cchsieh 8 Posted July 21, 2021 Posted July 21, 2021 (edited) Hi, My Sony SRS-HG1 dlna renderer supports DSD (dsf/dff) audio files directly. I try to play dsf audio files from Emby web client to Sony speaker, but it seems transcode to mp3. I also try to play flac audio files, it can play flac directly. I check the log and the server seems autodetect dsd for Sony speaker. (Log file: embyserver.dsf.txt & ffmpeg-transcode*) Then I try to create a custom profile for Sony SRS-HG1 and disable transcoding in the profile, but it still can't play dsf files directly. (Log file: embyserver.dsf.customprofiletxt.txt & SONY SRS-HG1 TEST.xml) What can I do for this situation? Thanks in advance. ffmpeg-transcode-44e50ce6-80fd-46d5-8d26-436358a1414d_1.txt embyserver.dsf.txt ffmpeg-transcode-0896c31e-afd7-4225-95f8-27c1735c7b8e_1.txt embyserver.dsf.customprofiletxt.txt SONY SRS-HG1 TEST.xml Edited July 21, 2021 by cchsieh
Luke 42237 Posted July 21, 2021 Posted July 21, 2021 Hi, please follow along in this topic: Which is on my to do list for review. Thanks.
