fallenwitch3r 45 Posted August 2, 2021 Author Posted August 2, 2021 (edited) Trying to watch live TV on a mobile browser on an android smartphone outside my local network. The channel named ONE HD The channel don't start playing. The Channel named ServusTv HD starts playing but the playback is stuttering because emby direkt streams the channel. The Channel Nitro SD starts to play but Beginns stuttering because emby direct streams the channel As you see emby don't transcode these channels If I want to watch some channels, with the emby for Android app, they're all get direct played by emby without transcoding. If I try to watch these channels with emby for Android TV, all channels playing nice and directly. If I want to watch these channels with a Webbrowser on pc or smartphone they won't start. It seems that some between emby and thv has a big problem. But I can't figure it out what's wrong. Maybe someone can upload some screenshots from a working tvh setup. Nitro SD ffmpeg-transcode-dc110922-770b-44b5-a946-5e8c698725a4_1.txt ONE HD ffmpeg-remux-51a7b4a2-77ca-4e9e-948a-237aab5f5cf9_1.txt ServusTv HD ffmpeg-transcode-f32ecd62-81ec-4af6-be52-cdde8cec69e6_1.txt Edited August 2, 2021 by fallenwitch3r
Carlo 4561 Posted August 2, 2021 Posted August 2, 2021 It's likely because you're running a low end Atom based system that really can't transcode that well and it's marginal at best keeping up with the stream. So you will want to use Emby Apps vs browser when ever possible to avoid having to transcode.
Solution pünktchen 1410 Posted August 2, 2021 Solution Posted August 2, 2021 24 minutes ago, fallenwitch3r said: The Channel named ServusTv HD starts playing but the playback is stuttering because emby direkt streams the channel. The Channel Nitro SD starts to play but Beginns stuttering because emby direct streams the channel As you see emby don't transcode these channels Your ffmpeg logs tell the opposite. Both channels where transcoded. ServusTV because of to high (estimated) bitrate. Nitro because of not supported video codec. Why don't you just lower the in-app bitrate or the server side maximum remote streaming bitrate? That will also force transcode your 720p channels and removes the stuttering that probably happens because of bandwidth limitations. @cayars it does transcode hw accelerated, so that shouldn't be a problem. 1
Carlo 4561 Posted August 3, 2021 Posted August 3, 2021 4 hours ago, pünktchen said: it does transcode hw accelerated, so that shouldn't be a problem. Yes your right, good catch.. I was looking at the actual transcode taking place watching the speed drop quickly down to speed=1.09 when playback was quit. But of course this is a real-time stream so that will happen (doh) as you can only process the stream as fast as you can retrieve it which is going to be 1.x speed.
fallenwitch3r 45 Posted August 3, 2021 Author Posted August 3, 2021 (edited) It runs before. 6-8 streames works fine. HD and SD but suddenly it stopped working. I don't know why and I think it's just a settings thing. The in App Bitrate is automatically. Local playing runs at the Android app I can't watch Webbrowser or mobile Webbrowser. Because even on mobile network emby tries to direct play or direct stream instead of transcoding play. Even when I lower the Bitrate all 720p channels plays directly. Edited August 3, 2021 by fallenwitch3r
fallenwitch3r 45 Posted August 3, 2021 Author Posted August 3, 2021 (edited) These are my settings from tvheadend Edited August 3, 2021 by fallenwitch3r
fallenwitch3r 45 Posted August 3, 2021 Author Posted August 3, 2021 And these are the emby settings for transcoding.
