kaledi 42 Posted July 31, 2021 Posted July 31, 2021 I have the latest version of Emby server on a Synology NAS DSM 7. Migration from DSM 6.2 went fine. Libraries are fine, except music and photo libraries. With the music library no music is shown except when I go the folders view and then I can navigate to different albums and the meta data appears to be correct for the music. For photos, which are all jpeg, nothing shows regardless of library refresh. For both, I've checked that the internal user 'emby' has access rights to the respective shared folders. Any suggestions?
Carlo 4561 Posted August 1, 2021 Posted August 1, 2021 What version of Emby Server did you have installed on DSM 6?
Carlo 4561 Posted August 4, 2021 Posted August 4, 2021 Hi, if you look at the library menu at your music and photo libraries what type does it say under it? Does it say "Mixed Content" on either?
kaledi 42 Posted August 4, 2021 Author Posted August 4, 2021 No, the photos library says 'Home Videos and Photos' and the Music library says Music
Gulan 0 Posted August 14, 2021 Posted August 14, 2021 It seems that i have the same problem. I have 2 shared folders on my Synology (both have access) and since DSM 7, Photos are not recognized/scanned. Scanning begins immediately for the Video folder but does nothing for the Photo folder. I triple checked access on this shared folder (Photo) in synology but still it doesn't recognize or can access the content.
Carlo 4561 Posted August 14, 2021 Posted August 14, 2021 6 minutes ago, Gulan said: It seems that i have the same problem. I have 2 shared folders on my Synology (both have access) and since DSM 7, Photos are not recognized/scanned. Scanning begins immediately for the Video folder but does nothing for the Photo folder. I triple checked access on this shared folder (Photo) in synology but still it doesn't recognize or can access the content. Can you scan this library then upload your server log when it finishes so we can take a look?
Carlo 4561 Posted August 14, 2021 Posted August 14, 2021 It's loading other years but has a problem with Access to the path '/volume1/Photo/2021' is denied. There could be others as well but I saw this one in the logs.
Gulan 0 Posted August 14, 2021 Posted August 14, 2021 I don't see it. Enabled debug logging Check after 16:42 (there I started scanning the Photo library) embyserver (1).txt
Carlo 4561 Posted August 14, 2021 Posted August 14, 2021 2021-08-14 13:41:14.360 Error Server: Error processing request *** Error Report *** Version: 4.6.4.0 Command line: /volume1/@appstore/EmbyServer/system/EmbyServer.dll -programdata /var/packages/EmbyServer/var -ffdetect /var/packages/EmbyServer/target/bin/ffdetect -ffmpeg /var/packages/EmbyServer/target/bin/ffmpeg -ffprobe /var/packages/EmbyServer/target/bin/ffprobe -nolocalportconfig -ignore_vaapi_enabled_flag -pidfile /var/packages/EmbyServer/var/EmbyServer.pid -updatepackage emby-server-synology7_{version}_x86_64.spk Operating system: Linux version 4.4.180+ (root@build13) (gcc version 7.5.0 (GCC) ) #41890 SMP Thu Jul 15 03:37:40 CST 2021 Framework: .NET Core 3.1.13 OS/Process: x64/x64 Runtime: volume1/@appstore/EmbyServer/system/System.Private.CoreLib.dll Processor count: 2 Data path: /var/packages/EmbyServer/var Application path: /volume1/@appstore/EmbyServer/system System.UnauthorizedAccessException: System.UnauthorizedAccessException: Access to the path '/volume1/Photo/2021' is denied.
Gulan 0 Posted August 14, 2021 Posted August 14, 2021 (edited) 7 minutes ago, cayars said: 2021-08-14 13:41:14.360 Error Server: Error processing request *** Error Report *** Version: 4.6.4.0 Command line: /volume1/@appstore/EmbyServer/system/EmbyServer.dll -programdata /var/packages/EmbyServer/var -ffdetect /var/packages/EmbyServer/target/bin/ffdetect -ffmpeg /var/packages/EmbyServer/target/bin/ffmpeg -ffprobe /var/packages/EmbyServer/target/bin/ffprobe -nolocalportconfig -ignore_vaapi_enabled_flag -pidfile /var/packages/EmbyServer/var/EmbyServer.pid -updatepackage emby-server-synology7_{version}_x86_64.spk Operating system: Linux version 4.4.180+ (root@build13) (gcc version 7.5.0 (GCC) ) #41890 SMP Thu Jul 15 03:37:40 CST 2021 Framework: .NET Core 3.1.13 OS/Process: x64/x64 Runtime: volume1/@appstore/EmbyServer/system/System.Private.CoreLib.dll Processor count: 2 Data path: /var/packages/EmbyServer/var Application path: /volume1/@appstore/EmbyServer/system System.UnauthorizedAccessException: System.UnauthorizedAccessException: Access to the path '/volume1/Photo/2021' is denied. Ok but I changed access on the individual folders after that. Look after 16:42 where i did my scan again. Edited August 14, 2021 by Gulan
Luke 42243 Posted August 14, 2021 Posted August 14, 2021 3 hours ago, Gulan said: Ok but I changed access on the individual folders after that. Look after 16:42 where i did my scan again. And what happened after that? What do you see when browsing the library in the emby web app? What formats are the photos?
Gulan 0 Posted August 15, 2021 Posted August 15, 2021 17 hours ago, Luke said: And what happened after that? What do you see when browsing the library in the emby web app? What formats are the photos? Nothing: the library is empty. You don't see a progress bar calculating like with the Video's of the other folder.
Carlo 4561 Posted August 15, 2021 Posted August 15, 2021 We still need the answer to what @Luke asked. What format are these photos?
Gulan 0 Posted August 15, 2021 Posted August 15, 2021 3 minutes ago, cayars said: We still need the answer to what @Luke asked. What format are these photos? Formats are plain jpg. This shared folder (Photo) wasn't a problem in DSM6 for Emby, so I don't know what happened now in DSM7.
Carlo 4561 Posted August 15, 2021 Posted August 15, 2021 If you want to do a remote session I'd be happy to take a look with you to see if we can figure this out. Send me a PM if you would like to do this.
Luke 42243 Posted August 15, 2021 Posted August 15, 2021 How many emby libraries have you created and what folder paths did you add to each one?
Gulan 0 Posted August 16, 2021 Posted August 16, 2021 (edited) 13 hours ago, Luke said: How many emby libraries have you created and what folder paths did you add to each one? I have a Movies: (/volume1/Nasmedia/Films en Series/Films) I have a TV Series (/volume1/Nasmedia/Films en Series/Series) I have a Home Videos & Photos which uses /volume1/Photo /volume1/Video Red = Shared folder All are ok except Photo. Edited August 16, 2021 by Gulan
Carlo 4561 Posted August 16, 2021 Posted August 16, 2021 Is /volume1/Photo or /volume1/Video added to any other lib?
Gulan 0 Posted August 16, 2021 Posted August 16, 2021 3 minutes ago, cayars said: Is /volume1/Photo or /volume1/Video added to any other lib? No
Gulan 0 Posted August 17, 2021 Posted August 17, 2021 (edited) 16 hours ago, cayars said: Have you fixed the permission problem yet? No, I don't have proof it is a permission problem. I checked all access several times for the shared folder and the subfolders. Edited August 17, 2021 by Gulan
