anything to do with a channel. I am basically every once in a while deleting the extra xml files. How frequently does the server normally automatically delete the extra xml files? Each day it clears out any files that are greater than 30 days old.
Carlo 4561 Posted August 14, 2021 Posted August 14, 2021 Is there any reason to keep them beyond 1 day if they've already been loaded?
normanmurcheson 7 Posted August 15, 2021 Author Posted August 15, 2021 @LukeI have to ask the very same question. All the xml files are identical in size. Is there any difference at all between them? In my case they are currently 179 megs each. That really eats disk space quickly. Thanks a lot.
