Jeryd 1 Posted July 21, 2021 Posted July 21, 2021 1 hour ago, Luke said: Yes @cypher0117, yes please open a new topic. Thanks. Was this topic opened? I cant find it. I'm having the same issue. Reverse proxy (npm - handles SSL) to the http port and the system no longer reports if players are remote. It thinks everything is local.
Luke 42246 Posted July 21, 2021 Posted July 21, 2021 @Jeryd Hi, I would start by comparing your reverse proxy configuration to the nginx configuration used by @pir8radio
pir8radio 1313 Posted July 23, 2021 Posted July 23, 2021 On 7/21/2021 at 3:01 PM, Jeryd said: Was this topic opened? I cant find it. I'm having the same issue. Reverse proxy (npm - handles SSL) to the http port and the system no longer reports if players are remote. It thinks everything is local. probably missing a few headers in your proxy config.. x_forwarded_for would be where i would start looking.
Jeryd 1 Posted July 26, 2021 Author Posted July 26, 2021 On 7/23/2021 at 8:56 PM, Luke said: @Jeryd has this helped? Thanks for the follow up. I am guessing that was it, but the problem I was running into is that I was using NPM, so I was using the GUI and not doing any headers. Honestly, I found tailscale over the weekend and I went 100% in that direction. closed all outside ports and just rely on wireguard vpn.
