thegrunge 29 Posted July 23, 2021 Posted July 23, 2021 Hello, is this a bug or is it normal that I cannot send a message to a user from the dashboard except when he is on the same network as me? What I want to talk about is the icon that is used to send a message to a user who is listening to something on dashboard.
thegrunge 29 Posted July 25, 2021 Author Posted July 25, 2021 Does anyone have anything to say about it? It is rather rare ...
mastrmind11 722 Posted July 26, 2021 Posted July 26, 2021 iirc i've used this with external clients and it worked.
thegrunge 29 Posted July 26, 2021 Author Posted July 26, 2021 ok i tested several times without success. can be a correct pitch setting
Luke 42246 Posted July 26, 2021 Posted July 26, 2021 If the option is displayed, then it should work.
thegrunge 29 Posted July 27, 2021 Author Posted July 27, 2021 @Luke I have done tests from home directly from the server and it does not work. On the other hand I did the same test from my phone with the emby application and without wifi, it worked. I would like to know what can cause this problem. Probably it also works from my macbook pro but when I'm not at home
