Junglejim 385 Posted December 14, 2024 Posted December 14, 2024 (edited) This change was implimented to make library scans quicker, which it does.. No need to scrape future bullcrap that you don't have and may never have! I think it was the way to go. What I think could be done is add a "missing episodes" to the shedule so we can run it overnight and don't get the spinning wheel when we enter that menu.. Edited December 14, 2024 by Junglejim 1 1
Trevor68 70 Posted December 14, 2024 Posted December 14, 2024 Can't be nearly as bad as the upcoming eps spinning wheel though right? The change was always touted as reducing database size BTW.
Junglejim 385 Posted December 14, 2024 Posted December 14, 2024 29 minutes ago, Trevor68 said: Can't be nearly as bad as the upcoming eps spinning wheel though right? The change was always touted as reducing database size BTW. No shit..
Trevor68 70 Posted December 14, 2024 Posted December 14, 2024 1 hour ago, Junglejim said: This change was implimented to make library scans quicker, none whatsover 1
bandit8623 232 Posted December 15, 2024 Posted December 15, 2024 On 11/21/2024 at 2:01 PM, Luke said: Yes but there are three dot menus all throughout that have this function. there is a number showing all non watched episodes why is it so bad or hard to have a red number on the top left showing missing?
Gilgamesh_48 1244 Posted December 15, 2024 Posted December 15, 2024 17 minutes ago, bandit8623 said: there is a number showing all non watched episodes why is it so bad or hard to have a red number on the top left showing missing? Well, that is the location Emby has chosen for multi-select so the upper left of a poster is not available. Also I imagine that these forums would be inundated with questions like "What is that number in the upper left?" But for me it is hideously easy to discover missing episodes, if I need to, using the current method. There are a LOT of other areas where Emby need to fix/improve things and most are WAY more important than finding missing episodes.
bandit8623 232 Posted December 15, 2024 Posted December 15, 2024 11 minutes ago, Gilgamesh_48 said: Well, that is the location Emby has chosen for multi-select so the upper left of a poster is not available. Also I imagine that these forums would be inundated with questions like "What is that number in the upper left?" But for me it is hideously easy to discover missing episodes, if I need to, using the current method. There are a LOT of other areas where Emby need to fix/improve things and most are WAY more important than finding missing episodes. correct, but its better than having to click 3 dots on every show
Luke 42269 Posted December 18, 2024 Posted December 18, 2024 On 12/10/2024 at 2:21 PM, bandit8623 said: When you click the sort buttons should it not change how it sorts? In the video you can see when changing sort by date it doesn't change by date at all. Not does it sort differently by series. Actually it looks like these are in the UI but just never got implemented. We'll take a look at it. Thanks. 1
bandit8623 232 Posted December 18, 2024 Posted December 18, 2024 25 minutes ago, Luke said: Actually it looks like these are in the UI but just never got implemented. We'll take a look at it. Thanks. thanks @Luke
Theangelofspace15 2 Posted March 20 Posted March 20 Over a year later and the bug (removing missing episodes from the in-line list) is still not fixed. Time to find alternatives.
Luke 42269 Posted March 24 Posted March 24 On 3/19/2026 at 9:59 PM, Theangelofspace15 said: Over a year later and the bug (removing missing episodes from the in-line list) is still not fixed. Time to find alternatives. HI, have you tried using the context menu option to view missing episodes?
Theangelofspace15 2 Posted March 25 Posted March 25 (edited) 6 hours ago, Luke said: HI, have you tried using the context menu option to view missing episodes? Hi Luke, Are you asking about the one that many people have pointed out only works if you already know something is missing, or at least suspect it? That makes it pointless. I have been using it ever since we got this regression. It is incredibly annoying to start a marathon of a multi-season series, like House; both admin and regular users have given the same feedback; and then, a couple of seasons later, realize something looks off, and only then check the context menu. At this point, I feel like your response is coming from a bot, since it looks like the same response every time. I waited and tried to live with this bad user-experience “feature,” but I need to find an alternative. I am not asking for it back; we already lost that battle. Edited March 25 by Theangelofspace15 Proof read 2
