fxwegr 6 Posted July 23, 2021 Posted July 23, 2021 Why do the media, displayed in the secondary home screen section, not disappear from the secondary home screen, even though they are marked as played? What can I do so that only the media are displayed that are not yet played? I use release 4.6.4.0.
Carlo 4561 Posted July 23, 2021 Posted July 23, 2021 Hi, did you enable the option "Hide fully played content from latest media" in the home screen settings?
GrimReaper 4861 Posted July 23, 2021 Posted July 23, 2021 Just now, cayars said: Hi, did you enable the option "Hide fully played content from latest media" in the home screen settings? Hence the question which client app he was referring to, Web App or some other.
fxwegr 6 Posted July 23, 2021 Author Posted July 23, 2021 Many thanks. Because this option is placed under "Recordings" I did not check it. 1
Carlo 4561 Posted July 23, 2021 Posted July 23, 2021 That option should probably be shown first vs last to make it less confusing. @Luke
fxwegr 6 Posted July 24, 2021 Author Posted July 24, 2021 Yes, this is an item for Luke's to do list.
Luke 42201 Posted July 26, 2021 Posted July 26, 2021 On 7/23/2021 at 12:32 PM, fxwegr said: Many thanks. Because this option is placed under "Recordings" I did not check it. Are you saying you didn't scroll down to find it?
fxwegr 6 Posted July 26, 2021 Author Posted July 26, 2021 Sorry. Yes I see that was misleading. Not everyone has TVHeadEnd installed. Please have a look at the attached screenshot.
