ginjaninja 605 Posted July 28, 2021 Posted July 28, 2021 Am putting a touchscreen tablet in kitchen, for recipies, stock management and emby... Was looking at a Lenovo M10 2nd Gen FHD 2GB Ram 32GB Storage, Android Pie, front facing speakers Does anyone have any device or spec recommendations to run emby (tv, music, films)....Am not worried about server transcoding horsepower or wifi bandwidth..just the device. Theres a big difference in cost between a 2gb base model and something with more horsepower...is that necessary for Emby? i dont need to run apps concurrently. Any devices out there offer better sound quality than others? and a slightly different question...any bluetooth speaker recommendations? thanks in advance.
Luke 42238 Posted July 28, 2021 Posted July 28, 2021 Not exactly the same thing, but I have a cheap Lenovo chromebook for android testing and it's performed well enough.
ginjaninja 605 Posted July 29, 2021 Author Posted July 29, 2021 20 hours ago, Luke said: Not exactly the same thing, but I have a cheap Lenovo chromebook for android testing and it's performed well enough. thanks..can you say the model? that would be a useful yardstick
