Carlo 4561 Posted August 3, 2021 Posted August 3, 2021 From web dashboard Go to your device menu and click on your mobile device. You'll notice the URL in the browser change with an id= Copy the id shown after the = sign and post that here. BTW, turn off debug logging as you only want that turned on when asked as it makes reading log files hard.
crusher11 1134 Posted August 3, 2021 Author Posted August 3, 2021 I keep being asked to turn it on and then forgetting to turn it back off...
Happy2Play 9802 Posted August 3, 2021 Posted August 3, 2021 (edited) No issues on my iPhone. But there is a UI issue. But then it jumped to 64.5%. But is does look like there is a issue with Original quality. But phone download shows this gradually climbing. Download manager still show 0%. But download still progressing. Ending with this Edited August 3, 2021 by Happy2Play added image
crusher11 1134 Posted August 3, 2021 Author Posted August 3, 2021 56 minutes ago, cayars said: From web dashboard Go to your device menu and click on your mobile device. You'll notice the URL in the browser change with an id= Copy the id shown after the = sign and post that here. BTW, turn off debug logging as you only want that turned on when asked as it makes reading log files hard. 3f51ccfc99413bd9
Carlo 4561 Posted August 3, 2021 Posted August 3, 2021 2021-08-04 00:36:14.680 Debug App: Notifying target 3f51ccfc99413bd9 that downloads are ready OK so your ID does match the server. The server has notified the client that a download(s) is ready to transfer. So it's likely safe to assume the server has done it's thing and now is waiting on the client. What client version of software are you currently running? Have you tried stopping the client app (close then force close it) and then restarting it? That may kick off the transfer. Just curious, Is your phone on the same LAN right now as the server?
crusher11 1134 Posted August 3, 2021 Author Posted August 3, 2021 34 minutes ago, cayars said: 2021-08-04 00:36:14.680 Debug App: Notifying target 3f51ccfc99413bd9 that downloads are ready OK so your ID does match the server. The server has notified the client that a download(s) is ready to transfer. So it's likely safe to assume the server has done it's thing and now is waiting on the client. What client version of software are you currently running? Have you tried stopping the client app (close then force close it) and then restarting it? That may kick off the transfer. Just curious, Is your phone on the same LAN right now as the server? Whatever the latest one is, I assume. Yeah, they're on the same LAN. Although I think the connection is a remote one.
Carlo 4561 Posted August 3, 2021 Posted August 3, 2021 Can you look and tell us the exact version please of the client? 7 minutes ago, crusher11 said: Yeah, they're on the same LAN. Although I think the connection is a remote one. I don't understand what this means. If the client and server are on the same LAN (same IP address space) this should be a local connection and not remote.
crusher11 1134 Posted August 3, 2021 Author Posted August 3, 2021 If I type in the domain and connect that way, it's a remote connection no matter what LAN the phone is on. It's version 3.2.05.
Carlo 4561 Posted August 3, 2021 Posted August 3, 2021 (edited) Thanks crusher11. Please try this using the local server IP/port combo. That will make it app->server vs app->cloudflare->gninx->server That will rule out interference from any type of proxy. Edited August 4, 2021 by cayars
crusher11 1134 Posted August 4, 2021 Author Posted August 4, 2021 I tried it locally and it worked. Tried it remotely and it worked. Weird.
Carlo 4561 Posted August 4, 2021 Posted August 4, 2021 2 hours ago, crusher11 said: I tried it locally and it worked. Tried it remotely and it worked. Weird. What specifically did you do differently?
Carlo 4561 Posted August 4, 2021 Posted August 4, 2021 You didn't try local http vs domain avoiding cloudflare and nginx?
Carlo 4561 Posted August 5, 2021 Posted August 5, 2021 So previously you were using your domain which could allow either cloudflare or nginx to filter or block the download or the notification. When you remove the domain and login locally you bypass both and talk directly to the Emby Server.
crusher11 1134 Posted August 5, 2021 Author Posted August 5, 2021 But it works with the domain as well now.
crusher11 1134 Posted August 16, 2021 Author Posted August 16, 2021 And now it's broken again. So that's fun. The other user is trying to download something and it's stuck at "Ready to transfer", after the conversion has completed.
crusher11 1134 Posted August 16, 2021 Author Posted August 16, 2021 Connecting via the IP resolves it. So it's something to do with the domain.
crusher11 1134 Posted August 16, 2021 Author Posted August 16, 2021 It has, however, been stuck on "transferring 0%" for an hour now.
crusher11 1134 Posted August 17, 2021 Author Posted August 17, 2021 Several more hours, still no movement.
Carlo 4561 Posted August 17, 2021 Posted August 17, 2021 Not sure what to say but if it works when connecting directly but not when going through your proxies then this is likely where you need to look test.
