Necker 24 Posted August 28, 2014 Posted August 28, 2014 The clients display the Cast & Crew in the order that they appear in the xml file. Sometimes the order that they are in is not what I want and so I would like to change it. Therefore within the metadata editor could a simple up/down arrow be added to each actor so that the order they appear in can be controlled. 11 2
blade005 185 Posted July 15, 2018 Posted July 15, 2018 The ability to adjust the DISPLAY ORDER for PEOPLE in the Metadata editor of Emby Server would be useful. There are times when the lead actors in a series or movie are not listed near the top of the CAST sections of TheMovieDB or TheTVDB when they are grabbed. They can get buried later in the listings or at times you may have to go to the MORE section of ITEM INFORMATION page to find them. The current way to adjust for this is to go into the TVSHOW.nfo or MOVIE.nfo file and edit the SORT ORDER tag of the actors you want higher up in the listing. If possible, it would be useful if in the PEOPLE section of the METADATA EDITOR there were UP / DOWN selectors to adjust the display order. Similar to what is available in the HOME SCREEN SETTINGS section to adjust the LIBRARY ORDER. 3
blade005 185 Posted January 2, 2020 Posted January 2, 2020 The clients display the Cast & Crew in the order that they appear in the xml file. Sometimes the order that they are in is not what I want and so I would like to change it. Therefore within the metadata editor could a simple up/down arrow be added to each actor so that the order they appear in can be controlled. Thought my request in 2018 was the first. Beat me by 4 years! https://emby.media/community/index.php?/topic/60774-fr-metadata-editor-people-display-order/ @@Luke commented at the time that it was a good idea. Hopefully it will make it into a future release.
ebr 16337 Posted January 4, 2020 Posted January 4, 2020 FR: Control Actor order within Metadata Manager
michalkaluza 8 Posted September 18, 2022 Posted September 18, 2022 Please add an option to determine the order of the cast. In some films, the cast is shown in the wrong order.
michalkaluza 8 Posted September 18, 2022 Posted September 18, 2022 Is there a public list of upcoming updates? Those that are the most important.
Happy2Play 9812 Posted September 18, 2022 Posted September 18, 2022 @michalkaluza I assume you have TVDB as your primary movie provider, correct? @LukeI thought we discussed this but for TVDB are Featured actors sorted first? As it would appear from image only Sort order is used. I see the JSON is correct, but the UI is not. This is reproducible. "isFeatured": true, "sort": 9 should be before "isFeatured": false, "sort": 1 in the UI Spoiler "characters": [{ "id": 12149924, "name": "Lester Burnham", "peopleId": 253995, "seriesId": 0, "movieId": "445", "type": 3, "image": "https://artworks.thetvdb.com/banners/person/253995/5f0f7bb6d1f7e.jpg", "sort": 9, "isFeatured": true, "url": "253995-kevin-spacey", "peopleType": "Actor", "personName": "Kevin Spacey", "personImgURL": "https://artworks.thetvdb.com/banners/person/253995/primary.jpg" }, { "id": 12149925, "name": "Carolyn Burnham", "peopleId": 334650, "seriesId": 0, "movieId": "445", "type": 3, "image": "https://artworks.thetvdb.com/banners/person/334650/5f0f7c3b7b990.jpg", "sort": 10, "isFeatured": true, "url": "334650-annette-bening", "peopleType": "Actor", "personName": "Annette Bening", "personImgURL": "https://artworks.thetvdb.com/banners/person/334650/primary.jpg" }, { "id": 12149926, "name": "Jane Burnham", "peopleId": 335887, "seriesId": 0, "movieId": "445", "type": 3, "image": "", "sort": 11, "isFeatured": true, "url": "335887-thora-birch", "peopleType": "Actor", "personName": "Thora Birch", "personImgURL": "https://artworks.thetvdb.com/banners/person/335887/primary.jpg" }, { "id": 12149927, "name": "Ricky Fitts", "peopleId": 505320, "seriesId": 0, "movieId": "445", "type": 3, "image": "", "sort": 12, "isFeatured": true, "url": "505320-wes-bentley", "peopleType": "Actor", "personName": "Wes Bentley", "personImgURL": "https://artworks.thetvdb.com/banners/person/505320/primary.jpg" }, { "id": 12149928, "name": "Angela