karlb 0 Posted August 28, 2014 Posted August 28, 2014 Hi I have added a folder and season 1 of most haunted to my server but i cant download any metedata for it i have the numbers on IBM and moviedb but i cant add them when i edit it in the server there is no drop down for it unlike all the other TV series. What have i done wronge can someplease help
ebr 16306 Posted August 28, 2014 Posted August 28, 2014 Create a Season 1 folder underneath that one. Then run a library scan. Then use the identify feature from the web editor if it doesn't find it.
CBers 7541 Posted August 28, 2014 Posted August 28, 2014 Hi I have added a folder and season 1 of most haunted to my server but i cant download any metedata for it i have the numbers on IBM and moviedb but i cant add them when i edit it in the server there is no drop down for it unlike all the other TV series. What have i done wronge can someplease help It's the spirits playing with you Do as Ebr suggests and all should be good.
