Joechung 5 Posted July 30, 2021 Posted July 30, 2021 Dear EMBY Technicians Play a 4K movie, I have set the minimum transcoding output inside EMBY, and the output is successfully low bitrate output when I play it with EMBY side, why I still output the same 4K video quality when I play it with infuse?
Solution vdatanet 1619 Posted July 30, 2021 Solution Posted July 30, 2021 1 hour ago, Joechung said: Dear EMBY Technicians Play a 4K movie, I have set the minimum transcoding output inside EMBY, and the output is successfully low bitrate output when I play it with EMBY side, why I still output the same 4K video quality when I play it with infuse? The problem is on Infuse's side. Infuse does not support transcoding at this time, so only direct playback is possible. It is planned for the future, but it is not a priority feature.