Hayes", "peopleId": 274651, "seriesId": 0, "movieId": "445", "type": 3, "image": "", "sort": 13, "isFeatured": true, "url": "274651-mena-suvari", "peopleType": "Actor", "personName": "Mena Suvari", "personImgURL": "https://artworks.thetvdb.com/banners/person/274651/primary.jpg" }, { "id": 12149929, "name": "Colonel Frank Fitts", "peopleId": 333896, "seriesId": 0, "movieId": "445", "type": 3, "image": "", "sort": 14, "isFeatured": true, "url": "333896-chris-cooper", "peopleType": "Actor", "personName": "Chris Cooper", "personImgURL": "https://artworks.thetvdb.com/banners/person/333896/primary.jpg" }, { "id": 12149930, "name": "Barbara Fitts", "peopleId": 303573, "seriesId": 0, "movieId": "445", "type": 3, "image": "", "sort": 15, "isFeatured": true, "url": "303573-allison-janney", "peopleType": "Actor", "personName": "Allison Janney", "personImgURL": "https://artworks.thetvdb.com/banners/person/303573/5fe4d03d8f115.jpg" }, { "id": 12149931, "name": "Buddy Kane", "peopleId": 273508, "seriesId": 0, "movieId": "445", "type": 3, "image": "", "sort": 16, "isFeatured": true, "url": "273508-peter-gallagher", "peopleType": "Actor", "personName": "Peter Gallagher", "personImgURL": "https://artworks.thetvdb.com/banners/person/273508/primary.jpg" }, { "id": 12149932, "name": "Jim Olmeyer", "peopleId": 254114, "seriesId": 0, "movieId": "445", "type": 3, "image": "", "sort": 17, "isFeatured": true, "url": "254114-scott-bakula", "peopleType": "Actor", "personName": "Scott Bakula", "personImgURL": "https://artworks.thetvdb.com/banners/person/254114/primary.jpg" }, { "id": 12149933, "name": "Jim Berkley", "peopleId": 316720, "seriesId": 0, "movieId": "445", "type": 3, "image": "", "sort": 18, "isFeatured": true, "url": "316720-sam-robards", "peopleType": "Actor", "personName": "Sam Robards", "personImgURL": "https://artworks.thetvdb.com/banners/v4/actor/316720/photo/62a7adfc5b27b.jpg" }, { "id": 12149934, "name": "Brad Dupree", "peopleId": 316360, "seriesId": 0, "movieId": "445", "type": 3, "image": "", "sort": 19, "isFeatured": true, "url": "316360-barry-del-sherman", "peopleType": "Actor", "personName": "Barry Del Sherman", "personImgURL": "" }, { "id": 12149935, "name": "Sale House Man #1", "peopleId": 268183, "seriesId": 0, "movieId": "445", "type": 3, "image": "", "sort": 1, "isFeatured": false, "url": "268183-john-cho", "peopleType": "Actor", "personName": "John Cho", "personImgURL": "https://artworks.thetvdb.com/banners/person/268183/primary.jpg" }, { "id": 12149936, "name": "Sale House Man #3", "peopleId": 268381, "seriesId": 0, "movieId": "445", "type": 3, "image": "", "sort": 2, "isFeatured": false, "url": "268381-kent-faulcon", "peopleType": "Actor", "personName": "Kent Faulcon", "personImgURL": "" }, { "id": 12149937, "name": "Sale House Woman #1", "peopleId": 252228, "seriesId": 0, "movieId": "445", "type": 3, "image": "", "sort": 20, "isFeatured": false, "url": "252228-ara-celi", "peopleType": "Actor", "personName": "Ara Celi", "personImgURL": "" }, { "id": 12149938, "name": "Sale House Woman #2", "peopleId": 325350, "seriesId": 0, "movieId": "445", "type": 3, "image": "", "sort": 21, "isFeatured": false, "url": "325350-sue-casey", "peopleType": "Actor", "personName": "Sue Casey", "personImgURL": "" }, { "id": 12149939, "name": "Sale House Woman #3", "peopleId": 354721, "seriesId": 0, "movieId": "445", "type": 3, "image": "", "sort": 3, "isFeatured": false, "url": "354721-brenda-wehle", "peopleType": "Actor", "personName": "Brenda Wehle", "personImgURL": "" }, { "id": 12149940, "name": "Sale House Woman #4", "peopleId": 308860, "seriesId": 0, "movieId": "445", "type": 3, "image": "", "sort": 4, "isFeatured": false, "url": "308860-lisa-cloud", "peopleType": "Actor", "personName": "Lisa Cloud", "personImgURL": "" }, { "id": 12149941, "name": "Christy Kane", "peopleId": 298723, "seriesId": 0, "movieId": "445", "type": 3, "image": "", "sort": 22, "isFeatured": true, "url": "298723-amber-smith", "peopleType": "Actor", "personName": "Amber Smith", "personImgURL": "" }, { "id": 12149942, "name": "Catering Boss", "peopleId": 286142, "seriesId": 0, "movieId": "445", "type": 3, "image": "", "sort": 