fallenwitch3r 45 Posted August 3, 2021 Author Posted August 3, 2021 2021-08-03 09:35:45.629 http: ::ffff:192.168.178.32: using auth xxxxxxxxxx for /tvheadend/stream/channelid/2047207402 2021-08-03 09:35:45.630 mpegts: 330MHz in VODAFONE - tuning on Silicon Labs Si2168 #3 : DVB-C #0 2021-08-03 09:35:45.630 subscription: 0024: "HTTP" subscribing on channel "Das Erste HD", weight: 100, adapter: "Silicon Labs Si2168 #3 : DVB-C #0", network: "VODAFONE", mux: "330MHz", provider: "ARD", service: "Das Erste HD", profile="pass", hostname="::ffff:192.168.178.32", username="xxxxxxxxxx", client="VLC/3.0.11" 2021-08-03 09:36:25.864 pass: Live stream: Write failed -- Die Ressource ist zur Zeit nicht verfügbar 2021-08-03 09:36:25.864 webui: Stop streaming /tvheadend/stream/channelid/2047207402?auth=xxxxxxxxxx&profile=pass, muxer reported errors 2021-08-03 09:36:25.864 subscription: 0024: "HTTP" unsubscribing from "Das Erste HD", hostname="::ffff:192.168.178.32", username="xxxxxxxxxx", client="VLC/3.0.11" 2021-08-03 09:36:36.088 http: ::ffff:192.168.178.32: using auth xxxxxxxxxx for /tvheadend/stream/channelid/2047207402 2021-08-03 09:36:36.092 mpegts: 330MHz in VODAFONE - tuning on Silicon Labs Si2168 #3 : DVB-C #0 2021-08-03 09:36:36.093 subscription: 0025: "HTTP" subscribing on channel "Das Erste HD", weight: 100, adapter: "Silicon Labs Si2168 #3 : DVB-C #0", network: "VODAFONE", mux: "330MHz", provider: "ARD", service: "Das Erste HD", profile="pass", hostname="::ffff:192.168.178.32", username="xxxxxxxxxx", client="VLC/3.0.11" 2021-08-03 09:37:13.082 subscription: 0025: "HTTP" unsubscribing from "Das Erste HD", hostname="::ffff:192.168.178.32", username="xxxxxxxxxx", client="VLC/3.0.11" 2021-08-03 09:38:44.302 htsp: Got connection from ::ffff:127.0.0.1 2021-08-03 09:38:44.304 htsp: ::ffff:127.0.0.1: Identified as user 'xxxxxxxxxx' (unverified) 2021-08-03 09:38:44.304 htsp: ::ffff:127.0.0.1 [ xxxxxxxxxx ]: Welcomed client software: TVHclient4xxxxxxxxxx-4.6.4.0 (HTSPv20) 2021-08-03 09:38:44.306 htsp: ::ffff:127.0.0.1 [ xxxxxxxxxx | TVHclient4xxxxxxxxxx-4.6.4.0 ]: Identified as user 'xxxxxxxxxx' 2021-08-03 09:38:44.306 htsp: ::ffff:127.0.0.1 [ xxxxxxxxxx | TVHclient4xxxxxxxxxx-4.6.4.0 ]: Privileges updated 2021-08-03 09:39:11.007 http: ::ffff:192.168.178.30: using auth xxxxxxxxxx for /tvheadend/stream/channelid/2047207402 2021-08-03 09:39:11.008 mpegts: 330MHz in VODAFONE - tuning on Silicon Labs Si2168 #3 : DVB-C #0 2021-08-03 09:39:11.008 subscription: 0026: "HTTP" subscribing on channel "Das Erste HD", weight: 100, adapter: "Silicon Labs Si2168 #3 : DVB-C #0", network: "VODAFONE", mux: "330MHz", provider: "ARD", service: "Das Erste HD", profile="pass", hostname="::ffff:192.168.178.30", username="xxxxxxxxxx", client="VLC/3.0.8 LibVLC/3.0.8" 2021-08-03 09:39:32.363 subscription: 0026: "HTTP" unsubscribing from "Das Erste HD", hostname="::ffff:192.168.178.30", username="xxxxxxxxxx", client="VLC/3.0.8 LibVLC/3.0.8" 2021-08-03 09:42:39.636 http: ::ffff:192.168.178.32: using auth xxxxxxxxxx for /tvheadend/stream/channelid/2047207402 2021-08-03 09:42:39.637 mpegts: 330MHz in VODAFONE - tuning on Silicon Labs Si2168 #3 : DVB-C #0 2021-08-03 09:42:39.637 subscription: 0027: "HTTP" subscribing on channel "Das Erste HD", weight: 100, adapter: "Silicon Labs Si2168 #3 : DVB-C #0", network: "VODAFONE", mux: "330MHz", provider: "ARD", service: "Das Erste HD", profile="vaapi", hostname="::ffff:192.168.178.32", username="xxxxxxxxxx", client="VLC/3.0.11" 2021-08-03 09:42:39.751 transcode: 0001: 01:H264: ==> Using profile vaapi 2021-08-03 09:42:39.751 transcode: 0001: 02:MPEG2AUDIO: ==> Copy 2021-08-03 09:42:39.751 transcode: 0001: 03:MPEG2AUDIO: ==> Copy 2021-08-03 09:42:39.751 transcode: 0001: 04:AC3: ==> Copy 2021-08-03 09:42:39.751 transcode: 0001: 06:DVBSUB: ==> Filtered out 2021-08-03 09:42:40.261 libav: AVHWDeviceContext: No VA display found for device: /dev/dri/renderD128. 