fallenwitch3r 45 Posted July 31, 2021 Posted July 31, 2021 (edited) My System runs on Ubuntu 20.04.2 LTS with HTS Tvheadend 4.3-1857~g221c29b40 and Emby Server 4.6.4.0. My Problem is that i can not Play or Stream HD Channels. All SD Channels working fine. I noticed that i only can watch during connect to the local Network. Streamin over the Internet does not work. The Windows Store Emby App playes only SD Channels with Direct streaming I can play only SD Channles on Webbrowsers like Edge or Opera. The Android TV App Plays all Channels with direct Play Mobile Webbrowsers play only SD Channels And i noticed that Tvheadend wont drop the connections after stop playing the TV Channels. The strange this that it worked before Edited August 2, 2021 by fallenwitch3r
Carlo 4561 Posted August 1, 2021 Posted August 1, 2021 Hi, can you upload your server log file for us to look at?
fallenwitch3r 45 Posted August 1, 2021 Author Posted August 1, 2021 (edited) After switching from tvh plugin to m3u list the cover are showing up. But now trying to watch a HD channel through a m3u file. Most channels are working but some not. Maybe you can get more information with the log Edited August 1, 2021 by fallenwitch3r
Carlo 4561 Posted August 1, 2021 Posted August 1, 2021 That looks fine in the remux log. What happens at the client level?
fallenwitch3r 45 Posted August 1, 2021 Author Posted August 1, 2021 How do I get the log from the app or the emby website?
Carlo 4561 Posted August 1, 2021 Posted August 1, 2021 Log menu. The latest server log will be the one at the top.
Carlo 4561 Posted August 1, 2021 Posted August 1, 2021 When you look at the channel list menu item is it showing your channels mapped?
fallenwitch3r 45 Posted August 1, 2021 Author Posted August 1, 2021 Yes, all channels are mapped. All channels working on Kodi or on VLC but in Emby some channles wont play. The first three channels on my list wont start playing. The loading circle shows up an the screen goes black and then nothing..
fallenwitch3r 45 Posted August 1, 2021 Author Posted August 1, 2021 (edited) 32 minutes ago, cayars said: Which client are you have issues with? All. Emby in Android TV, Windows app, Android smartphone app or Webbrowser. The first few channels won't play. All other channels play more or less good. Some have stuttering or buffering problems butnafter a while they play without problems. Only the first few won't play Edit.. I noticed that more channels won't start playing. Most of them are HD channels. HD Channels that are provided by tvheadend won't play. HD internet steaming Channels play correctly. These channels are integrated into tvheadend. All other channels are dvb-c channles provided by hardware dvb-c tuners. Edited August 1, 2021 by fallenwitch3r
Carlo 4561 Posted August 2, 2021 Posted August 2, 2021 I don't use tvheadend so can't really comment on it but that would appear to be where to look???
fallenwitch3r 45 Posted August 2, 2021 Author Posted August 2, 2021 Maybe but if I know it I wouldn't ask for help
fallenwitch3r 45 Posted August 2, 2021 Author Posted August 2, 2021 streaming movies and series in HD works fine
Carlo 4561 Posted August 2, 2021 Posted August 2, 2021 So the problem is limited to HD streams played back from tvheadend? Can you try and play back one of these streams and upload the ffmpeg file generated?
fallenwitch3r 45 Posted August 2, 2021 Author Posted August 2, 2021 (edited) Here I trying to stream a HD channel on my smartphone outside my local network. ffmpeg-remux-1b7e17f8-3b5b-4400-ad09-5c75f1b0adae_1.txt Edited August 2, 2021 by fallenwitch3r
Carlo 4561 Posted August 2, 2021 Posted August 2, 2021 OK, that log is reporting bad timing in the stream while trying to remux the file. It also abruptly stops after about 1:48 into trying to process the stream. This looks like an mal-formed/incompatible stream.
fallenwitch3r 45 Posted August 2, 2021 Author Posted August 2, 2021 I don't know what you mean but how can I fix it? Another TV channel with a 1080p resolution streams great. Only the 720p streams fail.
Carlo 4561 Posted August 2, 2021 Posted August 2, 2021 What is the source of these streams? What kind of tuner?
fallenwitch3r 45 Posted August 2, 2021 Author Posted August 2, 2021 The source are 2 usb Dvb-c twin tuner. I don't know what happened because everything works fine a few days ago.
Carlo 4561 Posted August 2, 2021 Posted August 2, 2021 You were originally using a plugin for Live TV to communicate with tvheadend correct? What happens if you go back to using the plugin vs the m3u file?
fallenwitch3r 45 Posted August 2, 2021 Author Posted August 2, 2021 Same thing. 720p channels don't work. I think it's a fine adjust thing but I don't know
Carlo 4561 Posted August 2, 2021 Posted August 2, 2021 Have you by any chance unplugged the USB tuners to reset them?
Carlo 4561 Posted August 2, 2021 Posted August 2, 2021 Can you try playing a different channel and then upload the new ffmpeg log file?
