Home2008 21 Posted July 29, 2021 Posted July 29, 2021 Habe ein Phenomen mit dem Emby Server unter Windows 10, Version 4.6.4.0. wenn ich neue Folgen hinzufüge, werden nach einer Aktuallisierung nicht immer alle Folgen angezeigt. Kann mir jemand dies erklären? Bild 1: Alle Folgen sichtbar, und abspielbar Bild 2: Da wird die 6. Folgen als fehlend angezeigt, obwohl vorhanden.
Carlo 4561 Posted July 29, 2021 Posted July 29, 2021 Hi, run a library scan and then look again. If it doesn't show up after this upload the server log file and tell us the exact filename of this episode on disc and we can check the log file for it.
Home2008 21 Posted July 29, 2021 Author Posted July 29, 2021 Hi, the File Name is: Paris Police 1900-S01E06-Episode 6 from other File is: Paris Police 1900-S01E05-Episode 5 This works. And the log. embyserver.zip
Carlo 4561 Posted July 29, 2021 Posted July 29, 2021 I see this in the log EpisodeNfoProvider returned no metadata for \\HOME2008\Serien 02\Paris Police 1900\Staffel 01\Paris Police 1900-S01E06-Episode 6.ts Saving nfo metadata for \\HOME2008\Serien 02\Paris Police 1900\Staffel 01\Paris Police 1900-S01E06-Episode 6.ts to \\HOME2008\Serien 02\Paris Police 1900\Staffel 01\Paris Police 1900-S01E06-Episode 6.nfo Is this series Identified? Please upload the NFO file mentioned above.
Home2008 21 Posted July 29, 2021 Author Posted July 29, 2021 So, it is from Serie and Episode, both. Staffel 01.zip
Luke 42241 Posted July 29, 2021 Posted July 29, 2021 Do you have the library option enabled to import missing episodes? Try turning that off if you do.
Home2008 21 Posted July 30, 2021 Author Posted July 30, 2021 (edited) Yes this is enabled.ok, I'll turn that off. But I can´t find it again Edited July 30, 2021 by Home2008
Home2008 21 Posted July 30, 2021 Author Posted July 30, 2021 So, I have found it now. Then deactivated, and then rescanned the library. Now the episode is displayed correctly. But I find that a pity, because without this option I do not know which episode I am still missing.
Luke 42241 Posted August 9, 2021 Posted August 9, 2021 We'll take a look at it. Thanks for reporting.
oneumann 0 Posted February 20, 2022 Posted February 20, 2022 (edited) Have a similar problem: all 6 episodes exist in one folder (S01E01-S01E06). emby skips E01 and insists on starting with E02 !? also indicates only 5 episodes on series green point, top right corner.. happens to series "Parfum", IMDB tt6811236 Edited February 20, 2022 by oneumann
Luke 42241 Posted February 23, 2022 Posted February 23, 2022 On 2/20/2022 at 8:06 AM, oneumann said: Have a similar problem: all 6 episodes exist in one folder (S01E01-S01E06). emby skips E01 and insists on starting with E02 !? also indicates only 5 episodes on series green point, top right corner.. happens to series "Parfum", IMDB tt6811236 Hi there, how are your files named and organized?