2021-08-03 09:42:40.261 vaapi: failed to create a context for device: /dev/dri/renderD128 2021-08-03 09:42:40.313 libav: AVHWDeviceContext: No VA display found for device: /dev/dri/renderD128. 2021-08-03 09:42:40.313 vaapi: failed to create a context for device: /dev/dri/renderD128 2021-08-03 09:42:44.919 subscription: 0027: "HTTP" unsubscribing from "Das Erste HD", hostname="::ffff:192.168.178.32", username="xxxxxxxxxx", client="VLC/3.0.11" 2021-08-03 09:42:47.949 http: ::ffff:192.168.178.32: using auth xxxxxxxxxx for /tvheadend/stream/channelid/2047207402 2021-08-03 09:42:47.949 mpegts: 330MHz in VODAFONE - tuning on Silicon Labs Si2168 #3 : DVB-C #0 2021-08-03 09:42:47.949 subscription: 0028: "HTTP" subscribing on channel "Das Erste HD", weight: 100, adapter: "Silicon Labs Si2168 #3 : DVB-C #0", network: "VODAFONE", mux: "330MHz", provider: "ARD", service: "Das Erste HD", profile="vaapi", hostname="::ffff:192.168.178.32", username="xxxxxxxxxx", client="VLC/3.0.11" 2021-08-03 09:42:48.111 transcode: 0002: 01:H264: ==> Using profile vaapi 2021-08-03 09:42:48.111 transcode: 0002: 02:MPEG2AUDIO: ==> Copy 2021-08-03 09:42:48.111 transcode: 0002: 03:MPEG2AUDIO: ==> Copy 2021-08-03 09:42:48.111 transcode: 0002: 04:AC3: ==> Copy 2021-08-03 09:42:48.111 transcode: 0002: 06:DVBSUB: ==> Filtered out 2021-08-03 09:42:48.513 libav: AVHWDeviceContext: No VA display found for device: /dev/dri/renderD128. 2021-08-03 09:42:48.513 vaapi: failed to create a context for device: /dev/dri/renderD128 2021-08-03 09:42:48.553 libav: AVHWDeviceContext: No VA display found for device: /dev/dri/renderD128. 2021-08-03 09:42:48.553 vaapi: failed to create a context for device: /dev/dri/renderD128 2021-08-03 09:42:54.101 subscription: 0028: "HTTP" unsubscribing from "Das Erste HD", hostname="::ffff:192.168.178.32", username="xxxxxxxxxx", client="VLC/3.0.11" 2021-08-03 09:42:54.291 http: ::ffff:192.168.178.32: using auth xxxxxxxxxx for /tvheadend/stream/channelid/2047207402 2021-08-03 09:42:54.291 mpegts: 330MHz in VODAFONE - tuning on Silicon Labs Si2168 #3 : DVB-C #0 2021-08-03 09:42:54.291 subscription: 0029: "HTTP" subscribing on channel "Das Erste HD", weight: 100, adapter: "Silicon Labs Si2168 #3 : DVB-C #0", network: "VODAFONE", mux: "330MHz", provider: "ARD", service: "Das Erste HD", profile="vaapi", hostname="::ffff:192.168.178.32", username="xxxxxxxxxx", client="VLC/3.0.11" 2021-08-03 09:42:54.467 transcode: 0003: 01:H264: ==> Using profile vaapi 2021-08-03 09:42:54.467 transcode: 0003: 02:MPEG2AUDIO: ==> Copy 2021-08-03 09:42:54.467 transcode: 0003: 03:MPEG2AUDIO: ==> Copy 2021-08-03 09:42:54.467 transcode: 0003: 04:AC3: ==> Copy 2021-08-03 09:42:54.467 transcode: 0003: 06:DVBSUB: ==> Filtered out 2021-08-03 09:42:54.891 libav: AVHWDeviceContext: No VA display found for device: /dev/dri/renderD128. 2021-08-03 09:42:54.891 vaapi: failed to create a context for device: /dev/dri/renderD128 2021-08-03 09:42:54.926 libav: AVHWDeviceContext: No VA display found for device: /dev/dri/renderD128. 