freeflight29 2 Posted August 1, 2021 Posted August 1, 2021 Hello, with this parameters below: <?xml version="1.0"?> <ServerConfiguration xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema"> <EnableDebugLevelLogging>false</EnableDebugLevelLogging> <EnableAutoUpdate>true</EnableAutoUpdate> <LogFileRetentionDays>3</LogFileRetentionDays> <RunAtStartup>true</RunAtStartup> <IsStartupWizardCompleted>true</IsStartupWizardCompleted> <EnableUPnP>true</EnableUPnP> <PublicPort>8096</PublicPort> <PublicHttpsPort>8920</PublicHttpsPort> <HttpServerPortNumber>8096</HttpServerPortNumber> <HttpsPortNumber>8920</HttpsPortNumber> <EnableHttps>true</EnableHttps> <CertificatePath>/volume1/home/USER/CERTNAME.pfx</CertificatePath> <CertificatePassword>MyPassword</CertificatePassword> <IsPortAuthorized>true</IsPortAuthorized> <AutoRunWebApp>true</AutoRunWebApp> <EnableRemoteAccess>true</EnableRemoteAccess> <LogAllQueryTimes>false</LogAllQueryTimes> <EnableCaseSensitiveItemIds>true</EnableCaseSensitiveItemIds> <PreferredMetadataLanguage>fr</PreferredMetadataLanguage> <MetadataCountryCode>FR</MetadataCountryCode> <SortRemoveWords> <string>the</string> <string>a</string> <string>an</string> <string>das</string> <string>der</string> <string>el</string> <string>la</string> </SortRemoveWords> <LibraryMonitorDelay>60</LibraryMonitorDelay> <EnableDashboardResponseCaching>true</EnableDashboardResponseCaching> <ImageSavingConvention>Compatible</ImageSavingConvention> <EnableAutomaticRestart>true</EnableAutomaticRestart> <CollectionOptionsMigrated>true</CollectionOptionsMigrated> <CollectionsMigratedToTags>true</CollectionsMigratedToTags> <CollectionFolderIdsMigrated>true</CollectionFolderIdsMigrated> <SaveMetadataHiddenMigrated>true</SaveMetadataHiddenMigrated> <WanDdns>DnsNameOfMyNAS</WanDdns> <UICulture>fr</UICulture> <SaveMetadataHidden>false</SaveMetadataHidden> <RemoteClientBitrateLimit>0</RemoteClientBitrateLimit> <DisplaySpecialsWithinSeasons>true</DisplaySpecialsWithinSeasons> <LocalNetworkSubnets /> <LocalNetworkAddresses /> <EnableExternalContentInSuggestions>true</EnableExternalContentInSuggestions> <RequireHttps>true</RequireHttps> <IsBehindProxy>false</IsBehindProxy> <RemoteIPFilter /> <IsRemoteIPFilterBlacklist>false</IsRemoteIPFilterBlacklist> <ImageExtractionTimeoutMs>0</ImageExtractionTimeoutMs> <PathSubstitutions /> <UninstalledPlugins /> <CollapseVideoFolders>true</CollapseVideoFolders> <EnableOriginalTrackTitles>false</EnableOriginalTrackTitles> <VacuumDatabaseOnStartup>false</VacuumDatabaseOnStartup> <SimultaneousStreamLimit>0</SimultaneousStreamLimit> <DatabaseCacheSizeMB>96</DatabaseCacheSizeMB> <EnableSqLiteMmio>false</EnableSqLiteMmio> <NextUpUpgraded>true</NextUpUpgraded> <ChannelOptionsUpgraded>true</ChannelOptionsUpgraded> <OptimizeDbOnShutdown>false</OptimizeDbOnShutdown> <DatabaseAnalysisLimit>400</DatabaseAnalysisLimit> </ServerConfiguration> how can i have this on the dashboard ? what i have miss ? Https not working. "Version 4.6.4.0 Le serveur Emby est à jour En cours d'exécution sur le port http 8096. Accès local (LAN) : http://LocalIPOfTheNAS:8096 Accès à distance (WAN) : http://DnsNameOfMyNAS:8096"
Luke 42237 Posted August 1, 2021 Posted August 1, 2021 Hi, please attach the emby server log. thanks.
