Eleumas31 18 Posted July 21, 2021 Posted July 21, 2021 (edited) I installed the latest version of Emby for DSM 7 and when i try to select a directory for create a library something is wrong. I tested on latest Apple Safari e Google Chrome. Thanks for help me. Registrazione schermo 2021-07-21 alle 18.06.19.mov Edited July 21, 2021 by Eleumas31
Carlo 4561 Posted July 21, 2021 Posted July 21, 2021 Hi, Do you already have the share setup on your Synology containing the media? Did you grant the System Internal Emby User read/write access to this share? 1
Eleumas31 18 Posted July 21, 2021 Author Posted July 21, 2021 @cayars thanks for reply. The issue is now solved. I had to grant the System Internal Emby User. Thanks for help me. 1
