runtimesandbox 173 Posted July 26, 2021 Posted July 26, 2021 (edited) Whenever I attempt to chromecast audio from emby using the web app or the android mobile app, it will play for roughly 30 seconds and then cut out. Happens across both Chromecast audio and Google home mini speakers Still shows in the dashboard under active devices but with no play time Running latest emby stable on Ubuntu 20 behind an nginx reverse proxy (valid ssl cert). The chromecasts and devices casting to the chromecasts are all on the same local network but the emby server is on a remote network (over the internet). Tested both WAVs and FLAC files. Fresh server and ffmpeg logs attached Edit: anything that can be direct played works fine (audio books in m4a format). I have hardware transcoding disabled Playing the same file in the emby web app on a laptop, dashboard shows it as transcoding too but it doesn't cut out Playing the files on chromecasts on the network that the emby server is on plays the files fine but uses Direct Streaming instead of transcoding. embyserver.txt hardware_detection-63762919913.txt ffmpeg-transcode-84b5b79c-fe6a-436f-a7a5-fe27a8c6ecdf_1.txt Edited August 2, 2021 by runtimesandbox
Carlo 4561 Posted July 26, 2021 Posted July 26, 2021 Hi, how is your network setup that the Chromecasts are on a different network then the Emby Server?
runtimesandbox 173 Posted July 26, 2021 Author Posted July 26, 2021 My emby server is accessible over the internet. The chromecasts can connect back to the emby server to play media
runtimesandbox 173 Posted July 26, 2021 Author Posted July 26, 2021 The emby server is in one physical location - the chromecasts are in a different physical location. Two separate internet connections. As an aside the issue is also present playing locally in the android app when audio is required to be transcoded
Carlo 4561 Posted July 26, 2021 Posted July 26, 2021 OH ok what you said before "This is all on the same local network but is remote to the emby server." confused me a bit. So you have a client and chromecast in one location and the Emby Server at another location with the Internet between the two correct?
runtimesandbox 173 Posted July 26, 2021 Author Posted July 26, 2021 Have edited the original post to clarify that point Quote So you have a client and chromecast in one location and the Emby Server at another location with the Internet between the two correct? Yep thats correct - hopefully thats clearer now!
Carlo 4561 Posted July 26, 2021 Posted July 26, 2021 Was my bad, I just read what you typed incorrect. Do you have physical access to the server or is this hosted elsewhere? I ask because I'm wondering if it's possible to test casting to the chromecast on the same local network.
runtimesandbox 173 Posted July 26, 2021 Author Posted July 26, 2021 Have tested the chromecasts on the network local to the emby server, these all play the files fine (no stopping) but are directly streaming the file rather than transcoding it
Carlo 4561 Posted July 27, 2021 Posted July 27, 2021 Hi, would it be possible to allow me to test against your server? My server is local and doesn't sound like that's a problem. This way I can test against the same server you are using. If so send me a PM and we can arrange this test.
runtimesandbox 173 Posted August 2, 2021 Author Posted August 2, 2021 @Luke @softworkz any suggestions on this? Any more info I can provide from my end? As a side note this was present in previous versions of the server I just never had time to dig in to it
runtimesandbox 173 Posted August 9, 2021 Author Posted August 9, 2021 Can anyone provide any further advice for diagnosing this?
runtimesandbox 173 Posted August 16, 2021 Author Posted August 16, 2021 Yes still the exact same issue
