Carlo 4561 Posted July 25, 2021 Posted July 25, 2021 OK thank you. I would check your login credentials in the plugin setup and retype them just to make sure you have them correct. I was able to duplicate your results with a bad password on OpenSubtitles. I see a lot of errors in your log with douban.com mentioned? What is this?
Joechung 5 Posted July 25, 2021 Author Posted July 25, 2021 9 minutes ago, cayars said: OK thank you. I would check your login credentials in the plugin setup and retype them just to make sure you have them correct. I was able to duplicate your results with a bad password on OpenSubtitles. I see a lot of errors in your log with douban.com mentioned? What is this? Hello ma'am what should I do now to cooperate with you? Douban movie is a Chinese movie website (similar to imbd website) is used to scrape movie information, there is also a corresponding Douban plugin on emby. My OpenSubtitles account and password are correct. (This is for sure) I don't know how to get my emby to display search subtitles. I'm really struggling, can you help me solve my problem?
Joechung 5 Posted July 25, 2021 Author Posted July 25, 2021 12 minutes ago, cayars said: OK thank you. I would check your login credentials in the plugin setup and retype them just to make sure you have them correct. I was able to duplicate your results with a bad password on OpenSubtitles. I see a lot of errors in your log with douban.com mentioned? What is this? I have uploaded my logs and problem videos many times. I don't know why the reason is still not found. I previously uninstalled the Douban plugin and searched for subtitles and the results were the same as the video, without any changes. (So I think I can rule out the Douban plugin as the cause of the problem.)
Carlo 4561 Posted July 25, 2021 Posted July 25, 2021 Can you remove any any all subtitle plugin except for Open Subs just to narrow down possibilities?
Joechung 5 Posted July 25, 2021 Author Posted July 25, 2021 7 minutes ago, cayars said: Can you remove any any all subtitle plugin except for Open Subs just to narrow down possibilities? I have only OpenSubtitles. and subs plugins now. There are no other subtitle plugins. The video above also shows you the settings.
Joechung 5 Posted July 25, 2021 Author Posted July 25, 2021 8 minutes ago, cayars said: Can you remove all but open subs? Hello ma'am, do you mean I should delete all the plugins and only have open and subs left?
Joechung 5 Posted July 25, 2021 Author Posted July 25, 2021 11 minutes ago, cayars said: Can you remove all but open subs? Ma'am I suggest to ask for your direct remote assistance for me. Since this problem has been checked for a long time without a solution, remote assistance is probably the best way to go. It is also the best way to save time and effort.
Joechung 5 Posted July 25, 2021 Author Posted July 25, 2021 (edited) 34 minutes ago, cayars said: Can you remove all but open subs? I have only one subtitle plugin at the moment, OpenSubtitles, and I have uninstalled the rest of them. But still nothing has changed. I can't find the subtitles as well. Edited July 25, 2021 by Joechung
Carlo 4561 Posted July 25, 2021 Posted July 25, 2021 OK that's good but different than your last server log file. Can you do another search and upload your server log?
Joechung 5 Posted July 25, 2021 Author Posted July 25, 2021 1 minute ago, cayars said: OK that's good but different than your last server log file. Can you do another search and upload your server log? Okay I'll re-upload the log. embyserver.txt
ebr 16309 Posted July 25, 2021 Posted July 25, 2021 Hi. All attempts to reach the metadata providers are timing out. I couldn't find this specific to opensubtitles but I imagine it is the same problem. Something blocking the server from getting to them.
Joechung 5 Posted July 25, 2021 Author Posted July 25, 2021 3 minutes ago, ebr said: Hi. All attempts to reach the metadata providers are timing out. I couldn't find this specific to opensubtitles but I imagine it is the same problem. Something blocking the server from getting to them. So what should I do to make OpenSubtitles subtitles search properly?
Carlo 4561 Posted July 25, 2021 Posted July 25, 2021 I'm seeing a lot of timeout errors as well as still having Douban loaded. Loading Douban, Version=1.0.4.0, Culture=neutral, PublicKeyToken=null from /share/CACHEDEV1_DATA/.qpkg/EmbyServer/programdata/plugins/Douban.dll Are you running Emby Server behind a VPN or anything like that?
ebr 16309 Posted July 25, 2021 Posted July 25, 2021 You need to investigate why the server process cannot get out to the internet. It is probably a network configuration or firewall issue.
Joechung 5 Posted July 25, 2021 Author Posted July 25, 2021 15 minutes ago, ebr said: You need to investigate why the server process cannot get out to the internet. It is probably a network configuration or firewall issue. Hello, I'm a user in China, could the subtitle network have something to do with this? But I can access the OpenSubtitles website normally with the internet.
Joechung 5 Posted July 25, 2021 Author Posted July 25, 2021 17 minutes ago, cayars said: I'm seeing a lot of timeout errors as well as still having Douban loaded. Loading Douban, Version=1.0.4.0, Culture=neutral, PublicKeyToken=null from /share/CACHEDEV1_DATA/.qpkg/EmbyServer/programdata/plugins/Douban.dll Are you running Emby Server behind a VPN or anything like that? I don't have VPN turned on yet, I'm a Chinese user. I don't know if that would have anything to do with it. But I can access OpenSubtitles website normally. So is it necessary to uninstall the Douban plugin?
Carlo 4561 Posted July 25, 2021 Posted July 25, 2021 Yes please as we want to eliminate any other sub provider errors possibly affecting Open Subs. It's just one less issue in diagnosing your issue. Please turn off debug logging from your LOG menu as well.
Joechung 5 Posted July 25, 2021 Author Posted July 25, 2021 29 minutes ago, cayars said: Yes please as we want to eliminate any other sub provider errors possibly affecting Open Subs. It's just one less issue in diagnosing your issue. Please turn off debug logging from your LOG menu as well. I've turned off the debug log and uninstalled Douban, still no change, still can't find subtitles
Carlo 4561 Posted July 25, 2021 Posted July 25, 2021 New log with a test of a couple specific movies please.
Joechung 5 Posted July 25, 2021 Author Posted July 25, 2021 18 minutes ago, cayars said: New log with a test of a couple specific movies please. OK, then I'll resend you both the log and the video. 1217435112_Action2021-7-2523-55-13.avi embyserver.txt
Carlo 4561 Posted July 25, 2021 Posted July 25, 2021 This log looks like it's communicating just fine with Open Subs as there are no errors. Could you PM your open subtitles username and password so I can test using your credentials?
Joechung 5 Posted July 25, 2021 Author Posted July 25, 2021 (edited) 1 小时前,cayars 说: 此日志看起来与 Open Subs 通信得很好,因为没有错误。 你能PM你的开放字幕用户名和密码,以便我可以使用你的凭据进行测试吗? Edited July 25, 2021 by Joechung
Carlo 4561 Posted July 25, 2021 Posted July 25, 2021 Please edit and remove your credentials from the previous message. I did test with your credentials on a few movies and get back both English and simplified Chinese subs so it's not account related. @Luke any ideas how to troubleshoot this as it looks by the logs that requests are going through but not enough logging to know what it found.
Joechung 5 Posted July 25, 2021 Author Posted July 25, 2021 4 minutes ago, cayars said: Please edit and remove your credentials from the previous message. I did test with your credentials on a few movies and get back both English and simplified Chinese subs so it's not account related. @Luke any ideas how to troubleshoot this as it looks by the logs that requests are going through but not enough logging to know what it found. Yes, thank you ma'am. I hope I can solve my problem faster. And hopefully it will really solve my problem.