2021-08-03 09:42:54.926 vaapi: failed to create a context for device: /dev/dri/renderD128 2021-08-03 09:43:11.143 http: ::ffff:192.168.178.32: using auth xxxxxxxxxx for /tvheadend/stream/channelid/2047207402 2021-08-03 09:43:11.144 subscription: 002A: "HTTP" subscribing on channel "Das Erste HD", weight: 100, adapter: "Silicon Labs Si2168 #3 : DVB-C #0", network: "VODAFONE", mux: "330MHz", provider: "ARD", service: "Das Erste HD", profile="vaapi", hostname="::ffff:192.168.178.32", username="xxxxxxxxxx", client="VLC/3.0.11" 2021-08-03 09:43:13.741 subscription: 002A: "HTTP" unsubscribing from "Das Erste HD", hostname="::ffff:192.168.178.32", username="xxxxxxxxxx", client="VLC/3.0.11" 2021-08-03 09:43:58.448 subscription: 0029: "HTTP" unsubscribing from "Das Erste HD", hostname="::ffff:192.168.178.32", username="xxxxxxxxxx", client="VLC/3.0.11" 2021-08-03 09:44:24.731 http: ::ffff:192.168.178.32: using auth xxxxxxxxxx for /tvheadend/stream/channelid/2047207402 2021-08-03 09:44:24.731 mpegts: 330MHz in VODAFONE - tuning on Silicon Labs Si2168 #3 : DVB-C #0 2021-08-03 09:44:24.731 subscription: 002B: "HTTP" subscribing on channel "Das Erste HD", weight: 100, adapter: "Silicon Labs Si2168 #3 : DVB-C #0", network: "VODAFONE", mux: "330MHz", provider: "ARD", service: "Das Erste HD", profile="vaapi", hostname="::ffff:192.168.178.32", username="xxxxxxxxxx", client="VLC/3.0.11" 2021-08-03 09:44:24.842 transcode: 0004: 01:H264: ==> Using profile vaapi 2021-08-03 09:44:24.842 transcode: 0004: 02:MPEG2AUDIO: ==> Copy 2021-08-03 09:44:24.842 transcode: 0004: 03:MPEG2AUDIO: ==> Copy 2021-08-03 09:44:24.842 transcode: 0004: 04:AC3: ==> Copy 2021-08-03 09:44:24.842 transcode: 0004: 06:DVBSUB: ==> Filtered out 2021-08-03 09:44:25.115 libav: AVHWDeviceContext: No VA display found for device: /dev/dri/renderD128. 2021-08-03 09:44:25.115 vaapi: failed to create a context for device: /dev/dri/renderD128 2021-08-03 09:44:25.164 libav: AVHWDeviceContext: No VA display found for device: /dev/dri/renderD128. 2021-08-03 09:44:25.164 vaapi: failed to create a context for device: /dev/dri/renderD128 2021-08-03 09:44:30.050 subscription: 002B: "HTTP" unsubscribing from "Das Erste HD", hostname="::ffff:192.168.178.32", username="xxxxxxxxxx", client="VLC/3.0.11" 2021-08-03 09:44:30.689 http: ::ffff:192.168.178.32: using auth xxxxxxxxxx for /tvheadend/stream/channelid/2047207402 2021-08-03 09:44:30.689 mpegts: 330MHz in VODAFONE - tuning on Silicon Labs Si2168 #3 : DVB-C #0 2021-08-03 09:44:30.690 subscription: 002C: "HTTP" subscribing on channel "Das Erste HD", weight: 100, adapter: "Silicon Labs Si2168 #3 : DVB-C #0", network: "VODAFONE", mux: "330MHz", provider: "ARD", service: "Das Erste HD", profile="vaapi", hostname="::ffff:192.168.178.32", username="xxxxxxxxxx", client="VLC/3.0.11" 2021-08-03 09:44:30.866 transcode: 0005: 01:H264: ==> Using profile vaapi 2021-08-03 09:44:30.866 transcode: 0005: 02:MPEG2AUDIO: ==> Copy 2021-08-03 09:44:30.866 transcode: 0005: 03:MPEG2AUDIO: ==> Copy 2021-08-03 09:44:30.866 transcode: 0005: 04:AC3: ==> Copy 2021-08-03 09:44:30.866 transcode: 0005: 06:DVBSUB: ==> Filtered out 2021-08-03 09:44:31.411 libav: AVHWDeviceContext: No VA display found for device: /dev/dri/renderD128. 2021-08-03 09:44:31.412 vaapi: failed to create a context for device: /dev/dri/renderD128 2021-08-03 09:44:31.453 libav: AVHWDeviceContext: No VA display found for device: /dev/dri/renderD128. 