sewulba2021 0 Posted July 23, 2021 Posted July 23, 2021 Hello Community, My Emby-Server works well for month on my Debian-Linux. The Problem has begun as I deaktivate Transcoding in settings. From there I don't got Sound on any device. From now on all work well, but no sound. On WebOS (LG) no sound, on GoogleTV no sound. Direct in emby no sound. What can I do. I got no further ideas. Greets. Sewulba
gillmacca01 220 Posted July 23, 2021 Posted July 23, 2021 Is this happening on more than 1 video file? Have you tried playing the problem files outside of Emby? i.e. in VLC
sewulba2021 0 Posted July 23, 2021 Author Posted July 23, 2021 In all Videos. If I play any Video, over NFS as example, in VLC all works well. the Problem began, If I changed the transcoding-settings. I regret that since several weeks. No sound enymore.
sewulba2021 0 Posted July 23, 2021 Author Posted July 23, 2021 To the background: My Emby-Server runs virtual under KVM. Works really well for months. Transcoding settings changed, no sound anymore. ARGHL
gillmacca01 220 Posted July 23, 2021 Posted July 23, 2021 But have you tried to play the file outside of Emby. Want to confirm whether it is an issues with you sound device or not. Have you tried putting the transcoding settings back to default?
sewulba2021 0 Posted July 23, 2021 Author Posted July 23, 2021 Yes. If I play the videos outside Emby all works fine on several devices. If I want to play over Emby (direct, WebOS(LG) or GoogleTV and so on) no sound comes. And yes I put back the transcoding settings to default, but no success.
Luke 42246 Posted July 23, 2021 Posted July 23, 2021 Hi there, can we please look at an example? Please attach the information requested in how to report a media playback issue. thanks !
sewulba2021 0 Posted July 25, 2021 Author Posted July 25, 2021 I hope I got it. . . EnablePlaybackRemuxing: True EnableVideoPlaybackTranscoding: False EnableAudioPlaybackTranscoding: False This has to be the problem. Transcoding is on False, but why? I activate Transcoding in my settings.
sewulba2021 0 Posted August 5, 2021 Author Posted August 5, 2021 On 7/25/2021 at 5:31 PM, Luke said: Juhuuuuu. Genau das war die Lösung. Es funzt wieder. Thanks a lot.
Luke 42246 Posted August 5, 2021 Posted August 5, 2021 Emby will already direct play whenever possible, so you generally should not need to use those settings.