freeflight29 2 Posted August 1, 2021 Author Posted August 1, 2021 hello luke, logs as request. thx embyserver.txt
Happy2Play 9811 Posted August 1, 2021 Posted August 1, 2021 Don't know the error but it is certificate related. 2021-08-01 03:25:20.503 Error App: Error loading cert from /volume1/home/Admin_LBO/embyMO.pfx *** Error Report *** Version: 4.6.4.0 Command line: /volume1/.@plugins/AppCentral/emby-server/system/EmbyServer.dll -programdata /home/emby -ffdetect /usr/local/AppCentral/emby-server/bin/ffdetect -ffmpeg /usr/local/AppCentral/emby-server/bin/ffmpeg -ffprobe /usr/local/AppCentral/emby-server/bin/ffprobe -updatepackage emby-server-asustor_{version}_x86-64.apk Operating system: Linux version 5.4.x (root@sw1-server) (gcc version 7.4.0 (crosstool-NG 1.24.0)) #1 SMP Sun Jul 4 20:42:42 CST 2021 Framework: .NET Core 3.1.13 OS/Process: x64/x64 Runtime: volume1/.@plugins/AppCentral/emby-server/system/System.Private.CoreLib.dll Processor count: 2 Data path: /home/emby Application path: /volume1/.@plugins/AppCentral/emby-server/system Interop+Crypto+OpenSslCryptographicException: Interop+Crypto+OpenSslCryptographicException: error:2006D002:BIO routines:BIO_new_file:system lib at Interop.Crypto.CheckValidOpenSslHandle(SafeHandle handle) at Internal.Cryptography.Pal.OpenSslX509CertificateReader.FromFile(String fileName, SafePasswordHandle password, X509KeyStorageFlags keyStorageFlags) at System.Security.Cryptography.X509Certificates.X509Certificate..ctor(String fileName, String password, X509KeyStorageFlags keyStorageFlags) at System.Security.Cryptography.X509Certificates.X509Certificate2..ctor(String fileName, String password) at Emby.Server.Implementations.ApplicationHost.GetCertificate(CertificateInfo info) Source: System.Security.Cryptography.X509Certificates TargetSite: Void CheckValidOpenSslHandle(System.Runtime.InteropServices.SafeHandle)
Luke 42237 Posted August 2, 2021 Posted August 2, 2021 HI, make sure the pfx certificate has 777 execute permissions. Please let us know if this helps. Thanks.
freeflight29 2 Posted August 5, 2021 Author Posted August 5, 2021 On 8/2/2021 at 5:25 AM, Luke said: HI, make sure the pfx certificate has 777 execute permissions. Please let us know if this helps. Thanks. hello luke, i still have the issue, with permissions 777 execute. regards embyserver.txt
Luke 42237 Posted August 5, 2021 Posted August 5, 2021 1 hour ago, freeflight29 said: hello luke, i still have the issue, with permissions 777 execute. regards embyserver.txt 70.18 kB · 0 downloads Please attach the log file from right after starting up the server. thanks.
freeflight29 2 Posted August 6, 2021 Author Posted August 6, 2021 hello luke, when i restarted the emby server i saw an error about the certificate in the log. "error:23076071:PKCS12 routines:PKCS12_parse:mac verify failure" i decided to regenerate the certificate, i use ssh and the root account, and i restart the server. Now everything is good. I thinkmy mistake was, i was using an another account that is member of "administrator group" , but i think there is a problem with the rights of this account to correctly generate the certificate, even if the account is member of "administrator group" Regards 1