2021-08-03 09:44:31.453 vaapi: failed to create a context for device: /dev/dri/renderD128 2021-08-03 09:44:37.090 http: ::ffff:192.168.178.32: using auth xxxxxxxxxx for /tvheadend/stream/channelid/2047207402 2021-08-03 09:44:37.091 subscription: 002D: "HTTP" subscribing on channel "Das Erste HD", weight: 100, adapter: "Silicon Labs Si2168 #3 : DVB-C #0", network: "VODAFONE", mux: "330MHz", provider: "ARD", service: "Das Erste HD", profile="vaapi", hostname="::ffff:192.168.178.32", username="xxxxxxxxxx", client="VLC/3.0.11" 2021-08-03 09:44:39.842 subscription: 002D: "HTTP" unsubscribing from "Das Erste HD", hostname="::ffff:192.168.178.32", username="xxxxxxxxxx", client="VLC/3.0.11" 2021-08-03 09:45:14.844 subscription: 002C: "HTTP" unsubscribing from "Das Erste HD", hostname="::ffff:192.168.178.32", username="xxxxxxxxxx", client="VLC/3.0.11" 2021-08-03 09:47:05.578 http: ::ffff:192.168.178.32: using auth xxxxxxxxxx for /tvheadend/stream/channelid/2047207402 2021-08-03 09:47:05.579 mpegts: 330MHz in VODAFONE - tuning on Silicon Labs Si2168 #3 : DVB-C #0 2021-08-03 09:47:05.579 subscription: 002E: "HTTP" subscribing on channel "Das Erste HD", weight: 100, adapter: "Silicon Labs Si2168 #3 : DVB-C #0", network: "VODAFONE", mux: "330MHz", provider: "ARD", service: "Das Erste HD", profile="vaapi", hostname="::ffff:192.168.178.32", username="xxxxxxxxxx", client="VLC/3.0.11" 2021-08-03 09:47:05.689 transcode: 0006: 01:H264: ==> Using profile vaapi 2021-08-03 09:47:05.689 transcode: 0006: 02:MPEG2AUDIO: ==> Copy 2021-08-03 09:47:05.689 transcode: 0006: 03:MPEG2AUDIO: ==> Copy 2021-08-03 09:47:05.690 transcode: 0006: 04:AC3: ==> Copy 2021-08-03 09:47:05.690 transcode: 0006: 06:DVBSUB: ==> Filtered out 2021-08-03 09:47:06.750 libav: AVHWDeviceContext: No VA display found for device: /dev/dri/renderD128. 2021-08-03 09:47:06.750 vaapi: failed to create a context for device: /dev/dri/renderD128 2021-08-03 09:47:06.795 libav: AVHWDeviceContext: No VA display found for device: /dev/dri/renderD128. 2021-08-03 09:47:06.795 vaapi: failed to create a context for device: /dev/dri/renderD128 2021-08-03 09:47:10.754 subscription: 002E: "HTTP" unsubscribing from "Das Erste HD", hostname="::ffff:192.168.178.32", username="xxxxxxxxxx", client="VLC/3.0.11" 2021-08-03 09:47:11.789 http: ::ffff:192.168.178.32: using auth xxxxxxxxxx for /tvheadend/stream/channelid/2047207402 2021-08-03 09:47:11.789 mpegts: 330MHz in VODAFONE - tuning on Silicon Labs Si2168 #3 : DVB-C #0 2021-08-03 09:47:11.789 subscription: 002F: "HTTP" subscribing on channel "Das Erste HD", weight: 100, adapter: "Silicon Labs Si2168 #3 : DVB-C #0", network: "VODAFONE", mux: "330MHz", provider: "ARD", service: "Das Erste HD", profile="vaapi", hostname="::ffff:192.168.178.32", username="xxxxxxxxxx", client="VLC/3.0.11" 2021-08-03 09:47:11.950 transcode: 0007: 01:H264: ==> Using profile vaapi 2021-08-03 09:47:11.950 transcode: 0007: 02:MPEG2AUDIO: ==> Copy 2021-08-03 09:47:11.950 transcode: 0007: 03:MPEG2AUDIO: ==> Copy 2021-08-03 09:47:11.950 transcode: 0007: 04:AC3: ==> Copy 2021-08-03 09:47:11.950 transcode: 0007: 06:DVBSUB: ==> Filtered out 2021-08-03 09:47:12.549 libav: AVHWDeviceContext: No VA display found for device: /dev/dri/renderD128. 2021-08-03 09:47:12.549 vaapi: failed to create a context for device: /dev/dri/renderD128 2021-08-03 09:47:12.588 libav: AVHWDeviceContext: No VA display found for device: /dev/dri/renderD128. 