23, "isFeatured": true, "url": "286142-joel-mccrary", "peopleType": "Actor", "personName": "Joel McCrary", "personImgURL": "" }, { "id": 12149943, "name": "Janine", "peopleId": 277898, "seriesId": 0, "movieId": "445", "type": 3, "image": "", "sort": 24, "isFeatured": true, "url": "277898-marissa-jaret-winokur", "peopleType": "Actor", "personName": "Marissa Jaret Winokur", "personImgURL": "" }, { "id": 12149944, "name": "Firing Range Attendant", "peopleId": 333901, "seriesId": 0, "movieId": "445", "type": 3, "image": "", "sort": 5, "isFeatured": false, "url": "333901-matthew-kimbrough", "peopleType": "Actor", "personName": "Matthew Kimbrough", "personImgURL": "" }, { "id": 12149945, "name": "Spartanette #8", "peopleId": 329401, "seriesId": 0, "movieId": "445", "type": 3, "image": "", "sort": 6, "isFeatured": false, "url": "329401-nancy-anderson", "peopleType": "Actor", "personName": "Nancy Anderson", "personImgURL": "" }, { "id": 12149946, "name": "Playground Girl #1", "peopleId": 358834, "seriesId": 0, "movieId": "445", "type": 3, "image": "", "sort": 7, "isFeatured": false, "url": "358834-heather-joy-sher", "peopleType": "Actor", "personName": "Heather Joy Sher", "personImgURL": "" }, { "id": 12149947, "name": "Playground Girl #2", "peopleId": 284923, "seriesId": 0, "movieId": "445", "type": 3, "image": "", "sort": 8, "isFeatured": false, "url": "284923-chelsea-hertford", "peopleType": "Actor", "personName": "Chelsea Hertford", "personImgURL": "" }, { "id": 12149949, "peopleId": 379439, "seriesId": 0, "movieId": "445", "type": 1, "image": "", "sort": 6, "isFeatured": false, "url": "379439-sam-mendes", "peopleType": "Director", "personName": "Sam Mendes", "personImgURL": "https://artworks.thetvdb.com/banners/person/379439/primary.jpg" }, { "id": 12149950, "peopleId": 343182, "seriesId": 0, "movieId": "445", "type": 2, "image": "", "sort": 9, "isFeatured": false, "url": "343182-alan-ball", "peopleType": "Writer", "personName": "Alan Ball", "personImgURL": "" }, { "id": 12149951, "peopleId": 379444, "seriesId": 0, "movieId": "445", "type": 7, "image": "", "sort": 4, "isFeatured": false, "url": "379444-debra-zane", "peopleType": "Producer", "personName": "Debra Zane", "personImgURL": "" }, { "id": 12149953, "peopleId": 343182, "seriesId": 0, "movieId": "445", "type": 7, "image": "", "sort": 9, "isFeatured": false, "url": "343182-alan-ball", "peopleType": "Producer", "personName": "Alan Ball", "personImgURL": "" } ]
michalkaluza 8 Posted September 18, 2022 Posted September 18, 2022 (edited) This problem is also when you using themoviedb.org. First screen is from web page themoviedb, second one after identyfy the movie by emby. As you can see the order is not the same. Edited September 18, 2022 by michalkaluza
Happy2Play 9812 Posted September 18, 2022 Posted September 18, 2022 (edited) 16 minutes ago, michalkaluza said: This problem is also when you using themoviedb.org. First screen is from web page themoviedb, second one after identyfy the movie by emby. As you can see the order is not the same. But that is TVDB order not TMDB order As I get this from TMDB, same as site. TVDB is the primary defect here. Edited September 18, 2022 by Happy2Play
ebr 16337 Posted September 18, 2022 Posted September 18, 2022 Hi, there's already an open request for this or something functionally equivalent. Please join in and contribute to the existing discussion at:
WanderingCr0W 1 Posted April 7, 2023 Posted April 7, 2023 Would like to see the option to sort actors in different order in metadata manager.
Luke 42245 Posted April 7, 2023 Posted April 7, 2023 Hi, yes it’s something that needs to be added. 1 1
Romit 2 Posted April 7, 2023 Posted April 7, 2023 2 hours ago, Luke said: Hi, yes it’s something that needs to be added. Hi Luke, if you end up adding this feature, give us an option to make the director appear first in order for all contents. Thanks. 1
CharleyVarrick 284 Posted April 15, 2023 Posted April 15, 2023 (edited) Up Down arrows works for me, but if possible, it would be awesome by drag and drop. Edited April 15, 2023 by CharleyVarrick
Abobader 3485 Posted April 26, 2024 Posted April 26, 2024 Luke apply this in the latest beta, working great, well done Luke! 1 1
