Kandidat1999 35 Posted July 30, 2021 Posted July 30, 2021 Hi, so my problem is, Emby does recognize all new movies, but it will not show all of them in the "Newest Movies" Row, just some but not all of them, the movies that are not shown but added new to the library are in the general movie folder, but it would be cool if he would show all the new ones I add. Same for TV Shows by the way.
Carlo 4561 Posted July 30, 2021 Posted July 30, 2021 Hi, Unless you've had these movies before they should be shown. For a movie that doesn't show, if you look at it's meta-data in Emby what is the date added?
Solution Kandidat1999 35 Posted July 30, 2021 Author Solution Posted July 30, 2021 I think I finally found it, the library setting was at "Use Date when File was created" I changed it now to "Use Date when the File was added" 1