2021-08-03 09:47:12.588 vaapi: failed to create a context for device: /dev/dri/renderD128 2021-08-03 09:47:18.280 http: ::ffff:192.168.178.32: using auth xxxxxxxxxx for /tvheadend/stream/channelid/2047207402 2021-08-03 09:47:18.281 subscription: 0030: "HTTP" subscribing on channel "Das Erste HD", weight: 100, adapter: "Silicon Labs Si2168 #3 : DVB-C #0", network: "VODAFONE", mux: "330MHz", provider: "ARD", service: "Das Erste HD", profile="vaapi", hostname="::ffff:192.168.178.32", username="xxxxxxxxxx", client="VLC/3.0.11" 2021-08-03 09:47:20.941 subscription: 0030: "HTTP" unsubscribing from "Das Erste HD", hostname="::ffff:192.168.178.32", username="xxxxxxxxxx", client="VLC/3.0.11" 2021-08-03 09:47:52.934 subscription: 002F: "HTTP" unsubscribing from "Das Erste HD", hostname="::ffff:192.168.178.32", username="xxxxxxxxxx", client="VLC/3.0.11" 2021-08-03 09:48:55.303 http: ::ffff:192.168.178.32: using auth xxxxxxxxxx for /tvheadend/stream/channelid/2047207402 2021-08-03 09:48:55.303 mpegts: 330MHz in VODAFONE - tuning on Silicon Labs Si2168 #3 : DVB-C #0 2021-08-03 09:48:55.304 subscription: 0031: "HTTP" subscribing on channel "Das Erste HD", weight: 100, adapter: "Silicon Labs Si2168 #3 : DVB-C #0", network: "VODAFONE", mux: "330MHz", provider: "ARD", service: "Das Erste HD", profile="vaapi", hostname="::ffff:192.168.178.32", username="xxxxxxxxxx", client="VLC/3.0.11" 2021-08-03 09:48:55.465 transcode: 0008: 01:H264: ==> Using profile vaapi 2021-08-03 09:48:55.465 transcode: 0008: 02:MPEG2AUDIO: ==> Copy 2021-08-03 09:48:55.465 transcode: 0008: 03:MPEG2AUDIO: ==> Copy 2021-08-03 09:48:55.465 transcode: 0008: 04:AC3: ==> Copy 2021-08-03 09:48:55.465 transcode: 0008: 06:DVBSUB: ==> Filtered out 2021-08-03 09:48:55.692 libav: AVHWDeviceContext: No VA display found for device: /dev/dri/renderD128. 2021-08-03 09:48:55.692 vaapi: failed to create a context for device: /dev/dri/renderD128 2021-08-03 09:48:55.737 libav: AVHWDeviceContext: No VA display found for device: /dev/dri/renderD128. 2021-08-03 09:48:55.737 vaapi: failed to create a context for device: /dev/dri/renderD128 2021-08-03 09:49:00.701 subscription: 0031: "HTTP" unsubscribing from "Das Erste HD", hostname="::ffff:192.168.178.32", username="xxxxxxxxxx", client="VLC/3.0.11" 2021-08-03 09:49:01.251 http: ::ffff:192.168.178.32: using auth xxxxxxxxxx for /tvheadend/stream/channelid/2047207402 2021-08-03 09:49:01.251 mpegts: 330MHz in VODAFONE - tuning on Silicon Labs Si2168 #3 : DVB-C #0 2021-08-03 09:49:01.251 subscription: 0032: "HTTP" subscribing on channel "Das Erste HD", weight: 100, adapter: "Silicon Labs Si2168 #3 : DVB-C #0", network: "VODAFONE", mux: "330MHz", provider: "ARD", service: "Das Erste HD", profile="vaapi", hostname="::ffff:192.168.178.32", username="xxxxxxxxxx", client="VLC/3.0.11" 2021-08-03 09:49:01.420 transcode: 0009: 01:H264: ==> Using profile vaapi 2021-08-03 09:49:01.420 transcode: 0009: 02:MPEG2AUDIO: ==> Copy 2021-08-03 09:49:01.420 transcode: 0009: 03:MPEG2AUDIO: ==> Copy 2021-08-03 09:49:01.420 transcode: 0009: 04:AC3: ==> Copy 2021-08-03 09:49:01.420 transcode: 0009: 06:DVBSUB: ==> Filtered out 2021-08-03 09:49:02.162 libav: AVHWDeviceContext: No VA display found for device: /dev/dri/renderD128. 2021-08-03 09:49:02.162 vaapi: failed to create a context for device: /dev/dri/renderD128 2021-08-03 09:49:02.207 libav: AVHWDeviceContext: No VA display found for device: /dev/dri/renderD128. 2021-08-03 09:49:02.207 vaapi: failed to create a context for device: /dev/dri/renderD128 2021-08-03 09:49:16.279 http: ::ffff:192.168.178.32: using auth xxxxxxxxxx for /tvheadend/stream/channelid/2047207402 2021-08-03 09:49:16.280 subscription: 0033: "HTTP" subscribing on channel "Das Erste HD", weight: 100, adapter: "Silicon Labs Si2168 #3 : DVB-C #0", network: "VODAFONE", mux: "330MHz", provider: "ARD", service: "Das Erste HD", profile="vaapi", hostname="::ffff:192.168.178.32", username="xxxxxxxxxx", client="VLC/3.0.11" 2021-08-03 09:49:19.405 subscription: 0033: "HTTP" unsubscribing from "Das Erste HD", hostname="::ffff:192.168.178.32", username="xxxxxxxxxx", client="VLC/3.0.11" 2021-08-03 09:49:29.356 http: ::ffff:192.168.178.32: using auth xxxxxxxxxx for /tvheadend/stream/channelid/2047207402 2021-08-03 09:49:29.356 subscription: 0034: "HTTP" subscribing on channel "Das Erste HD", weight: 100, adapter: "Silicon Labs Si2168 #3 : DVB-C #0", network: "VODAFONE", mux: "330MHz", provider: "ARD", service: "Das Erste HD", profile="vaapi", hostname="::ffff:192.168.178.32", username="xxxxxxxxxx", client="VLC/3.0.11" 2021-08-03 09:49:29.405 subscription: 0032: "HTTP" unsubscribing from "Das Erste HD", hostname="::ffff:192.168.178.32", username="xxxxxxxxxx", client="VLC/3.0.11" 2021-08-03 09:49:33.652 http: ::ffff:192.168.178.32: using auth xxxxxxxxxx for /tvheadend/stream/channelid/2047207402 2021-08-03 09:49:33.652 subscription: 0035: "HTTP" subscribing on channel "Das Erste HD", weight: 100, adapter: "Silicon Labs Si2168 #3 : DVB-C #0", network: "VODAFONE", mux: "330MHz", provider: "ARD", service: "Das Erste HD", profile="vaapi", hostname="::ffff:192.168.178.32", username="xxxxxxxxxx", client="VLC/3.0.11" 2021-08-03 09:49:52.653 http: ::ffff:192.168.178.32: using auth xxxxxxxxxx for /tvheadend/stream/channelid/2047207402 2021-08-03 09:49:52.653 subscription: 0036: "HTTP" subscribing on channel "Das Erste HD", weight: 100, adapter: "Silicon Labs Si2168 #3 : DVB-C #0", network: "VODAFONE", mux: "330MHz", provider: "ARD", service: "Das Erste HD", profile="vaapi", hostname="::ffff:192.168.178.32", username="xxxxxxxxxx", client="VLC/3.0.11" 2021-08-03 09:50:04.620 http: ::ffff:192.168.178.32: using auth xxxxxxxxxx for /tvheadend/stream/channelid/2047207402 2021-08-03 09:50:04.621 subscription: 0037: "HTTP" subscribing on channel "Das Erste HD", weight: 100, adapter: "Silicon Labs Si2168 #3 : DVB-C #0", network: "VODAFONE", mux: "330MHz", provider: "ARD", service: "Das Erste HD", profile="vaapi", hostname="::ffff:192.168.178.32", username="xxxxxxxxxx", client="VLC/3.0.11" 2021-08-03 09:50:07.408 subscription: 0037: "HTTP" unsubscribing from "Das Erste HD", hostname="::ffff:192.168.178.32", username="xxxxxxxxxx", client="VLC/3.0.11" 2021-08-03 09:50:43.410 subscription: 0034: "HTTP" unsubscribing from "Das Erste HD", hostname="::ffff:192.168.178.32", username="xxxxxxxxxx", client="VLC/3.0.11" 2021-08-03 09:50:48.409 webui: Stop streaming /tvheadend/stream/channelid/2047207402?auth=xxxxxxxxxx, timeout waiting for packets 2021-08-03 09:50:48.409 webui: Stop streaming /tvheadend/stream/channelid/2047207402?auth=xxxxxxxxxx, timeout waiting for packets 2021-08-03 09:50:48.415 subscription: 0035: "HTTP" unsubscribing from "Das Erste HD", hostname="::ffff:192.168.178.32", username="xxxxxxxxxx", client="VLC/3.0.11" 2021-08-03 09:50:48.415 subscription: 0036: "HTTP" unsubscribing from "Das Erste HD", hostname="::ffff:192.168.178.32", username="xxxxxxxxxx", client="VLC/3.0.11" and the tvheadend log
fallenwitch3r 45 Posted August 3, 2021 Author Posted August 3, 2021 #EXTINF:-1 logo="http://192.168.178.32:9981/tvheadend/imagecache/33626?auth=xxxxxxx" tvg-id="eae7057adc2ae3120006ab465a1c2fd5" tvg-chno="1",Das Erste HD http://192.168.178.32:9981/tvheadend/stream/channelid/2047207402?auth=xxxxxxx&profile=pass #EXTINF:-1 logo="http://192.168.178.32:9981/tvheadend/imagecache/33638?auth=xxxxxxx" tvg-id="c4f67c3b76501a8c3738975775a94d09" tvg-chno="2",ONE HD http://192.168.178.32:9981/tvheadend/stream/channelid/998045380?auth=xxxxxxx&profile=pass #EXTINF:-1 logo="http://192.168.178.32:9981/tvheadend/imagecache/33637?auth=xxxxxxx" tvg-id="1378ccbf2a44fa255a9a34e942b8191f" tvg-chno="3",tagesschau24 HD http://192.168.178.32:9981/tvheadend/stream/channelid/1070364691?auth=xxxxxxx&profile=pass My m3u
fallenwitch3r 45 Posted August 3, 2021 Author Posted August 3, 2021 now it looks like this. Only WDR Köln HD playing with Opera Browser on my Smartphone outside my local network should use transcoding. But all devices except my Android TV using transcoding. But the playback dont work If i change from 3 Mbit/s to auto bitrate. I dont get it
Q-Droid 1011 Posted August 3, 2021 Posted August 3, 2021 A couple of things I see: Are you using the Emby TVHeadend plugin or is this a coincidence - TVHclient4xxxxxxxxxx-4.6.4.0 (HTSPv20)? It looks like TVH is transcoding or at least trying to. I can't tell if those were tests so I would try to prevent transcoding by TVH and only allow the pass profile. Let the client applications handle the transcoding unless you have a special case which could be handled by a different user account in TVH. If you uncheck the profiles from the user account(s) it should then only use the default pass profile. 1
fallenwitch3r 45 Posted August 3, 2021 Author Posted August 3, 2021 I tried the tvh plugin to see if it works, but it does. Is pass or htsp the default Profil? So you mean i should use only the default profil and the clients should tell the server for direct play or transcoding?
Q-Droid 1011 Posted August 3, 2021 Posted August 3, 2021 It looks like your settings for TVH have pass set as the default. Yes, you want Emby to get the stream in its original form and let it handle transcoding if needed based on the clients. Otherwise there's a chance of a stream being transcoded twice, once by TVH and then again by Emby. Adding overhead and degrading quality. 2
fallenwitch3r 45 Posted August 3, 2021 Author Posted August 3, 2021 (edited) It seems that lowering the bitrate fix the problem.. Edited August 3, 2021 by fallenwitch3r
Luke 42238 Posted August 4, 2021 Posted August 4, 2021 11 hours ago, fallenwitch3r said: It seems that lowering the bitrate fix the problem.. Do you mean using the in-app quality setting?
fallenwitch3r 45 Posted August 5, 2021 Author Posted August 5, 2021 Yes, the playback works after lowering the client nitrate because the server begins to transcode.
Luke 42238 Posted August 6, 2021 Posted August 6, 2021 On 8/5/2021 at 8:42 AM, fallenwitch3r said: Yes, the playback works after lowering the client nitrate because the server begins to transcode. OK that suggests the app video player doesn't like something about the original video when it is streamed directly.
